电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » valid-palindrome
valid-palindrome
2018-01-26 13:07:25     打赏
Given a string, determine if it is a palindrome, considering only alphanumeric characters and ignoring cases.
For example,
"A man, a plan, a canal: Panama"is a palindrome.
"race a car"is not a palindrome.
Note:
Have you consider that the string might be empty? This is a good question to ask during an interview.
For the purpose of this problem, we define empty string as valid palindrome.\
题意:给定一个字符串,确定它是否是回文,只考虑字母数字字符;
思路:从头遍历和从尾部遍历同时进行;
跳过不是字符的;
注意题意,忽略大小写,即a==A
[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     bool isPalindrome(string s)
  5.     {
  6.         if (s.empty())
  7.         {
  8.             return true;
  9.         }
  10.         int start = 0;
  11.         int end = s.size() - 1;
  12.         while (start<end)
  13.         {
  14.             //忽略非字符和非数字的
  15.             while (!((s[start] >= 'a' && s[start] <= 'z')
  16.                 || (s[start] >= 'A' && s[start] <= 'Z')
  17.                 || (s[start] >= '0' && s[start] <= '9'))
  18.                 && start<s.size())
  19.             {
  20.                 start++;
  21.             }
  22.
  23.             while (!((s[end] >= 'a' && s[end] <= 'z')
  24.                 || (s[end] >= 'A' && s[end] <= 'Z')
  25.                 || (s[end] >= '0' && s[end] <= '9'))
  26.                 && end >= 0)
  27.             {
  28.                 end--;
  29.             }
  30.
  31.             if (s[start] == s[end] || s[start] + 32 == s[end] || s[start] - 32 == s[end])
  32.             {
  33.                 start++;
  34.                 end--;
  35.             }
  36.             else
  37.             {
  38.                 return false;
  39.             }
  40.         }
  41.         return true;
  42.     }
  43. };
