电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Determining the Mission Parameters for T
Determining the Mission Parameters for Temperature Logger iButton® Devices
2012-04-08 12:50:51     打赏
Determining the Mission Parameters for Temperature LoggeriButton® Devices
关键词: temp logger, ibutton, sample rate, rollover, start delay, alarm
Abstract: For many first-time users, setting up a temperature logger for a mission can be a challenging task. This application note explains technical terms common with temperature logger iButtons. Additionally, it presents an algorithm that helps users choose the necessary input parameters, including the appropriate sample rate.
 Determining the Mission Parameters for Temperature Logger iButton® Devices.pdf
关键词: Determining     Mission     Param
