电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Rail-to-Rail: Railroading and the Electr
Rail-to-Rail: Railroading and the Electronics of Op Amps
2012-04-19 12:43:16     打赏
关键词: rail to rail, op amps, input, output, signal swings, beyond the rails, MOS, bi-polar, CMOS, P input pair, N common-mode, supply bias, current changes, sign magnitude, crossover, distortion, NPN, PNP, impedance, match phase, reversal, latch up, overdrive
Abstract: Railroads have had rail-to-rail components for years that were, in fact, nearly rail to rail. Op amps employ the same nearly rail-to-rail tradition. This application note discusses rail-to-rail op amps, and explains why some inputs and outputs can be less than, nearly, or slightly more than the power rails.
Rail-to-Rail:Railroading and the Electronics of Op Amps.pdf
关键词: Rail-to-Rail     Railroading
