看到有人把头文件都贴出来了,我也跟风,把以前用的一个头文件贴出来。
/* Define EMIF Registers */
#define EMIF_GBLCTL (*((unsigned int *)0x01800000)) /* Address of EMIF global control */
#define EMIF_CE1CTL (*((unsigned int *)0x01800004)) /* Address of EMIF CE1 control */
#define EMIF_CE0CTL (*((unsigned int *)0x01800008)) /* Address of EMIF CE0 control */
#define EMIF_CE2CTL (*((unsigned int *)0x01800010)) /* Address of EMIF CE2 control */
#define EMIF_CE3CTL (*((unsigned int *)0x01800014)) /* Address of EMIF CE3 control */
#define EMIF_SDCTRL (*((unsigned int *)0x01800018)) /* Address of EMIF SDRAM control */
#define EMIF_SDTIM (*((unsigned int *)0x0180001C)) /* Address of EMIF SDRAM refresh control*/
#define EMIF_SDEXT (*((unsigned int *)0x01800020)) /* Address of EMIF SDRAM extension control*/
#define EMIF_CCFG (*((unsigned int *)0x01840000))
/* Define McBSP0 Registers */
#define McBSP0_DRR 0x18c0000 /* Address of data receive reg. */
#define McBSP0_DXR 0x18c0004 /* Address of data transmit reg. */
#define McBSP0_SPCR 0x18c0008 /* Address of serial port contl. reg. */
#define McBSP0_RCR 0x18c000C /* Address of receive control reg. */
#define McBSP0_XCR 0x18c0010 /* Address of transmit control reg. */
#define McBSP0_SRGR 0x18c0014 /* Address of sample rate generator */
#define McBSP0_MCR 0x18c0018 /* Address of multichannel reg. */
#define McBSP0_RCER 0x18c001C /* Address of receive channel enable. */
#define McBSP0_XCER 0x18c0020 /* Address of transmit channel enable. */
#define McBSP0_PCR 0x18c0024 /* Address of pin control reg. */
/* Define McBSP1 Registers */
#define McBSP1_DRR 0x1900000 /* Address of data receive reg. */
#define McBSP1_DXR 0x1900004 /* Address of data transmit reg. */
#define McBSP1_SPCR 0x1900008 /* Address of serial port contl. reg. */
#define McBSP1_RCR 0x190000C /* Address of receive control reg. */
#define McBSP1_XCR 0x1900010 /* Address of transmit control reg. */
#define McBSP1_SRGR 0x1900014 /* Address of sample rate generator */
#define McBSP1_MCR 0x1900018 /* Address of multichannel reg. */
#define McBSP1_RCER 0x190001C /* Address of receive channel enable. */
#define McBSP1_XCER 0x1900020 /* Address of transmit channel enable. */
#define McBSP1_PCR 0x1900024 /* Address of pin control reg. */
/* Define L2 Cache Registers */
#define L2CFG 0x1840000 /* Address of L2 config reg */
#define MAR0 0x1848200 /* Address of mem attribute reg */
/* Define Interrupt Registers */
#define IMH 0x19c0000 /* Address of Interrupt Multiplexer High*/
#define IML 0x19c0004 /* Address of Interrupt Multiplexer Low */
/* Define Timer0 Registers */
#define TIMER0_CTRL 0x1940000 /* Address of timer0 control reg. */
#define TIMER0_PRD 0x1940004 /* Address of timer0 period reg. */
#define TIMER0_COUNT 0x1940008 /* Address of timer0 counter reg. */
/* Define Timer1 Registers */
#define TIMER1_CTRL 0x1980000 /* Address of timer1 control reg. */
#define TIMER1_PRD 0x1980004 /* Address of timer1 period reg. */
#define TIMER1_COUNT 0x1980008 /* Address of timer1 counter reg. */
/* Define EDMA Registers */
#define PQSR 0x01A0FFE0 /* Address of priority queue status */
#define CIPR 0x01A0FFE4 /* Address of channel interrupt pending */
#define CIER 0x01A0FFE8 /* Address of channel interrupt enable */
#define CCER 0x01A0FFEC /* Address of channel chain enable */
#define ER 0x01A0FFF0 /* Address of event register */
#define EER 0x01A0FFF4 /* Address of event enable register */
#define ECR 0x01A0FFF8 /* Address of event clear register */
#define ESR 0x01A0FFFC /* Address of event set register */
/* Define EDMA Transfer Parameter Entry Fields */
#define OPT 0*4 /* Options Parameter */
#define SRC 1*4 /* SRC Address Parameter */
#define CNT 2*4 /* Count Parameter */
#define DST 3*4 /* DST Address Parameter */
#define IDX 4*4 /* IDX Parameter */
#define LNK 5*4 /* LNK Parameter */
/* Define EDMA Parameter RAM Addresses */
#define EVENT0_PARAMS 0x01A00000
#define EVENT1_PARAMS EVENT0_PARAMS + 0x18
#define EVENT2_PARAMS EVENT1_PARAMS + 0x18
#define EVENT3_PARAMS EVENT2_PARAMS + 0x18
#define EVENT4_PARAMS EVENT3_PARAMS + 0x18
#define EVENT5_PARAMS EVENT4_PARAMS + 0x18
#define EVENT6_PARAMS EVENT5_PARAMS + 0x18
#define EVENT7_PARAMS EVENT6_PARAMS + 0x18
#define EVENT8_PARAMS EVENT7_PARAMS + 0x18
#define EVENT9_PARAMS EVENT8_PARAMS + 0x18
#define EVENTA_PARAMS EVENT9_PARAMS + 0x18
#define EVENTB_PARAMS EVENTA_PARAMS + 0x18
#define EVENTC_PARAMS EVENTB_PARAMS + 0x18
#define EVENTD_PARAMS EVENTC_PARAMS + 0x18
#define EVENTE_PARAMS EVENTD_PARAMS + 0x18
#define EVENTF_PARAMS EVENTE_PARAMS + 0x18
#define EVENTN_PARAMS EVENTF_PARAMS + 0x18
#define EVENTO_PARAMS EVENTN_PARAMS + 0x18
/* Define QDMA Memory Mapped Registers */
#define QDMA_OPT 0x02000000 /* Address of QDMA options register */
#define QDMA_SRC 0x02000004 /* Address of QDMA SRC address register */
#define QDMA_CNT 0x02000008 /* Address of QDMA counts register */
#define QDMA_DST 0x0200000C /* Address of QDMA DST address register */
#define QDMA_IDX 0x02000010 /* Address of QDMA index register */
/* Define QDMA Pseudo Registers */
#define QDMA_S_OPT 0x02000020 /* Address of QDMA options register */
#define QDMA_S_SRC 0x02000024 /* Address of QDMA SRC address register */
#define QDMA_S_CNT 0x02000028 /* Address of QDMA counts register */
#define QDMA_S_DST 0x0200002C /* Address of QDMA DST address register */
#define QDMA_S_IDX 0x02000030 /* Address of QDMA index register */
/* Definitions for the DSK Board and SW */
//操作扩展中断
//操作16C550
#define UART_BASE_ADDR 0xA0000000
#define OFFSET 0X00000400
#define RBR_16C550 *((int*)(UART_BASE_ADDR+0*OFFSET))
#define THR_16C550 *((int*)(UART_BASE_ADDR+0*OFFSET))
#define IER_16C550 *((int*)(UART_BASE_ADDR+1*OFFSET))
#define IIR_16C550 *((int*)(UART_BASE_ADDR+2*OFFSET))
#define FCR_16C550 *((int*)(UART_BASE_ADDR+2*OFFSET))
#define LCR_16C550 *((int*)(UART_BASE_ADDR+3*OFFSET))
#define MCR_16C550 *((int*)(UART_BASE_ADDR+4*OFFSET))
#define LSR_16C550 *((int*)(UART_BASE_ADDR+5*OFFSET))
#define MSR_16C550 *((int*)(UART_BASE_ADDR+6*OFFSET))
#define SCR_16C550 *((int*)(UART_BASE_ADDR+7*OFFSET))
#define DLL_16C550 *((int*)(UART_BASE_ADDR+0*OFFSET))
#define DLM_16C550 *((int*)(UART_BASE_ADDR+1*OFFSET))
#define Reset16C550 *((int*)0X90080000)=0X00;Wait(100);*((int*)NULL_ADDRESS)=0x00
#define SEND_CHAR(SendChar) while(1){if((LSR_16C550&0x20)!=0x00)break;}THR_16C550=SendChar
//6711寄存器
#define EXTPOL *(int*)0x019C0008 //External Interrupt Polarity Register
#define MUXL *(int*)0x019C0004 //Interrupt Selector Registers
#define MUXH *(int*)0x019C0004 //Interrupt Selector Registers
//命令匹配
#define RX_DATA 0x00 //正在接收数据
#define MATCHING 0x01 //命令正在匹配
#define MATCHED 0x02 //命令已经匹配
//状态字
#define YES 0x55 // !YES=NO
#define NO 0xaa //
//状态字
#define VALID 0x55 // !VALID=INVALID
#define INVALID 0xaa //
//可调参数
#define MAX_COMMAND_NUM 5 //命令匹配时最多需要匹配的命令
#define MATRIX_DEM 5 //进行QR分解的矩阵的维数
//空地之
#define NULL_ADDRESS 0xAFFF0000 //FPGA的空地址
//中断开关
#define ENABLE_ALL CSR|=1 //开全局中断
#define DISABLE_ALL CSR&=0 //关全局中断
//通用IO
#define WDI *((int*)0X90050000)=0x00 //看门购输入脉冲
#define RS485_RECEIVE *((int*)0X90010000)=0x00 //485接收数据
#define RS485_TRANSMIT *((int*)0X90020000)=0x00 //485发送数据
#define CAPMODE160128 *((int*)0X90030000)=0x00 //视频模块图像格式160*128
#define CAPMODE320240 *((int*)0X90040000)=0x00 //视频模块图像格式320*240
#define EX_LATCH2_HIGH *((int*)0X90090000)=0x00 //扩展IO 2 置低
#define EX_LATCH2_LOW *((int*)0X900A0000)=0x00 //扩展IO 2 置高
#define EX_LATCH3_HIGH *((int*)0X900B0000)=0x00 //扩展IO 3置低
#define EX_LATCH3_LOW *((int*)0X900C0000)=0x00 //扩展IO 2 置高
#define EX_LATCH4_HIGH *((int*)0X900D0000)=0x00 //扩展IO 4置低
#define EX_LATCH4_LOW *((int*)0X900E0000)=0x00 //扩展IO 2 置高
//多路选通
#define TXD_TO_TXDOUT1 *((int*)0X90200000)=0x00 //16c550的串行输出到第一路232
#define TXD_TO_TXDOUT2 *((int*)0X90210000)=0x00 //16c550的串行输出到第二路232
#define TXD_TO_RS485DI *((int*)0X90220000)=0x00 //16c550的串行输出到485
#define RXDIN1_TO_RXD *((int*)0X90230000)=0x00 //第一路232输出到16c550的串行输入
#define RXDIN2_TO_RXD *((int*)0X90240000)=0x00 //第二路232输出到16c550的串行输入
#define RS485RO_TO_RXD *((int*)0X90250000)=0x00 //485输出到16c550的串行输入
//LED
#define LED 0x90202018
#define LED1_ON *((int*)0x90202018)|=0x80000000
#define LED1_OFF *((int*)0x90202018)&=0x70000000
#define LED2_ON *((int*)0x90202018)|=0x40000000
#define LED2_OFF *((int*)0x90202018)&=0xB0000000
#define LED3_ON *((int*)0x90202018)|=0x20000000
#define LED3_OFF *((int*)0x90202018)&=0xD0000000
#define LED4_ON *((int*)0x90202018)|=0x10000000
#define LED4_OFF *((int*)0x90202018)&=0xE0000000
#define LED_ALL_ON *((int*)0x90202018)=0xff000000
#define LED_ALL_OFF *((int*)0x90202018)=0x00000000
//常用常数
#define LONG_BUAA 116 //北航的经度
#define LAT_BUAA 39 //北航的纬度
#define Wie 0.0041667 //地球自转角速度
#define PI 3.1415926 //PI
#define uchar unsigned char
#define FLASHMAP1ADDRESS 0x90000000 //flash首地址
