电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Regenerating the DS1847/DS1848 Resistor
Regenerating the DS1847/DS1848 Resistor Calibration Constants
2012-04-14 19:27:07     打赏
关键词: digital resistor, digital pot, digital potentiometer, digipot, DS1847, DS1848, potentiometers
Abstract: The purpose of this application note is to show how the DS1847/48 digital resistor calibration constants can be regenerated. This application note assumes that the reader is familiar with the Programming the Lookup Table section of the DS1847 or DS1848 data sheets. This application note will describe the measurements required, as well as show the calculations needed to regenerate the calibration constants. Last of all, this application note will show an example spreadsheet calculator (a link to it can be found at the end of this application note) that can be used to perform the calculations once several measurements are input
 Regenerating the DS1847 DS1848 Resistor Calibration Constants.pdf
关键词: Regenerating     DS1847     DS184
