重定向了_user_initial_stackheap,但仍出现以下错误
:Error : L6218E: Undefined symbol Image$$ZI$$Limit (referred from sys_stackheap.o)
 AREA START, CODE, READONLY
 CODE32
 IMPORT _main
 EXPORT Start
 EXPORT _user_initial_stackheap
 EXPORT stack_base
 EXPORT heap_base
ENTRY
Start
 BL InitStack
 BL MAC7111Init
 B  _main
 LDR R0, =heap_base
 LDR R1, =stack_base
 MOV PC, LR
InitStack
 MOV R0, LR             ;每种模式对应不同的LR,程序以管理员模式进入,以用户模式返回,所以要保存LR
 MSR CPSR_c, #0xd3       ;设置管理员模式堆栈
 LDR SP, StackSvc
 MSR CPSR_c, #0xd1       ;设置FIQ模式堆栈
 LDR SP, StackFIQ
 MSR CPSR_c, #0xd2       ;设置IRQ模式堆栈
 LDR SP, StackIRQ
 MSR CPSR_c, #0xd7       ;设置中止模式堆栈
 LDR SP, StackAbt
 MSR CPSR_c, #0xdb       ;设置未定义模式堆栈
 LDR SP, StackUde
 MSR CPSR_c, #0xdf       ;设置SYS模式堆栈
 LDR SP, =stack_base
MOV PC, R0
INTC_BASE  EQU 0xFC048000
INTC_CFG   EQU 0x0018
CRG_BASE   EQU 0xFC088000
CRG_SYNR   EQU 0x0000
CRG_RFDV   EQU 0x0001
CRG_CLKSEL EQU 0x0005
CRG_PLLCTL EQU 0x0006
EIM_BASE   EQU 0xFC008000
CASR0      EQU 0x0080              ;16BIT
CSMR0      EQU 0x0084              ;32BIT
CSCR0      EQU 0x0088              ;16BIT
CASR1      EQU 0x008C              ;16BIT
CSMR1      EQU 0x0090
CSCR1      EQU 0x0094              ;16BIT
CASR2      EQU 0x0098              ;16BIT
CSMR2      EQU 0x009C
CSCR2      EQU 0x00A0              ;16BIT
;CASR0      EQU 0xFC008080
;CSMR0      EQU 0xFC008084
;CSCR0      EQU 0xFC008088
;CASR1      EQU 0xFC00808C
;CSMR1      EQU 0xFC008090
;CSCR1      EQU 0xFC008094
;CASR2      EQU 0xFC008098
;CSMR2      EQU 0xFC00809C
;CSCR2      EQU 0xFC0080A0
MAC7111Init
 LDR  R0, =CRG_BASE
 LDR  R1, =0x0
 STRB R1, [R0, #CRG_CLKSEL]    ;Fclk=Fosc=8MHz
 STRB R1, [R0, #CRG_PLLCTL]    ;PLL Disabled, Clock Monitor Disabled
 ;AT RESET ALL THE INTERRUPT ARE DISABLED
 LDR  R0, =EIM_BASE
 LDR  R1, =0x00000000
 STR  R1, [R0, #CASR1]
 LDR  R1, =0x00010001
 STR  R1, [R0, #CSMR1]
 LDR  R1, =0x000005A0
 STR  R1, [R0, #CSCR1]
 LDR  R1, =0x00300000
 STR  R1, [R0, #CASR2]
 LDR  R1, =0x00000001
 STR  R1, [R0, #CSMR2]
 LDR  R1, =0x000001A0
 STR  R1, [R0, #CSCR2]
 LDR  R1, =0x00020000
 STR  R1, [R0, #CASR0]
 LDR  R1, =0x000009A0
 STR  R1, [R0, #CSCR0]
 LDR  R1, =0x001F0000
 STR  R1, [R0, #CSMR0]
 NOP
 NOP
 NOP
 NOP
 NOP
 NOP
 NOP
 LDR  R1, =0x001F0001
 MOV  PC, LR
 AREA RAMDATA, DATA, READWRITE
StackIRQ SPACE 256
StackFIQ SPACE 256
StackSvc SPACE 256
StackAbt SPACE 256
StackUde SPACE 256
StackSys SPACE 256
 AREA stack, DATA, NOINIT
stack_base SPACE 1024
 AREA heap, DATA, NOINIT
heap_base  SPACE 1024
 END
scf文件
LOAD_RAM 0x00000000                     ;加载域为RAM
RUN_RAM 0x00000000   0x5000            ;第一个运行时域,长20K Bytes
Vectors.o(vector, +First)
*(+RO)
ISR_table 0x00005000               ;256byte for 64 int sources
Vectors.o(ISRAddr, +First)
data 0x00005100
*(+RW, +ZI)
heaps 0x00006000   UNINIT
init.o(heap, +First)
stacks 0x00020000 UNINIT                 ;128K RAM的顶端
init.o(stack, +First)
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
