电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » 程序设计
程序设计
2015-01-09 09:06:59     打赏
3-3
答:1.IF-ELSIF
LIBRARY  IEEE;
USE   IEEE.STD_LOGIC_1164.ALL;
ENTITY   MUX41A  IS
PORT   (A,B,C,D,S0,S1,S2,S3:IN     STD_LOGIC;
                         Y:OUT   STD_LOGIC);
END  ENTITY  MUX41A;
ARCHITECTURE  BHV  OF  MUX41A  IS
BEGIN
  PROCESS(S0,S1,S2,S3,A,B,C,D)
   BEGIN
     IF      S0=’0’   THEN   Y<=A;
     ELSIF   S1=’0’   THEN   Y<=B;
     ELSIF   S2=’0’   THEN   Y<=C;
     ELSIF   S2=’0’   THEN   Y<=D;
     ELSE    NULL;
     END     IF;
  END   PROCESS;
END  BHV;
2.CASE语句
LIBRARY  IEEE;
ENTITY   MUX41A  IS
                         Y:OUT   STD_LOGIC);
END  ENTITY  MUX41A;
SIGNAL  S :STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
S<=S3&S2&S1&S0;
  PROCESS(S0,S1,S2,S3,A,B,C,D)   BEGIN
   CASE  (S)  IS
     WHEN  “0111” =>  Y<=D;
     WHEN  “1011” =>  Y<=C;
     WHEN  “1101” =>  Y<=B;
     WHEN  “1110” =>  Y<=A;
     WHEN  OTHER=>  NULL;
    END   CASE;
END  PROCESS;
END   BHV;
   3.WHEN-ELSE
LIBRARY  IEEE;
ENTITY   MUX41A  IS
                         Y:OUT   STD_LOGIC);
END  ENTITY  MUX41A;
BEGIN
   S<=S3&S2&S1&S0;
   Y<=A     WHEN   S=“1110” ELSE
   Y<=B     WHEN   S=“1101” ELSE
   Y<=C     WHEN   S=“1011” ELSE
   Y<=D     WHEN   S=“0111” ELSE
   NULL;
END   BHV;
3-4解:1.
LIBRARY  IEEE;
ENTITY  H_SUBER  IS
     PORT (     x, y : IN  STD_LOGIC;
           diff, s_out : OUT  STD_LOGIC);
END  ENTITY  H_SUBER;
ARCHITECTURE  fh1  OF  H_SUBER  IS
BEGIN
      s_out <= (NOT x ) AND  y;
      diff <= x  XOR  y;
END  ARCHITECTURE  fh1;
(2)全减器
LIBRARY  IEEE;
ENTITY  F_SUBER  IS
     PORT ( X,Y,sub_in : IN  STD_LOGIC;
             diff,s_out : OUT  STD_LOGIC);
END  ENTITY  F_SUBER;
ARCHITECTURE  fd1  OF  F_SUBER  IS
COMPONENT  H_SUBER
   PORT  (x ,y : IN  STD_LOGIC;  s_out ,diff : OUT  STD_LOGIC);
END  COMPONENT;
SIGNAL  net1, net2, net3: STD_LOGIC;
BEGIN
   u1 : H_SUBER  PORT  MAP(x=>X, y=>Y, diff=>net1, s_out=>net2);
   u2 : H_SUBER  PORT  MAP(x=>net1, y=>sub_in, diff=>diffr, s_out=>net3);
   sub_out <= net2  OR  net3;
END  fd1;
