共1条
去藕电容的位置
有书有这么一段描述:
Do not put the bypass capacitors within the package footprint
(on the underside of the board) if signal feedthroughts perforate
the ground plane. Return current must flow to the outside ground plane,
which may be poorly connected to the inside ground plane if this is perforated by f
by feedthroughts.
大虾,解释一下吧?
关键词: 去藕 电容 位置
共1条
