电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 内存设置问题
共3条 1/1 1 跳转至页
内存设置问题
2006-05-12 18:16:00     打赏
我用的是勤研的2440 开发板,启动到wince后,发现内存大小,显示只有24M,而板上的内存有64M,请问如何设置
关键词: 内存     设置     问题
2006-05-12 19:08:00     打赏
MEMORY
;#define CHAIN_ADDRESS 81E40000
; CHAIN $(CHAIN_ADDRESS) 00001000 RESERVED
; pdwXIPLoc 00000000 $(CHAIN_ADDRESS) FIXUPVAR
;;; Tarzan Debug mode
NK 8C200000 02400000 RAMIMAGE
; NK 80040000 01E00000 RAMIMAGE
; CHAIN 81E40000 00001000 RESERVED
; DRIVERS 81E41000 001BF000 RAMIMAGE
; RESERVE 8df00000 00080000
; RAM 8c200000 01D00000 RAM
RAM 8E600000 01900000 RAM
; Common RAM areas
AUD_DMA 8c002000 00002000 RESERVED
DRV_GLB 8c010000 00010000 RESERVED
; DBGSER_DMA 8c022000 00002000 RESERVED
; SER_DMA 8c024000 00002000 RESERVED
; IR_DMA 8c026000 00002000 RESERVED
SD_DMA 8c028000 00008000 RESERVED
EDBG 8c030000 00020000 RESERVED
; CAMERA 8c050000 000A0000 RESERVED
; CAMERA 8c088000 00140000 RESERVED
; DISPLAY 8c100000 00100000 RESERVED
DISPLAY 8c1d0000 00030000 RESERVED
CONFIG
COMPRESSION=ON
KERNELFIXUPS=ON
IF IMGPROFILER
PROFILE=ON
ENDIF
IF IMGPROFILER !
PROFILE=OFF
ENDIF
IF IMGTRUSTROMONLY
IF IMGNOTALLKMODE
ROMFLAGS=12
ENDIF
IF IMGNOTALLKMODE !
ROMFLAGS=10
ENDIF
ENDIF
IF IMGTRUSTROMONLY !
IF IMGNOTALLKMODE
ROMFLAGS=2
ENDIF
IF IMGNOTALLKMODE !
ROMFLAGS=0
ENDIF
ENDIF
ROMSTART=8C200000
ROMWIDTH=32
ROMSIZE=02400000
2006-05-12 19:18:00     打赏
OEMAddressTable
;;; Virt Addr Phys Addr MB
DCD 0x80000000, 0x02000000, 30 ; 30 MB SRAM(SRAM/ROM) BANK 0
DCD 0x82000000, 0x08000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 1
DCD 0x84000000, 0x10000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 2
DCD 0x86000000, 0x18000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 3
DCD 0x88000000, 0x20000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 4
DCD 0x8A000000, 0x28000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 5
DCD 0x8C000000, 0x30000000, 64 ; 64 MB DRAM BANK 0, 1
DCD 0x90800000, 0x48000000, 1 ; Memory control register
DCD 0x90900000, 0x49000000, 1 ; USB Host register
DCD 0x90A00000, 0x4A000000, 1 ; Interrupt Control register
DCD 0x90B00000, 0x4B000000, 1 ; DMA control register
DCD 0x90C00000, 0x4C000000, 1 ; Clock & Power register
DCD 0x90D00000, 0x4D000000, 1 ; LCD control register
DCD 0x90E00000, 0x4E000000, 1 ; NAND flash control register
DCD 0x90F00000, 0x4F000000, 1 ; Camera control register
DCD 0x91000000, 0x50000000, 1 ; UART control register
DCD 0x91100000, 0x51000000, 1 ; PWM timer register
DCD 0x91200000, 0x52000000, 1 ; USB device register
DCD 0x91300000, 0x53000000, 1 ; Watchdog Timer register
DCD 0x91400000, 0x54000000, 1 ; IIC control register
DCD 0x91500000, 0x55000000, 1 ; IIS control register
DCD 0x91600000, 0x56000000, 1 ; I/O Port register
DCD 0x91700000, 0x57000000, 1 ; RTC control register
DCD 0x91800000, 0x58000000, 1 ; A/D convert register
DCD 0x91900000, 0x59000000, 1 ; SPI register
DCD 0x91A00000, 0x5A000000, 1 ; SD Interface register
DCD 0x91B00000, 0x5B000000, 1 ; AC97 Interface register
DCD 0x92000000, 0x00000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 0
DCD 0x00000000, 0x00000000, 0 ; End of Table (MB MUST BE ZERO!)
共3条 1/1 1 跳转至页
