电子产品世界 » 论坛首页 » 活动中心 » 有奖活动 » SWM221CBT7显示开发板驱动OLED屏显示
SWM221CBT7显示开发板驱动OLED屏显示 19
2025-11-13 12:01:34     打赏
上一篇介绍了SWM221CBT7显示开发板的基本用法,这次来介绍如何用GPIO口以模拟I2C的方式来驱动OLED屏。
常见的OLED屏,有0.91寸和0.96寸这2种,除初始化的函数不同外,其它的基本相同。
为后续实现硬件驱动的方便,这里选取的连接引脚就选用对应的I2C引脚。
将所用引脚配置为输出模式的函数为:
void oled_config(void)
    GPIO_Init(GPIOA, PIN6, 1, 0, 0, 0);
    GPIO_Init(GPIOA, PIN7, 1, 0, 0, 0);
为便于输出高低电平的需要,相应的定义语句为:
#define OLED_SCLK_Clr()   GPIO_ClrBit(GPIOA, PIN6)
#define OLED_SCLK_Set()   GPIO_SetBit(GPIOA, PIN6)
#define OLED_SDIN_Clr()   GPIO_ClrBit(GPIOA, PIN7)
#define OLED_SDIN_Set()   GPIO_SetBit(GPIOA, PIN7)
使显示屏工作的参数设置为:
#define OLED_MODE   0
#define SIZE          16
#define XLevelL     0x02
#define XLevelH     0x10
#define Max_Column 128
#define Max_Row  64
#define Brightness 0xFF
#define X_WIDTH      128
#define Y_WIDTH      64
#define OLED_CMD    0
#define OLED_DATA    1
使用GPIO口模拟I2C方式发送字节数据的函数为:
void Write_IIC_Byte(unsigned char IIC_Byte)
     unsigned char i;
     unsigned char m,da;
     da=IIC_Byte;
     OLED_SCLK_Clr();
     for(i=0;i<8;i++)
        m=da;
        m=m&0x80;
        if(m==0x80)
            OLED_SDIN_Set();
        else
            OLED_SDIN_Clr();
        da=da<<1;
        delay_us(3);
        OLED_SCLK_Set();
        delay_us(3);
        OLED_SCLK_Clr();
        delay_us(3);
对0.91寸屏的初始化函数为:
void OLED_Init(void)
    Write_IIC_Command(0xAE);
    Write_IIC_Command(0x40);
    Write_IIC_Command(0xb0);
    Write_IIC_Command(0xc8);
    Write_IIC_Command(0x81);
    Write_IIC_Command(0xff);
    Writ e_IIC_Command(0xa1);
    Write_IIC_Command(0xa6);
    Write_IIC_Command(0xa8);
    Write_IIC_Command(0x1F);
    Write_IIC_Command(0xd3);
    Write_IIC_Command(0x00);
    Write_IIC_Command(0xd5);
    Write_IIC_Command(0xf0);
    Write_IIC_Command(0xd9);
    Write_IIC_Command(0x22);
    Write_IIC_Command(0xda);
    Write_IIC_Command(0x02);
    Write_IIC_Command(0x8d);
    Write_IIC_Command(0x14);
    Write_IIC_Command(0xdb);
    Write_IIC_Command(0x49);
    Write_IIC_Command(0xaf);
实现驱动测试的主程序为:
int main(void)
    SystemInit();
    GPIO_Init(GPIOA, PIN5, 1, 0, 0, 0);
    oled_config();
    OLED_Init();
    OLED_Clear();
     OLED_ShowString(0,0,"SWDM221CBA5",16);
    OLED_ShowString(0,2,"jinglixixi",16);
    while(1)
       GPIO_SetBit(GPIOA, PIN5);
       delay_ms(300);
        GPIO_ClrBit(GPIOA, PIN5);
       delay_ms(300);
经程序的编译和下载,其测试效果如图2所示,说明驱动有效。
图2 测试效果
若变更初始化函数,则可实现0.96寸显示屏的驱动,其初始化函数为:
    Write_IIC_Command(0x20);
    Write_IIC_Command(0x10);
    Write_IIC_Command(0xdf);
    Write_IIC_Command(0xa1);
    Write_IIC_Command(0x3F);
    Write_IIC_Command(0xa4);
    Write_IIC_Command(0x12);
经测试,去显示效果如图3所示,说明驱动有效且成功。
图3 显示效果
关键词: SWM221CBT7
2025-11-18 12:07:29     打赏
是的,我一般是先模拟I2C再到I2C驱动,这样会稳妥些。
