电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 续串口问题
共3条 1/1 1 跳转至页
续串口问题
2008-05-29 15:56:28     打赏
/*  FILE        :uart.c                                                */
/*  DATE        :Thu, May 27, 2008                                     */
/*  DESCRIPTION :uart program file.                                    */
/*  CPU GROUP   :M30290                                                */
/*  by          :liufeng                                               */
#include "sfr_M16C29config.h"
void delay(void);
void clock_initial(void);
void uarttx_initial(void);
void uartrx_initial(void);
void port_initial(void);
void main(void)
 clock_initial();
 port_initial();
 uarttx_initial();
 //uartrx_initial();
 asm("NOP");
 asm("NOP");
void clock_initial(void)     //时钟初始化配置
 unsigned char i;
    prc1 = 1;
 pm20 = 0;
 prc1 = 0;
 prc0 = 1;        //允许写时钟
 prc2 = 1;
 pacr=0x03;        //80引脚版本
 prc1 = 1;        // Enable write to PM0,PM1,PM2,TB2SC,INVC0 and INVC1 registers
 pm21 = 0;         // System clock protective bit
 cm10=0;cm05=0;
 for(i=0; i<10; i++);
 cm15=1;                                  //High drive capacity selected(cm1 bit 5)
 cm07=0;cm21=0;cm11=0;                    //Main clock selected(cm0 bit 7,cm1 bit1,cm2 bit 1)
 cm16=0;cm17=0;cm06=1;                    //CPU clock divide by 8 selected(cm0 bit 6, cm1 bit 6 and 7)
 pclk5=0;cm01=0;cm00=0;                   //CLKout pin function as normal I/O port P90(pclkr bit 5,cm0 bit 0 and 1)
 prc0 = 1;
 pclk1 = 1;         //f1SIO set
 prc0 = 0;         //写时钟保护,   系统时钟8分频
void uarttx_initial(void)      //串口发送
 unsigned int trans_data;  //发送REG
 trans_data = 0x0011;
 u0brg = 0x81;
 ucon = 0x00;
 u0c0 = 0x30;
 u0c1 = 0x00;
 u0mr = 0x05;
 u0tb = trans_data;
  u0c1 = 0x05;
 trans_data = ucon;
 trans_data = u0c0;
 trans_data = u0c1;
 trans_data = u0tb;
 trans_data = u0c1;
 clk0_u0c0=0;
 clk1_u0c0=0;
 u0brg = 0x81;
 u0mr = 0x05;
 te_u0c1=0;
 re_u0c1=0;
 clk0_u0c0=0;
 clk1_u0c0=0;
 asm("NOP");
 u0brg = 0x00;        // Setting UART0 bit rate generator (Approx 9600bps @20MHz f1)必须在U0C0后
 crd_u0c0 = 1;       //禁止CTS  RTS
 ucon = 0x01;
 u0tb = trans_data;
 u0brg = 0x81;
 te_u0c1=1;
 re_u0c1=1;
 u0brg = 0x81;
 u1brg = 0x81;
 ti_u0c1 = 0;
 while (1)
  p9_0 = 1;
  u0tb = trans_data;
  while (ti_u1c1 == 0);   //Wait for transmission buffer emty
   u0tb = trans_data;         // Set transmission data
  te_u1c1 = 1;           // Transmission enabled
  p9_0 = 0;
  trans_data++;
void uartrx_initial(void)     //串口接收
 unsigned int recevie_data;   //接收REG
 pd6_1 = 0;
 pd6_2 = 0;        //RXD direction bit
 pd6_3 = 1;        //TXD direction bit
 u0mr = 0x05;
 u0c0 = 0x00;
 u0brg = 0x81;        /* Setting UART0 bit rate generator (Approx 9600bps @20MHz f1)必须在U0C0后 */
 ucon = 0x00;
 u0c1 = 0x05;
 while (1)
  while (!ri_u0c1)
  recevie_data = u0rb;
  asm("NOP");
  asm("NOP");
void delay(void)       //p9_0 LED delay
 unsigned int j,k;
 j = 0;
 k = 0;
 for (;j<3000;j++);
 for (;k<6000;k++);
 prc2 = 1;         // Enable write to PD9,PACR and S4C registers
 pd9_0 = 1;        //P9 direction bit
 pd6_1 = 0;        // CLK direction bit
关键词: 串口     问题     initial     trans
2008-06-17 10:19:28     打赏
楼主最好将什么问题都写清楚~~这样才好解答啊~~~
2008-06-18 11:53:30     打赏
Tony,楼主的问题已经解决,请参考他的“串口问题”的帖子。
楼主的UART1的中断处理程序声明有一些不正确的地方
共3条 1/1 1 跳转至页
