电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 39R16A3/39R08A3 头文件
39R16A3/39R08A3 头文件
2014-09-28 20:19:35     打赏
// Header file for SM39R16A3/OB39R16A3, SM39R08A3/OB39R08A3 microcontroller.
// FOSVOS MCU
 #ifndef                __SM39R16A3_H__
 #define                __SM39R16A3_H__
 /*  BYTE Registers  */
 sfr        P0        = 0x80;
 sfr        P1        = 0x90;
 sfr        P3        = 0xB0;
 sfr        PSW        = 0xD0;
 sfr        ACC        = 0xE0;
 sfr        B        = 0xF0;
 sfr        SP        = 0x81;
 sfr        DPL        = 0x82;
 sfr        DPH        = 0x83;
 sfr        PCON        = 0x87;        /*        SMOD,X,X,X,X,X,STOP,IDLE  */
 sfr        TCON        = 0x88;
 sfr        TMOD         = 0x89;
 sfr        TL0        = 0x8A;
 sfr        TL1        = 0x8B;
 sfr        TH0        = 0x8C;
 sfr        TH1        = 0x8D;
 sfr CKCON        = 0x8E;
 sfr        SCON        = 0x98;
 sfr        SBUF        = 0x99;
 sfr        IE        = 0x0A8; /*        Separate IEN0&IEN1        */
 sfr        IP        = 0x0A9; /*        Separate IP0&IP1        */
 /*  Dual DPTR control register */
 sfr        DPL1        = 0x84;
 sfr        DPH1        = 0x85;
 sfr        AUX        = 0x91;        /*BRS,x,x,x,x,DPS */
 /*ISP SFR */
 sfr        IFCON        = 0x8F;        /*X,CDPR,X,X,X,X,X,ISPE*/
 sfr        TAKEY        = 0xF7;
 sfr        ISPFAH        = 0xE1;
 sfr        ISPFAL        = 0xE2;
 sfr        ISPFD        = 0xE3;
 sfr         ISPFC        = 0xE4;
 /*        Enhance UART control register        */
 sfr        S0CON        = 0x98;
 sfr        S0BUF        = 0x99;
 sfr        S0RELL        = 0xAA;
 sfr        S0RELH        = 0xBA;
 sfr        SRELL        = 0xAA;
 sfr        SRELH        = 0xBA;
 sfr        PFCON        = 0xD9;
 /*        Enhance Interrupt control register */
 sfr        IEN2        = 0x9A;
 sfr        IEN0        = 0xA8;
 sfr        IEN1        = 0xB8;
 sfr        IP0        = 0xA9;
 sfr        IP1        = 0xB9;
 sfr        IRCON        = 0xC0;
 /*          KBI  */
 sfr         KBLS        = 0x93;
 sfr         KBE        = 0x94;
 sfr         KBF        = 0x95;
 sfr         KBD        = 0x96;
 /*        IRCON2        */
 sfr        IRCON2        = 0x97;
 /*        Reset rule        */
 sfr        RSTS        = 0xA1;
 sfr        LVC        = 0x0E6; /*        LVI_EN,X,LVRXE,X,X,X,X,X  */
 sfr        SWRES        = 0x0E7;
 /*        ADC        */
 sfr        ADCC1        = 0xAB;
 sfr        ADCC2        = 0xAC;
 sfr        ADCDH        = 0xAD;
 sfr        ADCDL        = 0xAE;
 sfr        ADCCS        = 0xAF;
 /*        PWM        */
 sfr        PWMC        = 0x0B5;
 sfr        PWMD0H        = 0x0BC;
 sfr        PWMD0L        = 0x0BD;
 sfr        PWMD1H        = 0x0BE;
 sfr        PWMD1L        = 0x0BF;
 sfr        PWMD2H        = 0x0B1;
 sfr        PWMD2L        = 0x0B2;
 sfr        PWMD3H        = 0x0B3;
 sfr        PWMD3L        = 0x0B4;
 sfr        PWMMDH        = 0x0CE;
 sfr        PWMMDL        = 0x0CF;
 /*        WDT        */
 sfr        WDTC        = 0xB6;
 sfr        WDTK        = 0xB7;
 /*  Timer2 Compare/Capture control register  */
 sfr         CCEN        = 0x0C1;
 sfr         CCEN2        = 0x0D1;
 sfr         CCL1        = 0x0C2;
 sfr         CCH1        = 0x0C3;
 sfr         CCL2        = 0x0C4;
 sfr         CCH2        = 0x0C5;
 sfr         CCL3        = 0x0C6;
 sfr         CCH3        = 0x0C7;
 sfr        T2CON        = 0X0C8;
 sfr         CCCON        = 0x0C9;
 sfr         CRCL        = 0x0CA;
 sfr         CRCH        = 0x0CB;
 sfr        TL2        = 0x0CC;
 sfr        TH2        = 0x0CD;
 sfr16         CC1        = 0xC2;
 sfr16         CC2        = 0xC4;
 sfr16         CC3        = 0xC6;
 sfr16         CRC        = 0xCA;
 sfr16         T2        = 0xCC;        // TH2 | TL2
 /*        GPIO mode control register */
 sfr        P0M0        = 0x0D2;
 sfr        P0M1        = 0x0D3;
 sfr        P1M0        = 0x0D4;
 sfr        P1M1        = 0x0D5;
 sfr        P3M0        = 0x0DA;
 sfr        P3M1        = 0x0DB;
 /*        SPI        */
 sfr        SPIC1        = 0x0F1;
 sfr        SPIC2        = 0x0F2;
 sfr        SPITXD        = 0x0F3;
 sfr        SPIRXD        = 0x0F4;
 sfr        SPIS        = 0x0F5;
 /*        IIC        */
 sfr        IICS        = 0x0F8;
 sfr        IICCTL        = 0x0F9;
 sfr        IICA1        = 0x0FA;
 sfr        IICA2        = 0x0FB;
 sfr        IICRWD        = 0x0FC;
 sfr        IICEBT        = 0x0FD;
 /*        Comparator        */
 sfr        OpPin        = 0x0F6;
 sfr        Cmp0CON        = 0x0FE;
 sfr        Cmp1CON        = 0x0FF;
 /*  BIT Registers  */
 sbit P0_0        = 0x80;
 sbit P0_1        = 0x81;
 sbit P0_2        = 0x82;
 sbit P0_3        = 0x83;
 sbit P0_4        = 0x84;
 sbit P0_5        = 0x85;
 sbit P0_6        = 0x86;
 sbit P0_7        = 0x87;
 sbit P1_0        = 0x90;
 sbit P1_1        = 0x91;
 sbit P1_2        = 0x92;
 sbit P1_3        = 0x93;
 sbit P1_4        = 0x94;
 sbit P1_5        = 0x95;
 sbit P1_6        = 0x96;
 sbit P1_7        = 0x97;
 sbit P3_0        = 0x0B0;
 sbit P3_1        = 0x0B1;
 /*  PSW  */
 sbit CY                = PSW^7;
 sbit AC                = PSW^6;
 sbit F0                = PSW^5;
 sbit RS1        = PSW^4;
 sbit RS0        = PSW^3;
 sbit OV                = PSW^2;
 sbit P                = PSW^0; //8052 only
 /*  TCON  */
 sbit TF1         = TCON^7;
 sbit TR1         = TCON^6;
 sbit TF0         = TCON^5;
 sbit TR0         = TCON^4;
 sbit IE1         = TCON^3;
 sbit IT1         = TCON^2;
 sbit IE0         = TCON^1;
 sbit IT0         = TCON^0;
 /*  IE  */
 sbit EA                = IE^7;
 sbit ET2        = IE^5;
 sbit ES                = IE^4;
 sbit ET1        = IE^3;
 sbit EX1        = IE^2;
 sbit ET0        = IE^1;
 sbit EX0        = IE^0;
 /*  P3  */
 sbit T1                = P3^5;
 sbit T0            = P3^4;
 sbit INT1          = P3^3;
 sbit INT0          = P3^2;
 sbit TXD           = P3^1;
 sbit RXD           = P3^0;
 /*  S0CON  */
 sbit SM0           = S0CON^7;
 sbit SM1           = S0CON^6;
 sbit SM2           = S0CON^5;
 sbit REN           = S0CON^4;
 sbit TB8           = S0CON^3;
 sbit RB8           = S0CON^2;
 sbit TI            = S0CON^1;
 sbit RI            = S0CON^0;
 /*        IICS        */
 sbit MPIF        = IICS^6;
 sbit LAIF        = IICS^5;
 sbit RXIF        = IICS^4;
 sbit TXIF        = IICS^3;
 sbit RXAK        = IICS^2;
 sbit TXAK        = IICS^1;
 sbit RW                = IICS^0;
 sbit BB                = IICS^0;
 /*        IRCON        */
 sbit EXF2        = IRCON^7;
 sbit TF2        = IRCON^6;
 sbit IICIF        = IRCON^5;
 sbit LVIIF        = IRCON^4;
 sbit KBIIF        = IRCON^3;
 sbit ADCIF        = IRCON^2;
 sbit SPIIF        = IRCON^1;
 sbit PWMIF        = IRCON^0;
 /*        IEN1        */
 sbit EXEN2        = IEN1^7;
 sbit IEIIC        = IEN1^5;
 sbit IELVI        = IEN1^4;
 sbit IEKBI        = IEN1^3;
 sbit IEADC        = IEN1^2;
 sbit IESPI        = IEN1^1;
 sbit IEPWM        = IEN1^0;
 /*        Interrupt Define        */
 #define        d_INT0_Vector                0        // 0003h
 #define        d_T0_Vector                1        // 000Bh
 #define        d_INT1_Vector                2        // 0013h
 #define        d_T1_Vector                3        // 001Bh
 #define        d_UART0_Vector                4        // 0023h
 #define        d_T2_Vector                5        // 002Bh
 #define        d_PWM_Vector                8        // 0043h
 #define        d_SPI_Vector                9        // 004Bh
 #define        d_ADC_Vector                10        // 0053h
 #define        d_KBI_Vector                11        // 005Bh
 #define        d_LVI_Vector                12        // 0063h
 #define        d_IIC_Vector                13        // 006Bh
 #define        d_WDT_Vector                17        // 008Bh
 #define        d_Comparator_Vector        18        // 0093h
 // SyncMos/On-Bright MCU   FOSVOS
 // 021-58998693
 // www.fosvos.com
 #endif
