#include "reg52.h"
#include "math.h"
#include "intrins.h"
typedef unsigned char uint8; /* 定义可移植的无符号8位整数关键字 */
typedef signed char int8; /* 定义可移植的有符号8位整数关键字 */
typedef unsigned int uint16; /* 定义可移植的无符号16位整数关键字 */
typedef signed int int16; /* 定义可移植的有符号16位整数关键字 */
typedef unsigned long uint32; /* 定义可移植的无符号32位整数关键字 */
typedef signed long int32; /* 定义可移植的有符号32位整数关键字
/************ vfd ************************************/
//unsigned char code disp_0[]={0x15,0x10,0x51,0x51,0x54,0x45,0x45,0x11,0x55,0x55 };
//unsigned char code disp_1[]={0x15,0x04,0x11,0x14,0x04,0x14,0x15,0x04,0x15,0x14 };
//unsigned char code disp_2[]={0x2a,0x20,0xa2,0xa2,0xa8,0x8a,0x8a,0x22,0xaa,0xaa};
//unsigned char code disp_3[]={0x2a,0x08,0x22,0x28,0x08,0x28,0x2a,0x08,0x2a,0x28 };
unsigned char code disp_0[]={0x15,0x04,0x51,0x45,0x44,0x45,0x55,0x04,0x55,0x45,0x54,0x55,0x11,0x55,0x51,0x50,0x15,0x54 };
unsigned char code disp_1[]={0x15,0x01,0x11,0x11,0x05,0x14,0x14,0x11,0x15,0x15,0x15,0x04,0x14,0x01,0x14,0x14,0x05,0x04 };
unsigned char code disp_2[]={0x2a,0x08,0xa2,0x8a,0x88,0x8a,0xaa,0x08,0xaa,0x8a,0xa8,0xaa,0x22,0xaa,0xa2,0xa0,0x2a,0xa8};
unsigned char code disp_3[]={0x2a,0x02,0x22,0x22,0x0a,0x28,0x28,0x22,0x2a,0x2a,0x2a,0x08,0x28,0x02,0x28,0x28,0x0a,0x08};
unsigned char code disp_4[]={0x2a,0x20,0xa2,0xa2,0xa8,0x8a,0x8a,0x22,0xaa,0xaa,0xaa,0x88,0x0a,0xa0,0x8a,0x8a,0x88,0x28};
unsigned char code disp_5[]={0x2a,0x08,0x22,0x28,0x08,0x28,0x2a,0x08,0x2a,0x28,0x0a,0x2a,0x22,0x2a,0x22,0x02,0x0a,0x2a};
unsigned char code disp_6[]={0x15,0x10,0x51,0x51,0x54,0x45,0x45,0x11,0x55,0x55,0x55,0x44,0x05,0x50,0x45,0x45,0x44,0x14};
unsigned char code disp_7[]={0x15,0x04,0x11,0x14,0x04,0x14,0x15,0x04,0x15,0x14,0x05,0x15,0x11,0x15,0x11,0x01,0x05,0x15};
unsigned char code disp1[]={0x01,0x57,0x18,0x50,0x46,0x60,0x20,0x55,0x00,0x40,0x04,0x22,0x29,0x12,0x28,0x2c};
uint8 bdata set1;
uint8 vfd_disp[16];
uint8 disp_a[8];
uint8 disph[3];
uint8 bdata vfd_data;
uint8 disp_count,disp_count1;
uint8 buffer_uv,buffer_liang,buffer_size,buffer_chong;
uint8 b,c;
sbit vfd_data0=vfd_data^0;
void data_write(void);
void write_task(void);
void convert(void);
void convert1(void);
void xiaoyan(void);
void xiaoyan1(void);
void rtc_xiaoyan(void);
void WDT(void);
void delay(void);
void check_uv(void);
void check_mg(void);
void check_size(void);
void func(void);
void minus(void);
void ji_count(void);
void ji_batch(void);
void jishu(void);
void anjin(void);
void jincao(void);
void xianshi(void);
void jishu(void);
void chushi(void);
void weicao(void);
void shiwei(void);
void zhijin(void);
void send_jishu(void);
void cuv(void);
void jczt(void);
void key_add(void);
void key_mg(void);
void key_uv(void);
void key_size(void);
void key_preset(void);
void key_preset_add(void);
void key_preset_dec(void);
void frist(void);
/*****************1302******************************************/
sbit sw_mg=P3^6;
sbit sw_uv=P0^7;
sbit sw_size=P0^6;
sbit sw_add=P1^4;
sbit sw_preset=P3^5;
sbit sw_fuwei=P3^5;
sbit sw_preset_add=P0^1;
sbit sw_add1=P0^1;
sbit sw_preset_dec=P0^2;
sbit sw_dec=P0^2;
sbit a_sda=P2^2;
sbit a_scl=P2^3;
sbit chong_a=P2^4;
sbit chong_b=P2^6;
sbit cheshi =P2^2;
sbit beep=P1^6;
sbit T2_PORTE=P1^2;
sbit motor_b=P1^3;
sbit motor_s=P1^5;
sbit input_c=P2^0;
sbit output_c=P2^1;
sbit count_ca=P3^0;
sbit count_cb=P3^1;
sbit da_chi=P3^2;
sbit VIO=P2^5;
sbit right_mg=P3^7;
sbit disp_clk = P1^0;
sbit disp_cs = P1^2;
sbit disp_out = P1^1;
sbit disp_clk1 = P0^4;
sbit disp_cs1 = P0^3;
sbit disp_out1 = P0^5;
uint8 bdata set;
uint8 batch1[3];
uint8 bdata count;
uint8 bdata tiao;
sbit tiao0=tiao^0;
sbit tiao1=tiao^1;
sbit tiao2=tiao^2;
sbit tiao3=tiao^3;
sbit tiao4=tiao^4;
sbit tiao5=tiao^5;
sbit tiao6=tiao^6;
sbit tiao7=tiao^7;
uint8 bdata biao;
sbit biao0=biao^0;
uint8 uv_zhi,mg_zhi,liang_zhi1,fu_zhi,jishu_zhi,chong_a_data,chong_b_data,chong_zhi,chong_zhi1,shou_zhi,shoudong;
uint8 yanshi,yanshi1,yanshi2,yanshi5;
uint8 fu_can;
uint16 fu_can1;
uint8 huan0,huan1,huan2;
uint8 dachi,huan3;
uint8 idata k,che_mapan;
uint8 uv;
uint8 ma_pan;
uint8 fu_huan;
uint8 banhuan,vfd_huan,vfd_huan1;
uint8 motor_zuan,beep_du;
uint8 weima,i,n;
uint8 set_led,set_led1,mapanl,beep_huan,motor_huan,motor_s_yanshi;
unsigned char bdata ok;
sbit data7=ok^7;
void start(void);
void stop(void);
void receive(void);
void send(void);
void read2401a(void);
void write2401a(void);
void ack(void);
void noack(void);
void delayms(void);
//at2401a寄存//
uint8 bdata huan_2401;
uint8 bdata huan1_2401;
sbit huan_2401_7=huan_2401^7;
sbit huan1_2401_7=huan1_2401^7;
uint8 bdata a_ack;
sbit ack0=a_ack^0;
uint8 m;
void chushi(void){
P2=0xff;
TMOD=0x02;
TCON=0x00;
TH0=0;
TL0=0;
TH1=0;
TL1=0;
T2CON=0;
TL2=0x00;
TH2=0Xff;
RCAP2L=0x00;
RCAP2H=0Xff; //c6
IE=0x2F;
IP=1;
TR0=1;
disp_a[0]=0;
disp_a[1]=0;
disp_a[2]=0;
disp_a[3]=0;
disp_a[4]=0;
disp_a[5]=0;
disp_a[6]=0;
beep=0;
beep_huan=0x02;
motor_huan=0x02;
motor_b=1;
motor_s=0;
EA=1;
TR2=1;
void main(void)
_nop_();
_nop_();
_nop_();
_nop_();
chushi();
while(1){
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
/*********************** VFD *********************************/
void xianshi (void)
convert();
convert1();
xiaoyan();
xiaoyan1();
// rtc_xiaoyan();
disp_cs=0;
vfd_data=0X38;
data_write();
disp_cs=1;
_nop_();
disp_cs=0;
vfd_data=0X70;
data_write();
disp_cs=1;
_nop_();
disp_cs=0;
vfd_data= 0xc0;
data_write();
_nop_();
c=9;
b=0;
while(c>0){
vfd_data= vfd_disp[b];
data_write();
b=b+1;
vfd_data=vfd_disp[b];
b=b+1;
data_write();
vfd_data=0;
data_write();
c=c-1;
disp_cs=1;
_nop_();
disp_cs=0;
vfd_data=0XBF;
data_write();
disp_cs=1;
/******************外显**************************************/
disp_cs1=0;
disp_clk1=0;
ok=weima;
ok=~ok;
for (n=0;n<8;n++){
disp_out1=data7;
disp_clk1=1;
_nop_();
_nop_();
disp_clk1=0;
ok<<=1;
ok=disph[i];
ok=~ok;
for (n=0;n<8;n++){
disp_out1=data7;
disp_clk1=1;
_nop_();
_nop_();
disp_clk1=0;
ok <<=1;
disp_cs1=1;
_nop_();
_nop_();
disp_cs1=0;
weima>>=1;
i=i+1;
if(i==3){
i=0;
weima=0x40;
void data_write (void) {
disp_out=1;
for (k=0;k<8;k++){
disp_clk=0;
disp_out=vfd_data0;
disp_clk=1;
vfd_data >>=1;
void convert(void){
//16511G1=vfdG8,16511G3=VFDG6
vfd_disp[0]=0;
vfd_disp[1]=0;
vfd_disp[2]=0;
vfd_disp[3]=0;
vfd_disp[4]=set_led;
vfd_disp[5]=0x00;
vfd_huan=disp_6[disp_a[0]];
vfd_huan1=disp_4[disp_a[1]];
vfd_disp[6]=vfd_huan|vfd_huan1;
vfd_huan=disp_7[disp_a[0]];
vfd_huan1=disp_5[disp_a[1]];
vfd_disp[7]=vfd_huan|vfd_huan1;
vfd_huan=disp_6[disp_a[2]];
vfd_huan1=disp_4[disp_a[3]];
vfd_disp[8]=vfd_huan|vfd_huan1;
vfd_huan=disp_7[disp_a[2]];
vfd_huan1=disp_5[disp_a[3]];
vfd_disp[9]=vfd_huan|vfd_huan1;
vfd_disp[10]=(motor_huan<<4)|set_led1|0x10;
vfd_disp[11]=beep_huan|(motor_huan>>4);
vfd_huan=disp_2[disp_a[6]];
vfd_disp[12]=vfd_huan;
vfd_huan=disp_3[disp_a[6]];
vfd_disp[13]=vfd_huan;
vfd_huan=disp_2[disp_a[4]];
vfd_huan1=disp_0[disp_a[5]];
vfd_disp[14]=vfd_huan|vfd_huan1;
vfd_huan=disp_3[disp_a[4]];
vfd_huan1=disp_1[disp_a[5]];
vfd_disp[15]=vfd_huan|vfd_huan1;
void convert1(void){
disph[0]=disp1[disp_a[3]];
disph[1]=disp1[disp_a[2]];
disph[2]=disp1[disp_a[1]];
void xiaoyan(void){
if(disp_a[0]==0){
vfd_disp[6]=vfd_disp[6]&0xaa;
vfd_disp[7]=vfd_disp[7]&0x2a;
if (disp_a[1]==0){
vfd_disp[6]=vfd_disp[6]&0x55;
vfd_disp[7]=vfd_disp[7]&0x15;
if (disp_a[2]==0){
vfd_disp[8]=vfd_disp[8]&0xaa;
vfd_disp[9]=vfd_disp[9]&0x2a;
if (disp_a[4]==0){
vfd_disp[14]=vfd_disp[14]&0x55;
vfd_disp[15]=vfd_disp[15]&0x15;
if (disp_a[5]==0){
vfd_disp[14]=vfd_disp[14]&0xaa;
vfd_disp[15]=vfd_disp[15]&0x2a;
void xiaoyan1(void){
if (disp_a[1]==0){
disph[2]=0xff;
if (disp_a[2]==0){
disph[1]=0xff;
void TIME2(void) interrupt 5
TF2=0;
beep=0;
motor_b=0;
motor_s=1;
disp_a[0]=disp_a[0]+1;
disp_a[1]=disp_a[1]+1;
disp_a[2]=disp_a[2]+1;
disp_a[3]=disp_a[3]+1;
disp_a[4]=disp_a[4]+1;
disp_a[5]=disp_a[5]+1;
disp_a[6]=disp_a[6]+1;
xianshi();
void ji_count(void){
batch1[3]=batch1[3]+1;
if(batch1[3]>9){
batch1[3]=0;
batch1[2]=batch1[2]+1;
if(batch1[2]>9){
batch1[2]=0;
batch1[1]=batch1[1]+1;
if(batch1[1]>9){
batch1[1]=0;
batch1[0]=batch1[0]+1;
if(batch1[0]>9){
batch1[0]=0;
if (disp_a[3]>9){
disp_a[3]=0;
if (disp_a[2]>9){
disp_a[2]=0;
if (disp_a[1]>9){
disp_a[1]=0;
if(disp_a[0]>9){
disp_a[0]=0;
