【简介】
S32K3 系列芯片是支持功能安全相关的特性,功能安全相关的特性在S32DS上是通过S322_SAF 模块来配置,可以通过以下的三个模块来配置。
从以下功能框图也可以看出eMCEM,提供安全服务的sevice 层封装了底层的FCCU/ERM 等配置。
在eMCEM(extended Microcontroller Error Manager) 中添加FCCU 的配置项目就以配置功能安全相关的特性.
emcem 驱动具有以下的配置能力
生成配置代码后,EMCEM 会生成如下的配置文件
const eMcem_ConfigType eMcem_Config_0 =
NULL_PTR, /* Configuration Timeout Notification function */
EMCEM_NO_LOCK, /* FCCU Configuration Lock Type */
&Fccu_Config_0, /* FCCU Configuration */
&Dcm_Config_0 /* DCM Configuration */
};上述的配置主要包含DCM 和 FCCU(Fault Collection and Control Unit)的配置,以下是Fccu_Config_0 配置。
static const eMcem_Fccu_ConfigType Fccu_Config_0 =
/* Configuration Register */
(uint32)(
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_CFG_EOUT_AFTER_RESET, EMCEM_DISABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_CFG_INDICATION_MODE, EMCEM_DISABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_CFG_POLARITY, EMCEM_FCCU_CFG_POLARITY_E1HE0L ) |
EMCEM_FCCU_CFG_EOUT_BISTABLE
), /* Configuration Register = 0x00000080UL */
/* NCF Recovery Timeout Register = 65535 [48MHz IRC ticks] (1365 [us]) */
(uint32)0x0000FFFFUL,
/* Configuration Timeout Register = 5 (5461 [us]) */
(uint32)0x00000005UL,
/* EOUT DeltaT Signal Duration Register = 0 [us] */
(uint32)0UL,
/* Configuration State Timeout IRQ Enable Register = Enabled */
(uint32)EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_CFG_IRQ_EN, EMCEM_ENABLED ),
/* NCF Enable Registers */
(uint32)(
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_0_M7_HSE_LOCKUP, EMCEM_ENABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_1_GASKET_ERROR_XBAR, EMCEM_ENABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_2_RAM_ERROR, EMCEM_ENABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_3_FLASH_ERROR, EMCEM_ENABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_4_VOLTAGE_ERROR, EMCEM_ENABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_5_DBG_TEST_MONITORING, EMCEM_ENABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_6_INTM_ERROR, EMCEM_ENABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_7_SW_FAULT, EMCEM_ENABLED )
) /* NCF Enable Register 0 = 0x000000FFUL */
/* NCF Cfg Registers */
(uint32)(
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_0_M7_HSE_LOCKUP, EMCEM_FCCU_RECOVERY_SW ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_1_GASKET_ERROR_XBAR, EMCEM_FCCU_RECOVERY_SW ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_2_RAM_ERROR, EMCEM_FCCU_RECOVERY_SW ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_3_FLASH_ERROR, EMCEM_FCCU_RECOVERY_SW ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_4_VOLTAGE_ERROR, EMCEM_FCCU_RECOVERY_SW ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_5_DBG_TEST_MONITORING, EMCEM_FCCU_RECOVERY_SW ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_6_INTM_ERROR, EMCEM_FCCU_RECOVERY_SW ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_7_SW_FAULT, EMCEM_FCCU_RECOVERY_SW )
) /* NCF Cfg Register 0 = 0x000000FFUL */
/* NCF Alarm Interrupt Enable Registers */
(uint32)(
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_0_M7_HSE_LOCKUP, EMCEM_DISABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_1_GASKET_ERROR_XBAR, EMCEM_DISABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_2_RAM_ERROR, EMCEM_DISABLED ) |
EMCEM_CONFIG_VAL_1BIT( EMCEM_FCCU_NCF_3_FLASH_ERROR, EMCEM_DISABLED ) |
) /* NCF Alarm Interrupt Enable Register 0 = 0x000000F0UL */
/* NCF NMI Enable Registers */
(uint32)(
) /* NCF NMI Enable Register 0 = 0x000000F0UL */
/* NCF Recovery Timeout Enable Registers */
(uint32)(
) /* NCF Recovery Timeout Enable Register 0 = 0x000000F0UL */
/* NCF EOUT Signaling Enable Registers */
(uint32)(
) /* NCF EOUT Signaling Enable Register 0 = 0x000000FFUL */
/* NCF Reaction Type Registers */
(uint32)(
EMCEM_CONFIG_VAL_2BITS( EMCEM_FCCU_NCF_0_M7_HSE_LOCKUP, EMCEM_FCCU_REACTION_SHORTRESETREACTION ) |
EMCEM_CONFIG_VAL_2BITS( EMCEM_FCCU_NCF_1_GASKET_ERROR_XBAR, EMCEM_FCCU_REACTION_SHORTRESETREACTION ) |
EMCEM_CONFIG_VAL_2BITS( EMCEM_FCCU_NCF_2_RAM_ERROR, EMCEM_FCCU_REACTION_SHORTRESETREACTION ) |
EMCEM_CONFIG_VAL_2BITS( EMCEM_FCCU_NCF_3_FLASH_ERROR, EMCEM_FCCU_REACTION_SHORTRESETREACTION ) |
EMCEM_CONFIG_VAL_2BITS( EMCEM_FCCU_NCF_4_VOLTAGE_ERROR, EMCEM_FCCU_REACTION_NORESETREACTION ) |
EMCEM_CONFIG_VAL_2BITS( EMCEM_FCCU_NCF_5_DBG_TEST_MONITORING, EMCEM_FCCU_REACTION_NORESETREACTION ) |
EMCEM_CONFIG_VAL_2BITS( EMCEM_FCCU_NCF_6_INTM_ERROR, EMCEM_FCCU_REACTION_NORESETREACTION ) |
EMCEM_CONFIG_VAL_2BITS( EMCEM_FCCU_NCF_7_SW_FAULT, EMCEM_FCCU_REACTION_NORESETREACTION )
) /* NCF Reaction Type Register 0 = 0x00000055UL */
/* FCCU Alarm Handler Functions */
NULL_PTR,
NULL_PTR,
NULL_PTR,
NULL_PTR,
NULL_PTR,
NULL_PTR,
NULL_PTR,
NULL_PTR
/* NMI notification function */
NULL_PTR
};对应的FCCU 的配置结构定义如下:
* @brief FCCU configuration struct type
* @details Configuration values of individual FCCU configuration registers.
typedef struct
uint32 Fault_Config; /**< @brief Configuration Register */
uint32 Fault_Ncf_TO; /**< @brief Non-Critical Fault Recovery Timeout Register */
uint32 Fault_Cfg_TO; /**< @brief Configuration timeout Register */
uint32 Fault_DeltaT; /**< @brief EOUT DeltaT signal duration Register */
uint32 Fault_Irq_EN; /**< @brief Configuration Timeout Enable Register */
uint32 Fault_Ncf_E[FCCU_FAULT_REGISTER_COUNT]; /**< @brief NCF Enable Registers */
uint32 Fault_Ncf_Cfg[FCCU_FAULT_REGISTER_COUNT]; /**< @brief NCF Cfg Registers */
uint32 Fault_Alarm_EN[FCCU_FAULT_REGISTER_COUNT]; /**< @brief NCF Alarm Interrupt Enable Registers */
uint32 Fault_Nmi_EN[FCCU_FAULT_REGISTER_COUNT]; /**< @brief NCF NMI Enable Registers */
uint32 Fault_Ncf_TOE[FCCU_FAULT_REGISTER_COUNT]; /**< @brief NCF Recovery Timeout Enable Registers */
uint32 Fault_EoutSig_EN[FCCU_FAULT_REGISTER_COUNT]; /**< @brief NCF EOUT Signaling Enable Registers */
uint32 Fault_Ncfs_Cfg[FCCU_FAULT_STATE_REGISTER_COUNT];/**< @brief NCF Reaction Type Registers */
eMcem_FccuHandlerType Fault_AlarmHandler[FCCU_NCF_COUNT]; /**< @brief NCF Alarm Handlers */
eMcem_NMINotificationType Fault_NMINotification; /**< @brief NMI Notification Function */
} eMcem_Fccu_ConfigType;以下RTD 代码会根据传入的传入的config 结构对FCCU进行初始化。
Std_ReturnType eMcem_Fccu_Init( const eMcem_Fccu_ConfigType *pConfigPtr )
uint32 u32ReadBack;
uint8 u8Bank;
volatile Std_ReturnType nReturnValue = (Std_ReturnType)E_OK;
eMcem_Fccu_pCurrentConfigPtr = pConfigPtr;
/* Set to FALSE to eliminate unwanted TIMEOUT_ISR */
Fccu_bCfgTimeoutExpired = (boolean)FALSE;
/* Clear Configuration Timeout Interrupt Flag.
* Flag shall be cleared at the beginning of eMcem_Fccu_Init to avoid false generation of CFG_TO interrupt.
* Also CFG_TO flag set with disabled CFG_TO interrupt leads to this function returning E_NOT_OK. */
/* @violates @ref eMcem_Fccu_c_REF_1104 */
/* @violates @ref eMcem_Fccu_c_REF_1106 */
SAFETYBASE_REG_WRITE32( FCCU_IRQ_STAT_ADDR32, FCCU_CFG_TO_IRQ_U32 );
#if( STD_ON == EMCEM_FCCU_DEBUG_MODE_ENABLED )
/* Enable FCCU debug mode if configured */
SAFETYBASE_REG_WRITE32( FCCU_CTRL_ADDR32, ( 1UL << EMCEM_FCCU_CTRL_DEBUG_MODE ) );
#endif
/* Read NCF_S0 status register */
/* @violates @ref eMcem_Fccu_c_REF_1008 */
u32ReadBack = SAFETYBASE_REG_READ32( FCCU_NCF_S_ADDR32( 0U ) );
/* Check if any NCF flag is set */
if( u32ReadBack > 0UL )
/* Go through all NCF flags */
for( u8Bank = 0U; ( (Std_ReturnType)E_OK == nReturnValue ) && ( u8Bank < EMCEM_FCCU_NCF_TOTAL_NUMBER ); u8Bank++ )
/* Check if specific NCF flag is set */
if( ( u32ReadBack & ( 1UL << (uint32)u8Bank ) ) > 0UL )
/* Clear NCF flag */
nReturnValue = eMcem_Fccu_ClearFault( u8Bank );
/* Clear DCM flags related to current NCF */
if( (Std_ReturnType)E_OK == nReturnValue )
nReturnValue = eMcem_Dcm_ClearNCFFaults( u8Bank );
#if( STD_ON == EMCEM_EXT_DIAG_ENABLED )
/* Log extended diagnostic data */
eMcem_StoreFailurePoint( nReturnValue, EMCEM_FP_FCCU_INIT_1, u8Bank );
#endif
/* Configure FCCU. Enters CONFIG state, configures FCCU, and enters NORMAL state */
nReturnValue = eMcem_Fccu_ConfigureFccu();
/* Check if configuration timeout occurred */
nReturnValue = eMcem_Fccu_CheckCfgTO();
/* Release EOUT pins */
DCM_GPR.DCMRWD2.B.EOUT_STAT_DUR_STEST = 0U;
return nReturnValue;
}上述的函数会将配置结构体 赋值到全局配置变量
然后调用 如下函数对传入的结构进行配置。
FCCU 内部对于错误的管理是按照group 进行管理的对应的如下的7个Slot ,每个slot 下会关联多个错误类型。
代码通过如下寄存器来开启FCCU NCF 中断使能。
以下是FCCU 模块的异常动作行为迁移图
