电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【分享开发笔记,赚取电动螺丝刀】MAX78000开发板读取SD卡
【分享开发笔记,赚取电动螺丝刀】MAX78000开发板读取SD卡 23
2025-10-17 17:14:52     打赏
上一篇帖子讲述了使用MAX78000开发板驱动2.4寸SPI液晶屏,这次使用MAX78000开发板来读取SD卡。对,最终目的,我是想用MAX78000做成一个电子相册。
MAX78000FTHR开发板背面有集成一个microSD卡卡槽。通过QSPI0与主控连接。官方例程中“MaximSDK\Examples\MAX78000\SDHC_FTHR”有给出如何使用SD卡的例子。从这个例子中抽取出SD卡操作的函数。
首先创建SD卡的头文件:sd.h,这里创建了4个方法给用户使用。
#include <stdint.h>
uint8_t checkCardInserted(void);
int read_data(char filename[], uint8_t *type1, uint8_t *type2, float *height, float *weight);
int read_bmp(char filename[], uint8_t rgb_image[]);
int ls(char cwd[]);
然后是这些方法的具体实现:sd.c
/***** Includes *****/
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
#include "board.h"
#include "mxc_delay.h"
#include "mxc_device.h"
#include "gpio.h"
#include "uart.h"
#include "ff.h"
#include "sd.h"
UINT mounted = 0;
TCHAR *FF_ERRORS[20] = {
    "FR_OK",
    "FR_DISK_ERR",
    "FR_INT_ERR",
    "FR_NOT_READY",
    "FR_NO_FILE",
    "FR_NO_PATH",
    "FR_INVLAID_NAME",
    "FR_DENIED",
    "FR_EXIST",
    "FR_INVALID_OBJECT",
    "FR_WRITE_PROTECTED",
    "FR_INVALID_DRIVE",
    "FR_NOT_ENABLED",
    "FR_NO_FILESYSTEM",
    "FR_MKFS_ABORTED",
    "FR_TIMEOUT",
    "FR_LOCKED",
    "FR_NOT_ENOUGH_CORE",
    "FR_TOO_MANY_OPEN_FILES",
    "FR_INVALID_PARAMETER"
FRESULT err; //FFat Result (Struct)
TCHAR cwd[256];
FATFS *fs; //FFat Filesystem Object
FATFS fs_obj;
    // On the MAX78000FTHR board, P0.12 will be pulled low when a card is inserted.
    mxc_gpio_cfg_t cardDetect;
    cardDetect.port = MXC_GPIO0;
    cardDetect.mask = MXC_GPIO_PIN_12;
    cardDetect.func = MXC_GPIO_FUNC_IN;
    cardDetect.pad = MXC_GPIO_PAD_NONE;
    cardDetect.vssel = MXC_GPIO_VSSEL_VDDIOH;
    MXC_GPIO_Config(&cardDetect);
    // Exit function if card is already inserted
    if (MXC_GPIO_InGet(MXC_GPIO0, MXC_GPIO_PIN_12) == 0) {
        return 1;
    return 0;
int mount()
    fs = &fs_obj;
    if ((err = f_mount(fs, "", 1)) != FR_OK) { //Mount the default drive to fs now
        printf("Error opening SD card: %s\n", FF_ERRORS[err]);
        f_mount(NULL, "", 0);
    } else {
        printf("SD card mounted.\n");
        mounted = 1;
    f_getcwd(cwd, sizeof(cwd)); //Set the Current working directory
    return err;
int umount()
    if ((err = f_mount(NULL, "", 0)) != FR_OK) { //Unmount the default drive from its mount point
        printf("Error unmounting volume: %s\n", FF_ERRORS[err]);
    } else {
        printf("SD card unmounted.\n");
        mounted = 0;
    return err;
    FIL file; //FFat File Object
    UINT bytes_read;
    if (!mounted)
        mount();
    if ((err = f_open(&file, filename, FA_READ)) != FR_OK) {
        printf("Error opening file: %s\n", FF_ERRORS[err]);
        return err;
    // Type1 is encoded in uint8
    if ((err = f_read(&file, type1, 1, &bytes_read)) != FR_OK) {
        printf("Error reading file: %s\n", FF_ERRORS[err]);
        return err;
    // Type2 is encoded in uint8
    if ((err = f_read(&file, type2, 1, &bytes_read)) != FR_OK) {
        return err;
    // Height is encoded in float
    if ((err = f_read(&file, height, 4, &bytes_read)) != FR_OK) {
        return err;
    // Weight is encoded in float
    if ((err = f_read(&file, weight, 4, &bytes_read)) != FR_OK) {
        return err;
    if ((err = f_close(&file)) != FR_OK) {
        printf("Error closing file: %s\n", FF_ERRORS[err]);
        return err;
    return 0;
    UINT bytes_read;
    uint8_t *ptr = rgb_image;
    // int height = 60, width = 60;
    if (!mounted)
        mount();
        return err;
    // Image data begins at 0x54
    if ((err = f_lseek(&file, 54)) != FR_OK) {
        printf("Error seeking file: %s\n", FF_ERRORS[err]);
        return err;
    do
        if ((err = f_read(&file, ptr, 255, &bytes_read)) != FR_OK) {
            return err;
        ptr += 255;
    } while (bytes_read == 255);  // bytes_read<255 means the cursor reached EOF
        return err;
    return 0;
int ls(char cwd[])
	DIR dir;
	FILINFO fno;
    if (!mounted) {
        mount();
    printf("Listing Contents of %s - \n", cwd);
    if ((err = f_opendir(&dir, cwd)) == FR_OK) {
        while (1) {
            err = f_readdir(&dir, &fno);
            if (err != FR_OK || fno.fname[0] == 0) {
                break;
            printf("%s", fno.fname);
            if (fno.fattrib & AM_DIR) {
                printf("/");
            printf("\n");
        f_closedir(&dir);
    } else {
        printf("Error opening directory!\n");
        return err;
    printf("\nFinished listing contents\n");
    return err;
准备好一张microSD卡,然后用FAT文件系统格式化,存放一些文件到卡里。
依然使用上一个帖子的工程,将sd.h和sd.c文件拷贝到项目文件夹内。在main.c文件开头处引入sd.h文件。
#include "sd.h"
然后修改main()函数,这里仅仅是读取SD卡,显示SD卡的文件列表。
int main(void) {
	int count = 0;
	MXC_Delay(200000);
	MXC_ICC_Enable(MXC_ICC0);
	/* Set system clock to 100 MHz */
	MXC_SYS_Clock_Select(MXC_SYS_CLOCK_IPO);
	SystemCoreClockUpdate();
	while (1) {
		ls("/");
		LED_On(LED1);
		MXC_Delay(500000);
		LED_Off(LED1);
		MXC_Delay(500000);
		printf("count : %d\n", count++);
使用串口工具打开串口,可以看见板子重复读取SD卡文件列表,并通过串口打印。
