电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » stm32 DAC
stm32 DAC
2014-09-28 19:35:35     打赏
DMA+TIM+DAC方式实现
//DAC通道1的12位右对齐数据保持寄存器
#define DAC_DHR12R1_Address      0x40007408
//生成一个360点的正弦表
u16 Sine_Const[360];
for(i = 0;i < 360;i++)
  Sine_Const[i] = 2047+((sin(i*3.1415926/180))*2047);
//相关时钟配置
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
//定时器相关配置
void TIM_Configuration(void)
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = 0x5;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
  TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
  TIM_Cmd(TIM6, ENABLE);
//DAC相关配置
void DAC_Configuration(void)
  DAC_InitTypeDef DAC_InitStructure;
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
  DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  DAC_Cmd(DAC_Channel_1, ENABLE
//DMA相关配置
void DMA_Configuration(void)
  DMA_DeInit(DMA2_Channel3);
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R1_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&Sine_Const;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;  //外设作为数据传输的目的地
  DMA_InitStructure.DMA_BufferSize = 360;   //dma缓存大小
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;    //内存地址寄存器 递增
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //外设数据宽度
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;  //工作在循环缓存模式,数据传输数目为0时,自动恢复配置初值
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //通道未被设置成内存到内存模式,与循环模式相对
  DMA_Init(DMA2_Channel3, &DMA_InitStructure); //将DMA_InitStructure中指定的参数初始化dma的通道寄存器
  DMA_Cmd(DMA2_Channel3, ENABLE);  //使能通道
  DAC_DMACmd(DAC_Channel_1, ENABLE);
