可能是习惯了12864这样的液晶,结果在硬件连接上就出来了一个重大错误,结果弄了好久也只显示条形点阵,而且对比度很差。这个错误就是240128液晶的对比度调节电位器,两端一端接地,另一端接VOUT(22脚)!而我习惯性的接到了5V!在曹老师的提醒下才发现了这个问题,在手册的角落里发现了硬件连接图:
调试效果图:
最后附上调试好的程序:
"日暮乡关何处是,烟波江上使人愁"}
uchar code tab2[]={ " " " " " " " " " "};
uchar code tab3[]={ /*-- 调入了一幅图像:C:\Users\Administrator\Desktop\240128 tuzki.bmp --*/ /*-- 宽度x高度=240x128 --*/ 0x00,0x38,0x00,0x00,0xFB,0xFC,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38, 0x00,0x01,0xFF,0xFE,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2E,0x00,0x01, 0x3F,0xFF,0x60,0x1A,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF, 0xA0,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x8F,0xC0,0x07, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x1F,0xF0,0x00,0x00,0x00,0x01,0x10,0x00,0x00,0x0F,0xB3,0xE8,0x07,0xE0,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F, 0xF0,0x04,0x00,0x00,0x1F,0x3C,0x00,0x00,0x0F,0x03,0xEC,0x00,0x78,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0xFF,0xF8,0x0F, 0x08,0x00,0x08,0x06,0x00,0x00,0x0F,0x01,0xF4,0x00,0x78,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x00,0x1D,0xFF,0xF8,0x07,0x03,0xFF, 0x17,0xF8,0x00,0x00,0x0F,0x80,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0xC1,0x00,0x00,0x00,0x00,0x03,0xFC,0xF8,0x00,0x1F,0xFF,0x0F,0xFF, 0x40,0x00,0x0F,0xB0,0xF8,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x28, 0x1E,0x7E,0xE2,0x00,0x00,0x00,0x0F,0xFA,0xFA,0x05,0x3F,0xFF,0x0F,0xFF,0xDC,0x00, 0x0F,0xB0,0xF8,0x1D,0xC1,0x90,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF, 0x60,0x00,0x00,0x00,0x1F,0xF6,0xFA,0x07,0xFF,0xFF,0x1F,0xFF,0xFC,0x00,0x07,0xD0, 0x7C,0x0F,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFB,0xFF,0xB0,0x00, 0x00,0x00,0x1F,0xEE,0xF8,0x05,0xFF,0xC7,0x1F,0xFF,0xF8,0x00,0x07,0xD1,0x7F,0xFF, 0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0x80,0x00,0x00,0x00, 0x1F,0xDD,0xF0,0x0B,0xFC,0x19,0x1F,0x8F,0xF9,0x80,0x07,0xDE,0x7F,0xFF,0xFF,0xFF, 0xFC,0x1E,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xC0,0x00,0x00,0x00,0xBF,0xA1, 0xF0,0x77,0xFE,0x19,0x1F,0x1B,0xFE,0xC0,0x0B,0xE1,0xFF,0xFF,0xFF,0xFF,0xFF,0xC6, 0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xC0,0x00,0x00,0x00,0xBF,0xE1,0xF4,0x6F, 0xF6,0x19,0x1F,0x3F,0xFF,0x00,0x0B,0xEF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00, 0x00,0x00,0x00,0x7F,0xFF,0xFF,0xC0,0x00,0x00,0x00,0x3F,0xC3,0xF4,0x0F,0xF8,0x1B, 0x1F,0x33,0x7F,0x98,0x0D,0xFF,0xFF,0xFF,0x00,0x07,0xFF,0xFE,0x7C,0x00,0x00,0x00, 0x00,0x7F,0xFF,0xFF,0xC0,0x06,0xA0,0x0F,0xFE,0xF7,0xE8,0x9F,0xA1,0x97,0x0F,0xB0, 0x1F,0xD8,0x61,0xFF,0xFE,0x00,0x00,0x00,0x0F,0xFF,0x98,0x00,0x00,0x00,0x00,0x7F, 0xFF,0xFF,0xD0,0x07,0x03,0xFF,0xFC,0x27,0xC0,0xBF,0x00,0xC7,0x0F,0xA0,0x2F,0xE8, 0x8F,0xFF,0xE0,0x00,0x00,0x00,0x11,0xFF,0xEC,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF, 0xC0,0x00,0x3F,0xFF,0xFE,0x1F,0xFC,0x7E,0x80,0xCF,0x07,0xC0,0x37,0xF0,0x3F,0xFE, 0x0C,0x00,0x00,0x00,0x0E,0x3F,0xF0,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xA0,0x01, 0xFF,0xFF,0xFE,0x1F,0xFF,0xFD,0x84,0x1F,0x1F,0xE4,0x13,0xFC,0xFF,0xF0,0x80,0x00, 0x00,0x00,0x00,0x0F,0xFB,0xC0,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xA2,0x8F,0xFF,0xFF, 0x04,0x3F,0xFF,0xF9,0x0E,0x3F,0x0B,0xF2,0x04,0xF9,0xFF,0x80,0x00,0x00,0x00,0x00, 0x00,0x03,0xFD,0x80,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xE2,0x3F,0xFF,0x80,0x00,0x21, 0xFF,0xF8,0x0C,0xFF,0x1D,0xFC,0x07,0x7F,0xFE,0x70,0x00,0x00,0x00,0x00,0x00,0x04, 0xFE,0xC0,0x00,0x00,0x00,0x5F,0xFF,0xFF,0x60,0xFF,0xF0,0x30,0x00,0x20,0x0F,0xF0, 0x09,0xFF,0x0C,0xFE,0x67,0x3F,0xF8,0xE0,0x00,0x00,0x00,0x00,0x00,0x06,0x7F,0x58, 0x00,0x00,0x00,0x6F,0xFF,0xFE,0xF3,0xFF,0x80,0x00,0x00,0x01,0x81,0xE8,0x23,0xFE, 0x08,0x7F,0x3F,0x9F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x3F,0xB8,0x00,0x00, 0x00,0x67,0xFF,0xFD,0xC7,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0xCF,0xFC,0x01,0xBF, 0xCF,0x3F,0xD8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5F,0xB8,0x00,0x00,0x00,0x03, 0xFF,0xFB,0x9F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFA,0x01,0xDF,0xF2,0x7F, 0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6F,0xC8,0x00,0x00,0x00,0x05,0xFF,0xF7, 0x3F,0xC4,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xE7,0x01,0xE7,0xFC,0xFE,0x60,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x17,0xE8,0x00,0x00,0x00,0x06,0xFF,0xEE,0x7F,0x30, 0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xCF,0x00,0x01,0xFF,0xFD,0x80,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x1B,0xF8,0x00,0x00,0x00,0x00,0x3F,0x9D,0xFC,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0xFF,0xF3,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x09,0xF0,0x00,0x00,0x00,0x00,0xCF,0x2B,0xF8,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x7F,0x20,0x00,0x03,0x3F,0xE7,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x05,0xF8,0x00,0x00,0x00,0x00,0xE0,0xC7,0xF6,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x3F,0x88,0x00,0x01,0x8F,0xCE,0x00,0x00,0x03,0x00,0x00,0x00,0x04,0x31,0xE4,0xFB, 0x00,0x00,0x00,0x00,0x19,0x97,0xE4,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9F,0xDE, 0x00,0x00,0x2F,0xD0,0x00,0x00,0x01,0xFF,0xFF,0xFF,0x04,0x3C,0x02,0xFD,0x00,0x00, 0x00,0x00,0x00,0x0F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xEE,0x00,0x00, 0x5F,0xB8,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFE,0x2F,0xF0,0x7D,0x80,0x00,0x00,0x00, 0x00,0x1F,0xA0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xF6,0x00,0x00,0x3F,0x38, 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFA,0x2F,0xFF,0xFD,0x80,0x00,0x00,0x00,0x00,0x3F, 0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0B,0xFA,0x00,0x00,0x3E,0xC0,0x00,0x00, 0x01,0xFF,0xFF,0xFF,0xFA,0x0F,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0xBE,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x0D,0xFE,0x00,0x00,0x3E,0xC0,0x00,0x00,0x03,0xFF, 0xFF,0xFF,0xFE,0x0F,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x0C,0xFC,0x00,0x00,0x7C,0xC0,0x00,0x00,0x03,0xC0,0x00,0x00, 0x06,0x11,0xFF,0xBE,0x00,0x00,0x00,0x00,0x01,0x7C,0x00,0x00,0x00,0x07,0xFF,0x80, 0x00,0x00,0x1E,0xFE,0x00,0x01,0x7C,0x80,0x00,0x00,0x01,0x00,0x00,0x00,0x0C,0x30, 0x00,0x3E,0x00,0x00,0x00,0x00,0x00,0xFD,0xF8,0x00,0xD8,0xEF,0xFF,0xFF,0x83,0x00, 0x0D,0x7E,0x00,0x02,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x3E, 0x00,0x00,0x00,0x00,0x00,0xF9,0xE7,0xFF,0xF8,0x9F,0xFF,0xFF,0xFD,0x80,0x00,0x3F, 0x00,0x02,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x00, 0x00,0x00,0x00,0xFB,0xFF,0xFF,0xF0,0xDF,0xFF,0xFF,0xFF,0xC0,0x00,0xBF,0x00,0x02, 0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00, 0x00,0xFB,0x7F,0xFF,0xF0,0xDF,0xFF,0xFF,0xFF,0x00,0x01,0x9F,0x00,0x02,0xF8,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x0D,0xF2, 0x7F,0xFF,0xF0,0x0F,0xFF,0xFF,0xFF,0x80,0x00,0x1F,0x00,0x02,0xF0,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x00,0x05,0xF2,0xFF,0xFF, 0xF8,0x07,0xFF,0xFF,0xFF,0x80,0x00,0x1F,0x00,0x00,0xF4,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x00,0x09,0xF2,0x7F,0xFF,0xF8,0x0E, 0x70,0x07,0xFF,0x80,0x00,0x0F,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x01,0xF0,0x7F,0xFC,0x00,0x0D,0x01,0xC2, 0x07,0x00,0x00,0x0F,0x00,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x7E,0x00,0x00,0x00,0x00,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x0F,0x00,0x01,0xF4,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7E, 0x00,0x00,0x00,0x00,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x27, 0x00,0x01,0xF4,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x00, 0x00,0x10,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0x00,0x01, 0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0xFE,0x00,0x00,0x00,0x67, 0x1B,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0x00,0x01,0xF0,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0xFD,0x00,0x00,0x00,0x1F,0xC9,0xF0, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0x00,0x01,0xF0,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x06,0xFD,0x00,0x00,0x00,0x7F,0xE1,0xF0,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x01,0xF4,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x05,0xFB,0x00,0x00,0x00,0x7F,0xF1,0xF0,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x01,0xFA,0x00,0x00,0x00,0x7F,0xFD,0xF0,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x17,0x00,0x01,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x03,0xF0,0x00,0x00,0x00,0xFC,0xFD,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x07,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0xF0, 0x00,0x00,0x00,0xFC,0x7F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x17, 0x00,0x02,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x77,0xE8,0x00,0x00, 0x00,0xFD,0x7E,0xF9,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0x00,0x02, 0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6F,0xE8,0x00,0x00,0x00,0x7C, 0xBE,0xFB,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0xF8,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2F,0xD8,0x00,0x00,0x00,0x7D,0x9F,0xFA, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0xFC,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x5F,0xB8,0x00,0x00,0x00,0x7D,0xDF,0x78,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0x00,0x02,0x7D,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x03,0xBF,0x38,0x00,0x00,0x00,0x7E,0x0F,0xFD,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x0F,0x00,0x01,0x7E,0xC0,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x03,0x7E,0x00,0x00,0x00,0x00,0x3E,0x0F,0xFD,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0x00,0x03,0x7E,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06, 0xFE,0x80,0x00,0x00,0x00,0x3F,0x07,0xBE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x0F,0x00,0x01,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1D,0xFD,0x80, 0x00,0x00,0x00,0x3F,0x07,0xDE,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F, 0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3B,0xF8,0x00,0x00,0x00, 0x00,0x5F,0xB7,0xFF,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xDF,0x00,0x00, 0x1F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x37,0xF4,0x00,0x00,0x00,0x00,0x1F, 0xFB,0xEF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x1F,0xC0, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2F,0xEC,0x00,0x00,0x00,0x00,0x6F,0xDB,0xFF, 0xA0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xBF,0x00,0x00,0x2F,0xE8,0x00,0x00, 0x00,0x00,0x00,0x00,0x01,0xBF,0xD8,0x00,0x00,0x00,0x00,0x2F,0xE5,0xF7,0xDA,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x00,0x37,0xF8,0x00,0x00,0x00,0x00, 0x00,0x00,0x01,0x7F,0x80,0x00,0x00,0x00,0x00,0x07,0xFC,0xFB,0xEC,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x3B,0xF8,0x00,0x00,0x00,0x00,0x00,0x00, 0x02,0xFE,0x40,0x00,0x00,0x00,0x00,0x07,0xF4,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0xFC,0x00,0x00,0x3B,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFD, 0xC0,0x00,0x00,0x00,0x00,0x03,0xFA,0x7D,0xF4,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x05,0xFC,0x00,0x00,0x05,0xFE,0xE0,0x00,0x00,0x00,0x00,0x00,0x13,0xF8,0x00,0x80, 0x00,0x00,0x00,0x07,0xFF,0x7E,0xFA,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x0B,0xFA, 0x00,0x00,0x03,0xFF,0x38,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xF0,0x00,0x00,0x00, 0x00,0x07,0xFD,0xBF,0x7C,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xF6,0x00,0x00, 0x03,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x07, 0xFE,0xFF,0xBE,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFE,0x00,0x61,0xC2,0x7F, 0xE2,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xC7,0x00,0x00,0x00,0x06,0x7F,0x5F, 0xDF,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x4F,0xFC,0x01,0x00,0xC0,0x6F,0xF8,0x78, 0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xF3,0x80,0x00,0x00,0x00,0xBF,0xAF,0xEF,0xCC, 0x00,0x00,0x00,0x00,0x00,0x01,0x9F,0xE0,0x00,0x7E,0x20,0x77,0xFF,0x00,0x00,0x00, 0x00,0x00,0x10,0x03,0xFF,0xFD,0x80,0x00,0x00,0x00,0xDF,0x97,0xFF,0xE4,0x00,0x00, 0x00,0x00,0x00,0x00,0x7F,0x60,0x01,0xFF,0x80,0x79,0xFF,0xF0,0x00,0x00,0x00,0x00, 0x07,0x98,0x0F,0xFE,0x00,0x00,0x00,0x00,0x7F,0xDB,0xFF,0xF8,0x00,0x00,0x00,0x00, 0x00,0x00,0xFE,0x40,0xF3,0xFF,0xCC,0x34,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00, 0x01,0xFF,0x70,0x00,0x00,0x00,0x2F,0xED,0xFF,0xFC,0x78,0x00,0x00,0x00,0x00,0x39, 0xFD,0x00,0xE7,0xFF,0xE4,0x00,0x3F,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F, 0xB0,0x00,0x00,0x00,0x07,0xF3,0x7F,0xFF,0x08,0x00,0x00,0x00,0x00,0xE7,0xFB,0x00, 0xCF,0xFF,0xF0,0x00,0xCF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x9F,0xF0,0x00, 0x00,0x00,0x0B,0xF9,0x9F,0xFF,0xE0,0x00,0x00,0x00,0x00,0x0F,0xE6,0x00,0x9F,0xC1, 0xFD,0xC0,0xF1,0xF8,0x00,0x00,0x00,0x00,0x00,0x7F,0x86,0xEF,0xC0,0x00,0x00,0x00, 0x0D,0xFC,0xCF,0xFF,0xFC,0x00,0x00,0x00,0x1E,0x3F,0x8E,0x00,0x7F,0xA2,0x7E,0xC0, 0x0B,0xF0,0x00,0x00,0x00,0x00,0x01,0xFF,0xF3,0x87,0xE0,0x00,0x00,0x00,0x00,0xFF, 0x61,0xFF,0xFF,0x00,0x00,0x00,0x78,0xFF,0x00,0x00,0xFF,0x61,0x3F,0x00,0x03,0xE0, 0x00,0x00,0x00,0x00,0x01,0xFF,0xFD,0x83,0xE0,0x00,0x00,0x00,0x01,0x7F,0x80,0x3F, 0xFF,0x00,0x00,0x00,0x63,0xFF,0x00,0x00,0xFE,0xE3,0x9F,0x80,0x07,0xD0,0x00,0x00, 0x00,0x00,0x01,0xFF,0xFE,0x0B,0xF0,0x00,0x00,0x00,0x01,0x9F,0xC3,0x00,0x00,0x00, 0x00,0x00,0x1F,0xFF,0x00,0x00,0xFD,0xB9,0xCF,0xC8,0x67,0xD0,0x00,0x00,0x00,0x00, 0x01,0xF0,0x7F,0x0B,0xF8,0x00,0x00,0x00,0x00,0xCF,0xF3,0xF8,0x00,0x00,0x00,0x00, 0x1F,0xFF,0x00,0x00,0xFB,0x30,0x67,0xE8,0x6F,0xD0,0x00,0x00,0x00,0x00,0x01,0xFA, 0x0F,0x03,0xF8,0x00,0x00,0x00,0x00,0x07,0xF8,0xC0,0x00,0x00,0x00,0x00,0x7C,0x1F, 0x00,0x00,0xFA,0x2F,0xB3,0xF0,0x0F,0x90,0x00,0x00,0x00,0x00,0x00,0xFC,0x67,0x01, 0xF8,0x00,0x00,0x00,0x00,0x0F,0xFE,0x00,0x00,0x00,0x00,0x00,0x60,0x5F,0x00,0x00, 0xFE,0x9F,0xD9,0xF8,0x1F,0xA0,0x00,0x00,0x00,0x00,0x00,0x7C,0x77,0x81,0xF8,0x00, 0x00,0x00,0x00,0x9F,0xFF,0x80,0x00,0x00,0x00,0x00,0x5F,0xDF,0x80,0x00,0xF8,0x3F, 0xDC,0xFC,0xDF,0x20,0x00,0x00,0x00,0x00,0x03,0xBE,0xA7,0x85,0xF8,0x00,0x00,0x00, 0x00,0xDF,0xFF,0xFF,0x18,0x00,0xCE,0x00,0x07,0xDF,0xA0,0x00,0x7C,0xFF,0xE7,0x7E, 0xBF,0x00,0x00,0x00,0x00,0x00,0x03,0xBF,0x87,0x87,0xF8,0x00,0x00,0x00,0x00,0x9F, 0x3F,0xFF,0xF8,0x00,0x3F,0x00,0x00,0x0F,0x80,0x00,0xBF,0xFD,0xF7,0x3F,0x7E,0x00, 0x00,0x00,0x00,0x00,0x01,0xDF,0x47,0x83,0xF8,0x00,0x00,0x00,0x00,0xBF,0x4F,0xFF, 0xC0,0x00,0xFF,0x00,0x00,0x0F,0xA0,0x00,0xBF,0xF8,0xFB,0xDF,0xFE,0x00,0x00,0x00, 0x00,0x00,0x03,0xCF,0x87,0x03,0xF0,0x00,0x00,0x00,0x00,0x9F,0xA7,0xFF,0xF0,0x07, 0xFE,0x00,0x00,0x0F,0x90,0x00,0x1F,0xF7,0x7D,0xC7,0xFC,0x03,0x60,0x00,0x00,0x00, 0x00,0x2F,0xE7,0x03,0xF0,0x00,0x00,0x00,0x00,0x1F,0xD9,0xFF,0xFF,0xFF,0xFE,0x00, 0x00,0x0F,0x80,0x00,0x07,0xCF,0x3E,0xF3,0xF9,0x01,0xE0,0x00,0x00,0x00,0x00,0x37, 0xCF,0x47,0xF0,0x00,0x00,0x00,0x00,0x1F,0xEE,0x7F,0xFF,0xFF,0xF8,0x00,0x00,0x0F, 0xD0,0x00,0x10,0x3F,0x9F,0x79,0xF3,0x03,0xC0,0x00,0x00,0x00,0x00,0x33,0xEE,0x07, 0xC0,0x00,0x00,0x00,0x00,0x0F,0xFB,0x9F,0xFF,0xFF,0xE2,0x00,0x00,0x0F,0xC0,0x00, 0x00,0x0C,0xDF,0xFC,0x0F,0x1B,0xEC,0x00,0x00,0x00,0x00,0x0B,0xFE,0xFF,0xC0,0x00, 0x00,0x00,0x00,0x07,0xFC,0xE3,0xFF,0xFF,0x8F,0x78,0xC0,0x0F,0xD0,0x00,0x00,0x00, 0x6F,0xF8,0x00,0x17,0xFE,0x00,0x00,0x00,0x00,0x01,0xFC,0xFF,0x90,0x00,0x00,0x00, 0x00,0x1B,0xFF,0x40,0x3F,0xF8,0x01,0xEF,0xE0,0x07,0xD0,0x00,0x00,0x00,0x37,0xF8, 0x00,0x17,0xF4,0x00,0x00,0x00,0x00,0x01,0xFD,0xDF,0xA0,0x00,0x00,0x00,0x00,0x1C, 0xFF,0xC7,0xC0,0x03,0x01,0xFF,0x80,0x07,0xD0,0x00,0x00,0x00,0x3B,0xF0,0x00,0x07, 0xF2,0x00,0x00,0x00,0x00,0x02,0xF9,0xBF,0x70,0x00,0x00,0x00,0x00,0x1F,0x7F,0xE3, 0x8E,0x73,0x08,0x7F,0x80,0x07,0xC0,0x00,0x00,0x00,0x05,0xFB,0x81,0xEF,0xFA,0x00, 0x00,0x00,0x00,0x06,0xF8,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xF8,0x39,0x98, 0x83,0xFF,0x80,0x07,0xE0,0x00,0x00,0x00,0x07,0xFC,0x01,0xDF,0xFC,0x00,0x00,0x00, 0x00,0x03,0xFD,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0x80,0x00,0x3F,0xFF, 0xC0,0x07,0xE0,0x00,0x00,0x00,0x07,0x7E,0x00,0x9F,0xFC,0x00,0x00,0x00,0x00,0x03, 0x7F,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x17,0xFF,0xFE,0x1F,0xFF,0xFF,0xC0,0x07, 0xE0,0x00,0x00,0x00,0x02,0xBF,0x94,0x3F,0x7E,0xC0,0x00,0x00,0x00,0x03,0x7F,0xF9, 0x00,0x00,0x00,0x00,0x00,0x00,0x09,0xFF,0xFF,0xFF,0xFF,0xFD,0x80,0x07,0xE0,0x00, 0x00,0x00,0x00,0x5F,0xC0,0x7E,0x3F,0x40,0x00,0x00,0x00,0x00,0x3F,0xF8,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xF0,0x00,0x07,0xE0,0x00,0x00,0x00, 0x00,0x6F,0xF1,0xFF,0x1F,0x40,0x00,0x00,0x00,0x00,0x3F,0xD8,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0x80,0x00,0x03,0xE0,0x00,0x00,0x00,0x00,0x77, 0xFF,0xFC,0x1F,0x80,0x00,0x00,0x00,0x00,0x1F,0xB8,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x33,0xFF,0xFF,0xF8,0x60,0x00,0x03,0xF0,0x00,0x00,0x00,0x00,0x6B,0xFF,0xFA, 0x0F,0x98,0x00,0x00,0x00,0x00,0x5F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10, 0x3F,0xFF,0x80,0x20,0x00,0x0B,0xF0,0x00,0x00,0x00,0x00,0x05,0xFF,0xF7,0x0F,0xD8, 0x00,0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x80, 0x00,0x00,0x00,0x03,0xF0,0x00,0x00,0x00,0x00,0x06,0x7F,0xC0,0x07,0xF8,0x00,0x00, 0x00,0x00,0x0F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6F,0x90,0x00,0x00, 0x00,0x03,0xF0,0x00,0x00,0x00,0x00,0x07,0x1F,0x00,0x0F,0xFC,0x00,0x00,0x00,0x00, 0x6F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6F,0xD8,0x00,0x00,0x00,0x03, 0xF2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xF0,0x00,0x00,0x00,0x00,0x6F,0x80, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x03,0xF0,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xF8,0x00,0x00,0x00,0x00,0x2F,0x80,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x03,0xFA,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x01,0xF8,0x00,0x00,0x00,0x00,0x2F,0x80,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x05,0xFA,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x01,0xFC,0x00,0x00,0x00,0x00,0x07,0xD8,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x05,0xFA,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x02,0xFC,0x00,0x00,0x00,0x00,0x07,0xD8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x03,0xF0,0x00,0x00,0x00,0x05,0xFB,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFC, 0x00,0x00,0x00,0x00,0x07,0xD0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xF0, 0x00,0x00,0x00,0x01,0xFB,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x7E,0x00,0x00, 0x00,0x00,0x07,0xD8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0B,0xF0,0x00,0x00, 0x00,0x01,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x3E,0x80,0x00,0x00,0x00, 0x07,0xC8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFB,0x00,0x00,0x00,0x01, 0xFD,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x07,0xE0, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x05,0xF9,0x00,0x00,0x00,0x01,0xFE,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x07,0xB0,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x05,0xF8,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x08,0x38,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x0D,0xFD,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x04,0xFD,0x00,0x00,0x00,0x00,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x1F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x04,0xFF,0x00,0x00,0x00,0x00,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0xFE, 0x00,0x00,0x00,0x00,0xFE,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x80,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0xFE,0x00,0x00, 0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x80,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2F,0x80,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 };
//============================================= void lcd_regwrite(uchar regname,uchar regdata) small { lcd_regwr(regname); delay(1); lcd_regwr(regdata); }
void lcd_regwr(uchar regnada) small { lcd_regnada = regnada; lcd_cs1 =0; lcd_rd = 1; lcd_rs = 0; lcd_wr = 0; ; lcd_wr = 1;
lcd_rs = 1; lcd_cs1 =1; }
//--------------------------------------------- void lcd_datawrite(uchar wrdata) small { while(lcd_busy == 1); lcd_data = wrdata; lcd_cs1 =0; lcd_rd = 1; lcd_rs = 1; lcd_wr = 0; ; lcd_wr = 1;
lcd_rs = 1; lcd_cs1 =1; } //--------------------------------------------- uchar lcd_regread(uchar regname) small { uchar reg_rddata; lcd_regwr(regname);
lcd_data = 0xff; lcd_cs1 =0; lcd_wr = 1; lcd_rs = 0; lcd_rd = 0; ; reg_rddata = lcd_data; lcd_rd = 1;
lcd_rs = 1; lcd_cs1 =1; return(reg_rddata); } //============================================= void delay(int k) { int i; for(i=0;i<k;i++) ; } void delay1 (int ms) { int i,j; for(i=0;i<ms;i++) for(j=0;j<123;j++) ; }
//============================================= void lcd_reset(void) small { delay1(120); lcd_control = 0xff; // lcd_rs/wr/rd/cs1/cs2 normal - skeep high. } //--------------------------------------------- void lcd_initial(void) small { lcd_regwrite(0x00,0xc9); // lcd control register(lcr) lcd_regwrite(0x01,0xf2); // misc.register(mir) lcd_regwrite(0x02,0x10); // advance power setup register(apsr) lcd_regwrite(0x03,0x80); // advance display setup regiser(adsr) lcd_regwrite(0x10,0x6b); // cursor control register(ccr) lcd_regwrite(0x11,0x00); // distance of word or lines register(dwlr) lcd_regwrite(0x12,0x91); // memory access mode register(awrr) lcd_regwrite(0x21,0x1d); // display window right register(dwrr) lcd_regwrite(0x31,0x7f); // display window bottom register(dwbr) lcd_regwrite(0x41,0x00); // display window left register(dwlr) lcd_regwrite(0x51,0x00); // display window top register(dwtr) lcd_regwrite(0x20,0x1d); // active window right register(awrr) lcd_regwrite(0x30,0x7f); // active window bottom register(awbr) lcd_regwrite(0x40,0x00); // active window left register(awlr) lcd_regwrite(0x50,0x00); // active window top register(awtr) lcd_regwrite(0x60,0x00); // cursor position x register(cpxr) lcd_regwrite(0x61,0x00); // begin segment position register(bgsg) lcd_regwrite(0x70,0x00); // cursor position y register(cpyr) lcd_regwrite(0x71,0x00); // shift action range,begin commom register(bgcm) lcd_regwrite(0x72,0x7f); // shift action range,end commom register(edcm) lcd_regwrite(0x80,0xaa); // blink time register(btr) lcd_regwrite(0x81,0x00); // frame rate polarity change at common_fa register(fdca) lcd_regwrite(0x91,0x00); // frame rate polarity change at common_fb register(fdcb) lcd_regwrite(0x90,0x0f); // shift clock control register(sccr) lcd_regwrite(0xa0,0x11); // interrupt setup & status register(frcb) lcd_regwrite(0xa1,0x00); // key scan control register(kscr) lcd_regwrite(0xa2,0x00); // key scan data register(ksdr) lcd_regwrite(0xa3,0x00); // key scan data expand register(kser) lcd_regwrite(0xb0,0x1d); // interrupt column setup register(intx) lcd_regwrite(0xb1,0x7f); // interrupt row setup register(inty) lcd_regwrite(0xc0,0x00); // touch panel control register(tpcr) lcd_regwrite(0xc1,0x0a); // adc status register(adcs) lcd_regwrite(0xc8,0x80); // touch panel segment high byte data register(tpxr) lcd_regwrite(0xc9,0x80); // touch panel common high byte data register(tpyr) lcd_regwrite(0xca,0x00); // touch panel segment/common low byte data register(tpzr) lcd_regwrite(0xd0,0x80); // lcd contrast control register (lccr) lcd_regwrite(0xe0,0x00); // pattern data register(pdr) lcd_regwrite(0xf0,0xa0); // font control register(fcr) lcd_regwrite(0xf1,0x0f); // font size control register } //--------------------------------------------- void lcd_clear(void) small { uchar reg_rddata; lcd_regwrite(0xe0,0x00); reg_rddata = lcd_regread(0xf0); reg_rddata |= 0x08; lcd_regwrite(0xf0,reg_rddata); } //--------------------------------------------- void lcd_photo(uchar code *pho) small { uchar i,j; uchar code *pp; gotoxy(0,0); pp=pho; for(j=0;j<128;j++) { for(i=0;i<30;i++) { lcd_datawrite(*pp); ++pp; } } }
//--------------------------------------------- void lcd_lattice(uchar data1,uchar data2) small { uchar i,j; gotoxy(0,0); for(j=0;j<32;j++) { for(i=0;i<60;i++) { lcd_datawrite(data1); //delay1(1000); }
for(i=0;i<60;i++) { lcd_datawrite(data2); } } } //--------------------------------------------- void lcd_character(uchar code *cha,int count) small { int i; for(i=0;i<count;i++) { lcd_datawrite(*cha); ++cha; } } //--------------------------------------------- extern void gotoxy(uchar x,uchar y) small { lcd_regwrite(0x60,x); // active window top register(awtr) lcd_regwrite(0x70,y); // active window top register(awtr) }
//============================================= void main (void) { lcd_reset(); lcd_initial(); lcd_clear(); while(1) { lcd_regwrite(0x00,0xcd); lcd_regwrite(0x10,0x2b); gotoxy(0x00,0x00); lcd_character(tab1,240); delay1(3000); lcd_regwrite(0x00,0xc5); lcd_lattice(0xcc,0xcc); delay1(3000); lcd_lattice(0x33,0x33); delay1(3000);
lcd_photo(tab3); delay1(3000);
lcd_regwrite(0x00,0xcd); lcd_regwrite(0x10,0x3b); gotoxy(0x00,0x00); lcd_character(tab2,240); delay1(3000); lcd_regwrite(0x00,0xc5); lcd_lattice(0xcc,0x33); delay1(3000);
