Information,Why Information? Why
问
:confused: Building configuration: test - Debug
Linking
xlink.exe D:\Program Files\IAR Systems\Embedded Workbench 3.2\Debug\Obj\fet110_1.r43 -o D:\Program Files\IAR
Systems\Embedded Workbench 3.2\Debug\Exe\test.d43 -rt -ID:\Program Files\IAR Systems\Embedded Workbench 3.2\
430\LIB\ -f D:\Program Files\IAR Systems\Embedded Workbench 3.2\430\config\lnk430F110.xcl D:\Program Files\IAR
Systems\Embedded Workbench 3.2\430\lib\dl430f.r43
IAR Universal Linker V4.56E/386
Copyright 1987-2003 IAR Systems. All rights reserved.
Error[e16]: Segment INTVEC (size: 0x20 align: 0x1) is too long for segment definition. At least 0x2 more bytes needed. The
problem occurred while processing the segment placement command "-Z(CONST)INTVEC=FFE0-FFFF", where at the
moment of placement the available memory ranges were "CODE:FFE0-FFFD"
Reserved ranges relevant to this placement:
CODE:FFFE-FFFF Absolute code from fet110_1
Total number of errors: 1
Total number of warnings: 0
Linking
