电子产品世界 » 论坛首页 » 活动中心 » 有奖活动 » 在RA4M2-SENSOR上以手机控制RGBLED彩灯效果
2025-12-06 16:28:05     打赏
RA4M2-SENSOR是一款体型小巧的开发板,用串口与蓝牙通讯模块相结合,可方便地以手机控制RGB_LED实现彩灯的色彩变换,其整体构成如图1所示。
图1 整体构成
尽管UART9在调试有较大的优势,但它却缺少向外引出的引脚,故无法直接使用。
图2  UART9引脚
为此,只能启用串口 UART0,其使用的引脚如图3所示。蓝牙通讯模块可通过 UART0来进行数据的传送。
图3  UART0引脚
此外,为了变换色彩的需要,选用的是一款RGB_LED模块,并使用CN4接口来与其连接。
图4  CN4接口
在使用RASC对所用引脚进行配置后,即可生成供KEIL使用的项目工程。
在手机控制下,实现RGB_LED彩灯变换效果的主程序为:
void hal_entry(void)
     uint8_t p,f,w,z;
     uint16_t k,u;
     err = R_SCI_UART_Open(&g_uart0_ctrl, &g_uart0_cfg);
     assert(FSP_SUCCESS == err);
     err = R_SCI_UART_Read(&g_uart0_ctrl, uart_rx_buffer, 3);
     R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_02, BSP_IO_LEVEL_LOW);
     R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_03, BSP_IO_LEVEL_LOW);
     R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_04, BSP_IO_LEVEL_LOW);
     R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_00, BSP_IO_LEVEL_LOW);
     R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_03_PIN_01, BSP_IO_LEVEL_LOW);
     R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_03_PIN_02, BSP_IO_LEVEL_LOW);
     R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_07, BSP_IO_LEVEL_LOW);
     R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_08, BSP_IO_LEVEL_LOW);
     while(1)
        if(uart_receive_complete_flag)
           uart_receive_complete_flag = false;
           if(uart_rx_buffer[0] == 0x55 && uart_rx_buffer[1] == 0xAA)
              if(uart_rx_buffer[2] == 0x10)
                 R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_02, BSP_IO_LEVEL_HIGH);
                 R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_00, BSP_IO_LEVEL_HIGH);
              if(uart_rx_buffer[2] == 0x11)
                 R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_07, BSP_IO_LEVEL_HIGH);
                 R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_03_PIN_02, BSP_IO_LEVEL_HIGH);
              if(uart_rx_buffer[2] == 0x12)
                 R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_03, BSP_IO_LEVEL_HIGH);
                 R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_08, BSP_IO_LEVEL_HIGH);
                 R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_03_PIN_01, BSP_IO_LEVEL_HIGH);
              if(uart_rx_buffer[2] == 0x13)
              if(uart_rx_buffer[2] == 0x14)
                 R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_04, BSP_IO_LEVEL_HIGH);
                           if(uart_rx_buffer[2] == 0x15)
                          if(uart_rx_buffer[2] == 0x16)
                           if(uart_rx_buffer[2] == 0x17)
                   R_BSP_SoftwareDelay (100, BSP_DELAY_UNITS_MILLISECONDS);
经程序的编译和下载,即可在手机控制下,实现色彩变换的效果。
关键词: RA4M2-SENSOR
