电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 有谁知道关于嵌入式qwt移植出现库文件找不到的问题怎么解决啊??
2011-10-23 23:39:32     打赏
  我的界面程序中调用了qwt库,为什么我在本地虚拟机下,用qmake 命令生成Makefile文件,然后用make命令编译,能够顺利通过编译,生成可执行文件。
但是我现在想把该界面移植到ARM板里面,我用tmake 生成Makefile 文件,然后编译,确总是报错,说找不到libqwt库,错误提示如下所示:
/usr/local/arm/3.3.2/lib/gcc-lib/arm-linux/3.3.2/../../../../arm-linux/bin/ld: skipping incompatible /usr/local/qwt-5.2.0/lib//libqwt.so when searching for -lqwt
/usr/local/arm/3.3.2/lib/gcc-lib/arm-linux/3.3.2/../../../../arm-linux/bin/ld: cannot find -lqwt
collect2: ld returned 1 exit status
make: *** [mydata_plot] 错误:
已经整了三天了,还是完全不知道怎么解决这个问题,麻烦哪位大虾帮帮忙啊!!!!
怀疑是不是Makefiel的问题,我把该文件贴出来:
# Makefile for building mydata_plot
# Generated by tmake at 16:40, 2011/04/17
#     Project: data_plot
#    Template: app
####### Compiler, tools and options
CC    =    arm-linux-gcc
CXX    =    arm-linux-g++
CFLAGS    =    -pipe -Wall -W -O2 -D_REENTRANT -DNO_DEBUG -DQT_THREAD_SUPPORT
CXXFLAGS=    -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -O2 -D_REENTRANT -DNO_DEBUG -DQT_THREAD_SUPPORT
INCPATH    =    -I/usr/local/qwt-5.2.0/include -I$(QTDIR)/include -I$(QPEDIR)/include -I/usr/lib/qt-3.3/include
LINK    =    arm-linux-g++
LFLAGS    =
LIBS    =    $(SUBLIBS) -L/usr/local/arm/3.3.2/lib -L$(QTDIR)/lib -lm -L/usr/local/qwt-5.2.0/lib/ -lqwt -lqte-mt -lpthread
MOC    =    $(QTDIR)/bin/moc
UIC    =    $(QTDIR)/bin/uic
TAR    =    tar -cf
GZIP    =    gzip -9f
####### Files
HEADERS =    data_plot.h \
        thread.h \
        mainwindow.h
SOURCES =    data_plot.cpp \
        main.cpp \
        thread.cpp \
        mainwindow.cpp
OBJECTS =    data_plot.o \
        main.o \
        thread.o \
        mainwindow.o
INTERFACES =
UICDECLS =
UICIMPLS =
SRCMOC    =    moc_data_plot.cpp \
        moc_mainwindow.cpp
OBJMOC    =    moc_data_plot.o \
        moc_mainwindow.o
DIST    =
TARGET    =    mydata_plot
INTERFACE_DECL_PATH = .
####### Implicit rules
.SUFFIXES: .cpp .cxx .cc .C .c
.cpp.o:
    $(CXX) -c $(CXXFLAGS) $(INCPATH) -o $@ $<
.cxx.o:
.cc.o:
.C.o:
.c.o:
    $(CC) -c $(CFLAGS) $(INCPATH) -o $@ $<
####### Build rules
all: $(TARGET)
$(TARGET): $(UICDECLS) $(OBJECTS) $(OBJMOC)
    $(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJMOC) $(LIBS)
moc: $(SRCMOC)
tmake: Makefile
Makefile: data_plot.pro
    tmake data_plot.pro -o Makefile
dist:
    $(TAR) data_plot.tar data_plot.pro $(SOURCES) $(HEADERS) $(INTERFACES) $(DIST)
    $(GZIP) data_plot.tar
clean:
    -rm -f $(OBJECTS) $(OBJMOC) $(SRCMOC) $(UICIMPLS) $(UICDECLS) $(TARGET)
    -rm -f *~ core
####### Sub-libraries
###### Combined headers
####### Compile
data_plot.o: data_plot.cpp \
        data_plot.h
main.o: main.cpp \
        mainwindow.h \
        thread.h \
        data_plot.h
thread.o: thread.cpp \
        thread.h
mainwindow.o: mainwindow.cpp \
        mainwindow.h \
        thread.h \
        data_plot.h
moc_data_plot.o: moc_data_plot.cpp \
        data_plot.h
moc_mainwindow.o: moc_mainwindow.cpp \
        mainwindow.h \
        thread.h \
        data_plot.h
moc_data_plot.cpp: data_plot.h
    $(MOC) data_plot.h -o moc_data_plot.cpp
moc_mainwindow.cpp: mainwindow.h
    $(MOC) mainwindow.h -o moc_mainwindow.cpp
我设置环境变量的脚本文件:
#!/bin/bash
export QTDIR=/home/build_qte/qt-2.3.7
export QPEDIR=/home/build_qte/qtopia-free-1.7.0
export LD_LIBRARY_PATH=$QTDIR/lib:$QPEDIR/lib:/usr/local/qwt-5.2.0/lib: $LD_LIBRARY_PATH
export TMAKEDIR=/home/build_qte/tmake-1.11
export TMAKEPATH=$TMAKEDIR/lib/qws/linux-arm-g++
export PATH=$QTDIR/bin:$TMAKEDIR/bin:/usr/local/arm/3.3.2/bin:$QPEDIR/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/qwt-5.2.0/lib:$LD_LIBRARY_PATH
关键词: 知道     关于     嵌入式     移植     出现     文件     不到     问题
