电子产品世界 » 论坛首页 » 综合技术 » PCB与EMC » 高手帮忙看看错在哪?
高手帮忙看看错在哪?
2007-10-22 20:26:46     打赏
以下是递归型卷积编码的移位存储器部分,编译室总出现“trans_1 has multiple soueces”不知道是为什么,希望高手帮忙看看逻辑上有什么错误,谢谢!
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY juanji_1 IS
  PORT(clk:IN STD_LOGIC;
       a,se:IN STD_LOGIC;
       Uk:OUT STD_LOGIC);
END juanji_1;
ARCHITECTURE shifter OF juanji_1 IS
  SIGNAL trans_1:STD_LOGIC_VECTOR(0 TO 7);
  SIGNAL b0,seo:STD_LOGIC;
  COMPONENT dff
    PORT(d,clk:IN STD_LOGIC;
             q:OUT STD_LOGIC);
  END COMPONENT;
  COMPONENT mux2
    PORT(d0,d1,sel:IN STD_LOGIC;
               q:OUT STD_LOGIC);
  END COMPONENT;
  BEGIN
  j1:FOR i IN 0 TO 6 GENERATE
       j11:IF(i=0)GENERATE
         muxx:mux2 PORT MAP(a,b0,se,seo);
         dffx:dff PORT MAP(seo,clk,trans_1(i+1));
       END GENERATE;
       j12:IF(i+1=7)GENERATE
         dffx:dff PORT MAP(trans_1(i),clk,Uk);
       END GENERATE;
       j13:IF(i=0) AND ((i+1)/=7)GENERATE
         dffx:dff PORT MAP(trans_1(i),clk,trans_1(i+1));
       END GENERATE;
     END GENERATE;
  PROCESS(clk)
    BEGIN
      IF(se='1')THEN
        seo<=a;
        trans_1(0)<=seo;
      ELSE
        b0<=trans_1(3) XOR trans_1(7);
        seo<=b0;
        trans_1(0)<=seo;
      END IF;
      IF(clk'EVENT AND clk='1')THEN
        FOR i IN 0 TO 6 LOOP
        trans_1(i+1)<=trans_1(i);
        END LOOP;
      END IF;
      Uk<=trans_1(7);
  END PROCESS;
END shifter;
关键词: 高手     帮忙     看错     在哪     trans     LOGIC
