问
在http://www.zlgmcu.com网站的专栏上下载了一份uc/os在Keil上的移植程序,作了一些应用的改动,主要是想验证一下使用uc/os的内存管理,在这里我使用任务1分配一块内存,然后发送相应的消息,在任务2中接收相应的消息,释放分配的内存,发现发配的内存指针在传递的过程中被更改,不知到是为什么?能帮助解释一下吗?谢谢!
void Task1(void xdata * ppdata) reentrant
unsigned char err;
stryy xdata* kk;
ppdata = ppdata;
while(1)
number++;
if(number>9) number=0;
kk=(stryy xdata*)OSMemGet(mem,&err);
//kk=yyy;
kk->a=5 ;
err=OSQPost(CommQ,(void *)kk);
switch(err)
case OS_NO_ERR:
printf("post msg ok!\n");
break;
case OS_Q_FULL:
OSQFlush(CommQ);
printf("box is over!");
break;
// printf("\n1");
OSTimeDlyHMSM(0,0,10,0);
void Task2(void xdata * ppdata) reentrant
unsigned char err;
unsigned char xdata *pp;
ppdata = ppdata;
while(1)
pp=(unsigned char xdata*)OSQPend(CommQ,0,&err);
if(err==OS_NO_ERR)
switch(*pp)
case 1:
printf("received value is 1\n");
break;
case 2:
printf("received value is 2\n");
break;
case 3:
printf("received value is 3\n");
break;
case 4:
printf("received value is 4\n");
break;
case 5:
printf("received value is 5\n");
break;
case 6:
printf("received value is 6\n");
break;
case 7:
printf("received value is 7\n");
break;
case 8:
printf("received value is 8\n");
break;
case 9:
printf("received value is 9\n");
break;
case 0:
printf("received value is 0\n");
break;
default:
printf("received default");
break;
else
printf("err explain");
err=OSMemPut(mem,pp);
void SerialInitial()
/* set TI to 1, set TR1 to 1 */
SCON = 0x52;/* SM0 SM1 =1 SM2 REN TB8 RB8 TI RI */
TMOD = 0x20;/* GATE=0 C/T-=0 M1 M0=2 GATE C/T- M1 M0 */
TH1 = 0xE6; /* TH1=E6 4800bit/s when at 24MHz,TH1=F3,9600bit/s,24MHz */
PCON = 0x80;
TCON = 0x40;/* 01101001 TF1 TR1 TF0 TR0 IE1 IT1 IE0 IT */
void InterruptInitial()
/* set timer. 50ms, THTL = 3caf when cpu at 12MHz */
TMOD |= 0x01;
TH0 = 0x70;
TL0 = 0x00;
/* TR0 is set in OSStart() */
ET0 = 1;
main()
unsigned char errm;
SerialInitial();
InterruptInitial();
OSInit();
printf("\nstart");
//pReceiverMailBox=OSMboxCreate((void*)0);
//pSenderMailBox=OSMboxCreate((void*)0);
mem=OSMemCreate(&Memo,5,32,&errm);
CommQ=OSQCreate((void xdata*)&CommMsg[0],3);
OSQFlush(CommQ);
OSTaskCreate(Task1, (void xdata *)0, &Task1Stack[0],2);
OSTaskCreate(Task2, (void xdata *)0, &Task2Stack[0],3);
OSStart();
答 1: 在问是否ucos在8位机上移植有限制?
unsigned char err;
stryy xdata* kk;
ppdata = ppdata;
while(1)
number++;
//kk=yyy;
kk->a=5 ;
switch(err)
case OS_NO_ERR:
break;
case OS_Q_FULL:
OSQFlush(CommQ);
break;
// printf("\n1");
unsigned char err;
ppdata = ppdata;
while(1)
if(err==OS_NO_ERR)
switch(*pp)
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 0:
break;
default:
break;
else
PCON = 0x80;
TMOD |= 0x01;
TH0 = 0x70;
TL0 = 0x00;
ET0 = 1;
main()
unsigned char errm;
SerialInitial();
InterruptInitial();
OSInit();
printf("\nstart");
OSQFlush(CommQ);
OSStart();
| 为遥控小车巧添功能被打赏¥26元 | |
