关键词: lithium-battery chargers, charge-termination voltage, fast charge, dual op amp
Abstract: By adding a dual op amp and some other components to a lithium-battery-charger IC, you can adjust the charging voltage to any level within the range for standard lithium batteries (3.6V to 4.2V).
Charging Lithium Batteries with a Nonstandard Termination Voltage.pdf
