电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Low Power Silicon BJT LNA for 1.9GHz
2012-04-17 12:36:38     打赏
关键词: Maxim, QuickChip, silicon bipolar, LNA, 1.9 GHz, QuickChip 9, semi-custom, ASIC, low noise amplifier, quick chip
Abstract: A two-stage 1.9GHz monolithic low-noise amplifier (LNA) with a measured noise figure of 2.3dB and an associated gain of 15dB was fabricated in a standard silicon bipolar transistor array. It dissipates 5.2mW from a 3V supply including the bias circuitry. Input return loss and isolation are -9dB and -20dB, respectively.
 Low Power Silicon BJT LNA for 1.9GHz.pdf
关键词: Power     Silicon     1.9GHz
