[NgdBuild 604] logical block 'system_i
QN1UH78VKP2T7)IA]ZM(FW.gif)
解决方案:
1. Removed directory .src/sources_1/edk//implementation
2. Removed directory .src/sources_1/edk//synthesis
3. Created new synthesis and implementation runs.
4. Set the new runs as "active".
5. Removed old runs.
6. Opened XPS by double-clicking in the embedded design under the sources tab.
7. Closed XPS without doing anything.
8. Selected the new synthesis run and clicked on "Reset Selected Runs".
9. Selected the new implementation run and clicked on "Launch Selected Runs".
