电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Implementing Nonvolatile, Nonresettable
Implementing Nonvolatile, Nonresettable Counters for Embedded Systems
2012-04-04 11:53:48     打赏
关键词: digital counter, nonvolatile, nonresettable, NV, EPROM emulation mode, EEPROM, EPROM, eeprom, eprom
Abstract: For warranty reasons it is desirable to count certain events such as power cycles, operating time, hard (pushbutton) resets, and timeouts. Although digital counters are easy to build, it is not that obvious how to make them nonvolatile and nonresettable. This article explains how to use the EPROM-emulation mode of readily available serial EEPROMs together with an unusual coding scheme to solve the problem.
  Implementing Nonvolatile, Nonresettable Counters for Embedded Systems.pdf
关键词: Implementing     Nonvolatile
