电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Bench Characterization of ADCs Using a L
Bench Characterization of ADCs Using a Low-Cost PC-Based Data-Acquisition Board
2012-04-12 18:16:43     打赏
关键词: ADC, characterization, INL, DNL, gain, offset, channel coupling and matching, National Intruments, NI, Labview, PC, DAQ, analog to digital converters
Abstract: This application note describes techniques of using a PC based Digital I/O Board to characterize analog-to-digital converters (ADCs). It will look at static DC parameters such as integral nonlinearity (INL), differential nonlinearity (DNL), gain, and offset errors, but also noise, internal reference voltage, and channel-to-channel coupling and matching, as well as the supply voltage dependence.
 Bench Characterization of ADCs Using a Low-Cost PC-Based Data-Acquisition Board.pdf
关键词: Bench     Characterization     Us
