问
Building configuration: w413 - Debug
fet410_1.s43
a430.exe -OD:\IAR Systems\一代II\Debug\Obj\ -s+ -M<> -w+ -IC:\IAR Systems\Embedded Workbench 3.2\430\inc\ -r D:\IAR Systems\新一代II\fet410_1.s43
Errors: 0
Warnings: 0
Bytes: 8160
Linking
xlink.exe D:\IAR Systems\II\Debug\Obj\fet410_1.r43 -o D:\IAR Systems\王金I\Debug\Exe\w413.d43 -rt -IC:\IAR Systems\
Embedded Workbench 3.2\430\LIB\ -f C:\IAR Systems\Embedded Workbench 3.2\430\config\lnk430F413.xcl C:\IAR Systems\Embedded Workbench 3.2\430\lib\
cl430f.r43 -e_small_write=_formatted_write -e_medium_read=_formatted_read -f C:\IAR Systems\Embedded Workbench 3.2\430\config\compactmath.xcl
IAR Universal Linker V4.56E/386
Copyright 1987-2003 IAR Systems. All rights reserved.
Error[e16]: Segment CSTART (size: 0x12 align: 0x1) is too long for segment definition. At least 0x8 more bytes needed. The problem occurred while processing the
segment placement command "-Z(CODE)CSTART=E000-FFDF", where at the moment of placement the available memory ranges were "CODE:FFD6-FFDF"
Reserved ranges relevant to this placement:
CODE:E000-FFD5 Absolute code from fet410_1
Total number of errors: 1
Total number of warnings: 0
如何解决? 答 1: 你该过,xcl文件吗?
不是代码太大,就是ram不够用吧....
fet410_1.s43
Errors: 0
Warnings: 0
Bytes: 8160
Linking
