电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 【转载】嵌入式中,TCP通信常用接口的使用封装--from嗷呜
2022-06-22 15:59:36     打赏
一个TCP通信的框图如:
这个图中也列出了常用的几个接口函数,其中,有几个函数调用时传参比较繁琐,为了提高我们的编码效率,有必要对这些接口的使用进一步地封装,使得函数调用更简单些。
TCP常用接口使用封装
下面给大家整理一份:
tcp_socket.h:
#ifndef TCP_SCOKET_H
#define TCP_SCOKET_H
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <unistd.h>
#include <signal.h>
#define MAX_CONNECT_NUM 10
int tcp_init(const char* ip, int port);
int tcp_accept(int sfd);
int tcp_connect(const char* ip, int port);
int tcp_nonblocking_recv(int conn_sockfd,
                         void *rx_buf,
                         int buf_len,
                         int timeval_sec,
                         int timeval_usec);
int tcp_blocking_recv(int conn_sockfd, void *rx_buf, uint16_t buf_len);
int tcp_send(int conn_sockfd, uint8_t *tx_buf, uint16_t buf_len);
void tcp_close(int sockfd);
#endif
tcp_socket.c:
#include "tcp_socket.h"
    int optval = 1;
    int server_fd = socket(AF_INET, SOCK_STREAM, 0);
    if (server_fd < 0)
        perror("socket");
        return -1;
    /* 解除端口占用 */
    if (setsockopt(server_fd, SOL_SOCKET, SO_REUSEADDR, &optval, sizeof(optval)) < 0)
  perror("setsockopt\n");
  return -1;
    struct sockaddr_in server_addr;
    bzero(&server_addr, sizeof(struct sockaddr));
    server_addr.sin_family = AF_INET;
    server_addr.sin_port = htons(port);
    if (NULL == ip)
        server_addr.sin_addr.s_addr = htonl(INADDR_ANY);
    else
        server_addr.sin_addr.s_addr = inet_addr(ip);
    if (bind(server_fd, (struct sockaddr*)&server_addr,sizeof(struct sockaddr)) < 0)
        perror("bind");
        close(server_fd);
        return -1;
    if(listen(server_fd, MAX_CONNECT_NUM) < 0)
        perror("listen");
        close(server_fd);
        return -1;
    return server_fd;
int tcp_accept(int server_fd)
    struct sockaddr_in client_addr = {0};
    int addrlen = sizeof(struct sockaddr);
    int new_fd = accept(server_fd, (struct sockaddr*) &client_addr, &addrlen);
    if(new_fd < 0)
        perror("accept");
        close(server_fd);
        return -1;
    return new_fd;
int tcp_connect(const char *ip, int port)
    if (server_fd < 0)
        perror("socket");
        return -1;
    if (connect(server_fd, (struct sockaddr*)&server_addr, sizeof(struct sockaddr)) < 0)
        perror("connect");
        close(server_fd);
        return -1;
    return server_fd;
int tcp_nonblocking_recv(int conn_sockfd, void *rx_buf, int buf_len, int timeval_sec, int timeval_usec)
 fd_set readset;
 struct timeval timeout = {0, 0};
 int maxfd = 0;
 int fp0 = 0;
 int recv_bytes = 0;
 int ret = 0;
 timeout.tv_sec = timeval_sec;
 timeout.tv_usec = timeval_usec;
 FD_ZERO(&readset);
 FD_SET(conn_sockfd, &readset);
 maxfd = conn_sockfd > fp0 ? (conn_sockfd+1) : (fp0+1);
 ret = select(maxfd, &readset, NULL, NULL, &timeout);
 if (ret > 0)
  if (FD_ISSET(conn_sockfd, &readset))
   if ((recv_bytes = recv(conn_sockfd, rx_buf, buf_len, MSG_DONTWAIT))== -1)
    perror("recv");
    return -1;
    else
  return -1;
 return recv_bytes;
    return recv(conn_sockfd, rx_buf, buf_len, 0);
    return send(conn_sockfd, tx_buf, buf_len, 0);
    close(sockfd);
测试代码
tcp_server.c:
int main(int argc, char **argv)
    printf("==================tcp server==================\n");
    int server_fd = tcp_init(NULL, 4321);
    if (server_fd < 0)
        printf("tcp_init error!\n");
        exit(EXIT_FAILURE);
    int client_fd = tcp_accept(server_fd);
    if (client_fd < 0)
        printf("tcp_accept error!\n");
        exit(EXIT_FAILURE);
    while (1)
        char buf[128] = {0};
        int recv_len = tcp_blocking_recv(client_fd, buf, sizeof(buf));
        if (recv_len <= 0)
            printf("recv error!\n");
            tcp_close(client_fd);
            tcp_close(server_fd);
            exit(EXIT_FAILURE);
        printf("recv : %s\n", buf);
        int send_len = tcp_send(client_fd, buf, strlen(buf));
        if (send_len <= 0)
            printf("send error!\n");
            exit(EXIT_FAILURE);
        else
            printf("send success! send: %s, send_len: %d\n", buf, send_len);
    return 0;
tcp_client.c:
    printf("==================tcp cient==================\n");
    if (argc < 3)
        printf("usage:./tcp_client ip port\n");
        exit(EXIT_FAILURE);
    char ip_buf[32] = {0};
    int port = 0;
    memcpy(ip_buf, argv[1], strlen(argv[1]));
    port = atoi(argv[2]);
    int server_fd = tcp_connect(ip_buf, port);
    if (server_fd < 0)
        printf("tcp_connect error!\n");
        exit(EXIT_FAILURE);
    while (1)
        if (scanf("%s", buf))
            int send_len = tcp_send(server_fd, buf, strlen(buf));
            if (send_len <= 0)
                printf("tcp_send error!\n");
                exit(EXIT_FAILURE);
            else
            bzero(buf, sizeof(buf));
            int recv_len = tcp_blocking_recv(server_fd, buf, sizeof(buf));
            if (recv_len <= 0)
                printf("tcp_blocking_recv error!\n");
                exit(EXIT_FAILURE);
    return 0;
测试结果:
转载自网络,如有侵权,联系删除。
