#include <GLOBAL.h> #include <stdlib.h> #include <stdbool.h> #include <msp430x41x.h> //*======================================================== //*======================================================== void ClrLcd(void) { unsigned int i; for(i=0;i<17;i++) { LCDMEM=0;; } } void InitLcd(void) { LCDCTL = LCD4MUX + LCDP1; P5SEL = 0xFF; BTCTL |= BTFRFQ0; ClrLcd(); } void OpenLcd(void) { LCDCTL|=LCDON; LcdRunData=0; LcdShowNum=0; LcdParseEn=1; } void DispLay(unsigned char Station,unsigned char Num) { const unsigned char LcdTable[11]={0x7d,0x60,0x3e,0x7a,0x63,0x5b,0x5f,0x70,0x7f,0x7b,0x00}; LCDMEM[Station]=LcdTable[Num]; } void LcdDataFull(unsigned char MemShowStr,unsigned char ShowFg) { unsigned char i,k; //GloBuf[0]-GloBuf[3]--->原始数据 //GloBuf[4]-GloBuf[11]-->分解后的数据 for(i=0;i<4;i++) { k=GloBuf & 0xf0; k=k>>4; GloBuf[11-(i+i+1)]=k; k=GloBuf & 0x0f; GloBuf[11-(i+i)]=k; } for(i=MemShowStr;i<8;i++) { DispLay(i,GloBuf[4+i]); } LCDMEM[0]|=0x01; if(ShowBit[0]&0x01){LCDMEM[8]|=0x04;}else{LCDMEM[8]&=0xfb;}//--->M if(ShowBit[0]&0x02){LCDMEM[0]|=0x02;}else{LCDMEM[0]&=0xfd;}//--->累计 if(ShowBit[0]&0x04){LCDMEM[0]|=0x04;}else{LCDMEM[0]&=0xfb;}//--->购水 if(ShowBit[0]&0x08){LCDMEM[0]|=0x08;}else{LCDMEM[0]&=0xf7;}//--->剩余 if(ValveOpenSt){LCDMEM[0]|=0x20;}else{LCDMEM[0]&=0xdf;}//--->开 if(ValveClosSt){LCDMEM[0]|=0x40;}else{LCDMEM[0]&=0xbf;}//--->关 if(ShowBit[1]&0x01){LCDMEM[5]|=0x80;}else{LCDMEM[5]&=0x7f;}//--->. if(DisturbFg){LCDMEM[3]|=0x80;}else{LCDMEM[3]&=0x7f;}//--->干扰 if(CardErr){LCDMEM[7]|=0x80;}else{LCDMEM[7]&=0x7f;}//--->卡错 if(PowerLowFg){LCDMEM[8]|=0x08;}else{LCDMEM[8]&=0xf7;}//--->低压 if(ShowBuy){LCDMEM[6]|=0x80;}else{LCDMEM[6]&=0x7f;}//--->速购 } void LcdParse(void) { if(LcdParseEn) { if(SecondsConn&0x04) { if(LcdRunData>3) { LcdRunData=0; LcdShowNum++; } else { LcdRunData++; } ClrLcd(); ShowBit[0]=0; ShowBit[1]=0; ShowBit[1]|=0x01; switch(LcdShowNum) { case 0x00 ://第03种显示方式数据提取到显示缓冲区---累计使用量 ShowBit[0]|=0x03; RamCopy(GloBuf,Overal,4); LcdDataFull(1,1); break; case 0x01 ://第01种显示方式数据提取到显示缓冲区---最新购买量 ShowBit[0]|=0x05; RamCopy(GloBuf,BuyData,4); LcdDataFull(1,1); break; case 0x02 ://第02种显示方式数据提取到显示缓冲区---当前剩余量 ShowBit[0]|=0x09; if(OverdraftSt) { RamCopy(GloBuf,OverData,4); LcdDataFull(2,1); LCDMEM[1]=0x02; } else { RamCopy(GloBuf,Residual,4); LcdDataFull(1,1); } break; case 0x03 ://第01种显示方式数据提取到显示缓冲区---版本号1107 ShowBit[0]=0; ShowBit[1]=0; ShowBit[1]|=0x01; LCDMEM[0]=0; LCDMEM[1]=0x75;//----N LCDMEM[2]=0x4e;//----0 LCDMEM[3]=0x02;//----- LCDMEM[4]=0x60;//----1 DispLay(5,0x02);//---2 LCDMEM[6]=0x7d;//----0 DispLay(7,0x02);//---2 LCDMEM[8]=0; break; default: LcdShowEn=1; if(!PowerLowFg) { LcdShowEn=0; LCDCTL&=~LCDON;; } LcdRunData=0; LcdShowNum=0; LcdParseEn=0; break; } SecondsConn&=0xfb; } } }
