虽然一直在学习ARM9,但是很多问题还是没明白,希望大家多多指点。
1,开发板从nor flash 启动,在串口界面上接着就会出现如下内容,请问这段程序是bootloader还是u-boot?
两者经常弄混了。
EmbedSky BIOS for SKY2440/TQ2440 #####
Press Space key to Download Mode !
##### Boot for Nor Flash Main Menu #####
##### EmbedSky USB download mode #####
[1] Download u-boot or STEPLDR.nb1 or other bootloader to Nand Flash
[2] Download Eboot (eboot.nb0) to Nand Flash
[3] Download Linux Kernel (zImage.bin) to Nand Flash
[5] Download CRAMFS image to Nand Flash
[6] Download YAFFS image (root.bin) to Nand Flash
[7] Download Program (uCOS-II or TQ2440_Test) to SDRAM and Run it
[8] Boot the system
[9] Format the Nand Flash
[0] Set the boot parameters
[a] Download User Program (eg: uCOS-II or TQ2440_Test)
[b] Download LOGO Picture (.bin) to Nand Flash
[l] Set LCD Parameters
[n] Enter TFTP download mode menu
[o] Download u-boot to Nor Flash
[r] Reboot u-boot
[t] Test Linux Image (zImage)
[q] quit from menu
Enter your selection:
2,以测试摄像头的实验为例,如果修改完屏幕的分辨率,利用上面的USB下载模式下载到开发板中是不是屏幕的分辨率就可以得到改善了?还是说linux的内核也需要修改?
希望各位老师帮帮忙,谢谢了!
