最后是公共板的几张实际效果照片
公共板WiDo上的源码公布
InfoBoardLite.ino:
#include"LED_Array.h"
/*感谢为“LED_Array”做贡献的:穆诗、Cont、丁Hao 等*/
#include <SPI.h>
#include <Adafruit_CC3000.h>
unsigned int NumOfWord = 0;
#define DataOfPage 128
#define NumOfPage 5
unsigned char Data[DataOfPage*NumOfPage];
unsigned long Time;
Adafruit_CC3000 cc3000 = Adafruit_CC3000(10, 7, 5, SPI_CLOCK_DIVIDER);
#define WLAN_SSID "TP-LINK_7A9FB8"
#define WLAN_PASS "enteryoupassword"
#define WLAN_SECURITY WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS 3000
#define WEBSITE "helloworld.pw"
#define WEBPAGE "/wido/display.shtml"
uint32_t ip;
void setup()
TimeCont(0);
Init_LED_Array();
Serial.begin(9600);
Serial.println("LED Arry Ready!");
Init_WIFI();
while (NumOfWord == 0)
Get_Data();
if(NumOfWord == 0)
delay(20000);
Serial.print("Runing!Loader Time: ");
Serial.print(TimeCont(1) / 1000);
Serial.println("s");
TimeCont(0);
void loop()
int i;
int n;
for (i = 0; i < NumOfWord / 4 + ((NumOfWord % 4>0)?1:0); i++)
for (n = 80; n > 1; n--)
Write_LED_Array(0, &Data[i * DataOfPage], L0);
Write_LED_Array(0, &Data[i * DataOfPage + 64], G1);
if (TimeCont(1) / 60000 > 4)
TimeCont(0);
Get_Data();
Serial.print("Does!Loader Time: ");
Serial.print(TimeCont(1));
Serial.println("ms");
TimeCont(0);
unsigned long TimeCont(char _do)
if (_do != 0)
return millis() - Time;
Time = millis();
void Init_WIFI(void)
Serial.println(F("Hello, CC3000!"));
/* Initialise the module */
Serial.println(F("Initializing..."));
if (!cc3000.begin())
Serial.println(F("Couldn't begin()! Check your wiring?"));
while (1);
Serial.print(F("Attempting to connect to ")); Serial.print(WLAN_SSID);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
Serial.println(F("...Failed!"));
while (1);
Serial.println(F("...Connected!"));
/* Wait for DHCP to complete */
Serial.print(F("Request DHCP..."));
while (!cc3000.checkDHCP())
delay(100); // ToDo: Insert a DHCP timeout!
Serial.println(F("OK!"));
while (! displayConnectionDetails()) {
delay(1000);
ip = 0;
Serial.print("ping: "); Serial.print(WEBSITE); Serial.print(F(" -> "));
while (ip == 0) {
if (! cc3000.getHostByName(WEBSITE, &ip)) {
Serial.println(F("Couldn't resolve!"));
delay(500);
cc3000.printIPdotsRev(ip);
Serial.println("\n");
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if (!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
Serial.println(F("Unable to retrieve the IP Address!\r\n"));
return false;
else
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
return true;
void Get_Data(void)
Adafruit_CC3000_Client www = cc3000.connectTCP(ip, 80);
char _do = 0;
Serial.println(F("---- Take Byte ...-------------------"));
if (www.connected()) {
www.fastrprint(F("GET "));
www.fastrprint(WEBPAGE);
www.fastrprint(F(" HTTP/1.1\r\n"));
www.fastrprint(F("Host: ")); www.fastrprint(WEBSITE); www.fastrprint(F("\r\n"));
www.println();
} else {
Serial.println(F("Connection failed"));
return;
unsigned long lastRead = millis();
int n = 0;
while (www.connected() && (millis() - lastRead < IDLE_TIMEOUT_MS)) {
while (www.available()) {
char c = www.read();
if (_do == 1 && n < DataOfPage * NumOfPage)
Data[n] = c;
n++;
if (c == '#')
_do = 1;
if (n > 0)
NumOfWord = (n + 1) / 32;
Serial.print("Take Byte: "); Serial.println(n);
Serial.println(F("-------------------------------------"));
www.close();
LED_Array.h:
#ifndef LED_Array_H #define LED_Array_H #define R0 2 #define R1 3 #define G0 8 #define G1 9 #define L0 11 #define L1 12 #define STB A4//RCLK STCP #define CLK A5//SCLK SHCP #define EN 13 #define RowA A0 #define RowB A1 #define RowC A2 #define RowD A3 void Write_595(unsigned char Data, unsigned char PIN_595); //this is the base driver of 74HC595 void Init_LED_Array(void); //put this function into setup() void Display(); //you can modify this function to display contents that you what to show void Write_LED_Array(unsigned long pos, unsigned char *pData, unsigned char COLOR); //this is the base driver of LED array #endif
LED_Array.cpp:
#include"Arduino.h"
void Display()//you can modify this function to display contents that you what to show
unsigned char i;
for (i = 80; i > 1; i--)
Write_LED_Array(0, &cod1[0x0000], R0); //Write_LED_Array(pos,data,color);
Write_LED_Array(1, &cod1[64], R1);
Write_LED_Array(0, &cod1[128], R0); //Write_LED_Array(pos,data,color);
Write_LED_Array(1, &cod1[192], R1);
void Init_LED_Array(void)//put this function into setup()
pinMode(R0, OUTPUT);
pinMode(R1, OUTPUT);
pinMode(G0, OUTPUT);
pinMode(G1, OUTPUT);
pinMode(L0, OUTPUT);
pinMode(L1, OUTPUT);
digitalWrite(R0, LOW);
digitalWrite(R1, LOW);
digitalWrite(G0, LOW);
digitalWrite(G1, LOW);
digitalWrite(L0, LOW);
digitalWrite(L1, LOW);
pinMode(STB, OUTPUT);
pinMode(CLK, OUTPUT);
pinMode(EN, OUTPUT);
pinMode(RowA, OUTPUT);
pinMode(RowB, OUTPUT);
pinMode(RowC, OUTPUT);
pinMode(RowD, OUTPUT);
digitalWrite(EN, LOW);
void Write_595(unsigned char Data, unsigned char PIN_595) //this is the base driver of 74HC595
digitalWrite(CLK, LOW);
digitalWrite(PIN_595, (Data & 0x80));
digitalWrite(CLK, HIGH);
digitalWrite(PIN_595, (Data & 0x40));
digitalWrite(PIN_595, (Data & 0x20));
digitalWrite(PIN_595, (Data & 0x10));
digitalWrite(PIN_595, (Data & 0x08));
digitalWrite(PIN_595, (Data & 0x04));
digitalWrite(PIN_595, (Data & 0x02));
digitalWrite(PIN_595, (Data & 0x01));
void Write_LED_Array(unsigned long pos, unsigned char *pData, unsigned char COLOR) //this is the base driver of LED array
#define LIGHT 160
unsigned char *pTemp;
unsigned char row;
for (row = 0; row < 16; row++)
digitalWrite(EN, HIGH);
pTemp = (pData + (row * 2));
Write_595(*pTemp, COLOR);
Write_595(*(pTemp + 1), COLOR);
Write_595(*(pTemp += 32), COLOR);
// Write_595(*(pTemp += 32), COLOR);
// Write_595(*(pTemp + 1), COLOR);
digitalWrite(STB, HIGH);
delayMicroseconds(1);
digitalWrite(STB, LOW);
digitalWrite(RowA, (row & 0x01)); //set display line
digitalWrite(RowB, (row & 0x02)); //Sequential scan
digitalWrite(RowC, (row & 0x04));
digitalWrite(RowD, (row & 0x08));
delayMicroseconds(LIGHT);
#undef LIGHT
| 为遥控小车巧添功能被打赏¥26元 | |
