电子产品世界 » 论坛首页 » 企业专区 » TI » 【技术应用】优化数字电机控制程序库
【技术应用】优化数字电机控制程序库
2012-04-11 18:38:26     打赏
摘要:
The DMC library contains a collection of component modules and system implementations, which are intended for evaluation, accelerated design, and development of motor control firmware.
The software is intended to meet these goals, and no optimization is performed.
As system designers implement systems, they must optimize their systems for performance in terms of memory consumption and CPU cycles spent to achieve the given task.
This application report reviews several optimizations to the DMC library code to achieve this objective and provides references to other resources to further optimize available code.
文档:spraak2.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=spraak2
关键词: 技术应用     优化     数字     电机     控制     程序
