//Header file for SM39R08A5/OB39R08A5 microcontroller. //FOSVOS MCU #ifndef __39R08A5_H__ #define __39R08A5_H__ /* BYTE Registers */ sfr P3 = 0xB0; sfr PSW = 0xD0; sfr ACC = 0xE0; sfr B = 0xF0; sfr SP = 0x81; sfr DPL = 0x82; sfr DPH = 0x83; sfr PCON = 0x87; /* SMOD,X,X,X,X,X,STOP,IDLE */ sfr TCON = 0x88; sfr TMOD = 0x89; sfr TL0 = 0x8A; sfr TL1 = 0x8B; sfr TH0 = 0x8C; sfr TH1 = 0x8D; sfr CKCON = 0x8E; sfr SCON = 0x98; sfr SBUF = 0x99; sfr IE = 0xA8; sfr IP = 0xA9; /* Dual DPTR control register */ sfr DPL1 = 0x84; sfr DPH1 = 0x85; sfr AUX = 0x91; /*BRS,x,x,PTS [1:0],PINTS[1:0],DPS */ /*ISP SFR */ sfr IFCON = 0x8F; /*X,CDPR,X,X,X,X,X,ISPE*/ sfr TAKEY = 0xF7; sfr ISPFAH = 0xE1; sfr ISPFAL = 0xE2; sfr ISPFD = 0xE3; sfr ISPFC = 0xE4; /* Enhance UART control register */ sfr S0CON = 0x98; sfr S0BUF = 0x99; sfr S0RELL = 0xAA; sfr S0RELH = 0xBA; sfr SRELL = 0xAA; sfr SRELH = 0xBA; /* Enhance Interrupt control register */ sfr IEN2 = 0x9A; sfr IEN0 = 0xA8; sfr IEN1 = 0xB8; sfr IP0 = 0xA9; sfr IP1 = 0xB9; sfr IRCON = 0xC0; /* IRCON2 */ sfr IRCON2 = 0x97; /* Reset rule */ sfr RSTS = 0xA1; sfr LVC = 0xE6; /* LVI_EN,X,LVRXE,X,X,X,X,X */ sfr SWRES = 0xE7; /* ADC */ sfr ADCC1 = 0xAB; sfr ADCC2 = 0xAC; sfr ADCDH = 0xAD; sfr ADCDL = 0xAE; sfr ADCCS = 0xAF; /* PWM */ sfr PWMC = 0xB5; sfr PWMD0H = 0xBC; sfr PWMD0L = 0xBD; sfr PWMD1H = 0xBE; sfr PWMD1L = 0xBF; sfr PWMD2H = 0xB1; sfr PWMD2L = 0xB2; sfr PWMD3H = 0xB3; sfr PWMD3L = 0xB4; sfr PWMMDH = 0xCE; sfr PWMMDL = 0xCF; /* WDT */ sfr WDTC = 0xB6; sfr WDTK = 0xB7; /* GPIO mode control register */ sfr P3M0 = 0xDA; sfr P3M1 = 0xDB; /* IIC */ sfr IICS = 0xF8; sfr IICCTL = 0xF9; sfr IICA1 = 0xFA; sfr IICA2 = 0xFB; sfr IICRWD = 0xFC; sfr IICEBT = 0xFD; /*Comparator */ sfr OPPIN = 0xF6; sfr CMP0CON = 0xFE; sfr OpPin = 0xF6; sfr Cmp0CON = 0xFE; /* BIT Registers */ sbit P3_0 = 0xB0; sbit P3_1 = 0xB1; sbit P3_2 = 0xB2; sbit P3_3 = 0xB3; sbit P3_4 = 0xB4; sbit P3_5 = 0xB5; sbit P3_6 = 0xB6; sbit P3_7 = 0xB7; /* PSW */ sbit CY = PSW^7; sbit AC = PSW^6; sbit F0 = PSW^5; sbit RS1 = PSW^4; sbit RS0 = PSW^3; sbit OV = PSW^2; sbit P = PSW^0; //8052 only /* TCON */ sbit TF1 = TCON^7; sbit TR1 = TCON^6; sbit TF0 = TCON^5; sbit TR0 = TCON^4; sbit IE1 = TCON^3; sbit IT1 = TCON^2; sbit IE0 = TCON^1; sbit IT0 = TCON^0; /* IE */ sbit EA = IE^7; sbit ET2 = IE^5; sbit ES = IE^4; sbit ET1 = IE^3; sbit EX1 = IE^2; sbit ET0 = IE^1; sbit EX0 = IE^0; /* P3 */ sbit T1 = P3^5; sbit T0 = P3^4; sbit INT1 = P3^3; sbit INT0 = P3^2; sbit TXD = P3^1; sbit RXD = P3^0; /* S0CON */ sbit SM0 = S0CON^7; sbit SM1 = S0CON^6; sbit SM2 = S0CON^5; sbit REN = S0CON^4; sbit TB8 = S0CON^3; sbit RB8 = S0CON^2; sbit TI = S0CON^1; sbit RI = S0CON^0; /* IICS */ sbit MPIF = IICS^6; sbit LAIF = IICS^5; sbit RXIF = IICS^4; sbit TXIF = IICS^3; sbit RXAK = IICS^2; sbit TXAK = IICS^1; sbit RW = IICS^0; sbit BB = IICS^0; /* IRCON */ sbit IICIF = IRCON^5; sbit LVIIF = IRCON^4; sbit ADCIF = IRCON^2; sbit PWMIF = IRCON^0; /* IEN1 */ sbit IEIIC = IEN1^5; sbit IELVI = IEN1^4; sbit IEADC = IEN1^2; sbit IEPWM = IEN1^0; /* Interrupt Define */ #define d_INT0_Vector 0 // 0003h #define d_T0_Vector 1 // 000Bh #define d_INT1_Vector 2 // 0013h #define d_T1_Vector 3 // 001Bh #define d_UART0_Vector 4 // 0023h #define d_PWM_Vector 8 // 0043h #define d_ADC_Vector 10 // 0053h #define d_LVI_Vector 12 // 0063h #define d_IIC_Vector 13 // 006Bh #define d_Comparator_Vector 18 // 0093h /*-------------------------------------------------------------------------- //===================================================================== // SyncMos/On-Bright MCU FOSVOS 08A5 // 021-58998693 // www.fosvos.com //==================================================================== /*-------------------------------------------------------------------------- Header file for SM39R08A5/OB39R08A5 microcontroller. -------------------------------------------------------------------------*/ #endif
