电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » rtthread硬件SPI框架解析
共3条 1/1 1 跳转至页
rtthread硬件SPI框架解析
2024-10-05 17:51:51     打赏
背景
   既然要使用SPI模块,那就得了解RTT的SPI是如何设计的,这样才能搞懂SPI的使用逻辑,以便更好的适配RTT的SPI驱动,也避免使用过程中踩雷。
SPI驱动框架解析
初级SPI
    此SPI的作用为注册不带cs的spi设备或已经带硬件cs脚的spi设备。
注册入口
     还是老思路,rt-thread源码中,bsp目录下不少芯片都有适配spi驱动(驱动文件名为drv_spi.c),因此,我们分析SPI驱动入口也从这开始查看。以GD32驱动为例,其注册入口如下:
#ifdef RT_USING_DEVICE_OPS
const static struct rt_device_ops spi_bus_ops =
    RT_NULL,
    RT_NULL,
    RT_NULL,
    _spi_bus_device_read,    // SPI读入口
    _spi_bus_device_write,   // SPI写入口
    RT_NULL
#endif
rt_err_t rt_spi_bus_device_init(struct rt_spi_bus *bus, const char *name)
    struct rt_device *device;
    RT_ASSERT(bus != RT_NULL);
    device = &bus->parent;
    /* set device type */
    device->type    = RT_Device_Class_SPIBUS;
    /* initialize device interface */
    device->ops     = &spi_bus_ops;
#else
    device->init    = RT_NULL;
    device->open    = RT_NULL;
    device->close   = RT_NULL;
    device->read    = _spi_bus_device_read;
    device->write   = _spi_bus_device_write;
    device->control = RT_NULL;
#endif
    /* register to device manager */
    return rt_device_register(device, name, RT_DEVICE_FLAG_RDWR);
rt_err_t rt_spi_bus_register(struct rt_spi_bus       *bus,
                             const char              *name,
                             const struct rt_spi_ops *ops)
    rt_err_t result;
    result = rt_spi_bus_device_init(bus, name);
    if (result != RT_EOK)
        return result;
    /* initialize mutex lock */
    rt_mutex_init(&(bus->lock), name, RT_IPC_FLAG_PRIO);
    /* set ops */
    bus->ops = ops;
    /* initialize owner */
    bus->owner = RT_NULL;
    /* set bus mode */
    bus->mode = RT_SPI_BUS_MODE_SPI;
    return RT_EOK;
static struct rt_spi_ops gd32_spi_ops =
    .configure = spi_configure, // 配置SPI参数
    .xfer = spixfer,
    // SPI数据传输
int rt_hw_spi_init(void)
    int result = 0;
    int i;
    for (i = 0; i < sizeof(spi_bus_obj) / sizeof(spi_bus_obj[0]); i++)
        spi_bus_obj[i].spi_bus->parent.user_data = (void *)&spi_bus_obj[i];
        // 注册SPI驱动入口
        result = rt_spi_bus_register(spi_bus_obj[i].spi_bus, spi_bus_obj[i].bus_name, &gd32_spi_ops);
        RT_ASSERT(result == RT_EOK);
        LOG_D("%s bus init done", spi_bus_obj[i].bus_name);
    return result;
INIT_BOARD_EXPORT(rt_hw_spi_init);
     从代码上看,spi驱动的注册,实际上也还是走到了rt_device_register,注册的设备类型为 RT_Device_Class_SPIBUS,而驱动层,向系统注册SPI设备时,需相应的实现两个接口,一个是configure,用于配置SPI工作模式,另一个时xfer,用于实现spi数据传递。
SPI读接口
     在SPI注册代码中,我们可以看到spi读的入口,其名称为_spi_bus_device_read,由于注册符合标准设备注册流程,那应用层肯定可以通过rt_device_read的方式实现读。在这里我们需向上以及向下查看,看该接口具体是如何使用的。
rt_ssize_t rt_spi_transfer(struct rt_spi_device *device,
                           const void           *send_buf,
                           void                 *recv_buf,
                           rt_size_t             length)
    rt_ssize_t result;
    struct rt_spi_message message;
    // 判断有效性
    RT_ASSERT(device != RT_NULL);
    RT_ASSERT(device->bus != RT_NULL);
    // 加锁,防止多线程调用时出现异常
    result = rt_mutex_take(&(device->bus->lock), RT_WAITING_FOREVER);
    if (result == RT_EOK)
        if (device->bus->owner != device)
            //如果spi未初始化,则初始化spi
            /* not the same owner as current, re-configure SPI bus */
            result = device->bus->ops->configure(device, &device->config);
                /* set SPI bus owner */
                device->bus->owner = device;
            else
                /* configure SPI bus failed */
                LOG_E("SPI device %s configuration failed", device->parent.parent.name);
                goto __exit;
        /* initial message */
        message.send_buf   = send_buf;
        message.recv_buf   = recv_buf;
        message.length     = length;
        message.cs_take    = 1;
        message.cs_release = 1;
        message.next       = RT_NULL;
        /* transfer message */
        result = device->bus->ops->xfer(device, &message);
        if (result < 0)
            LOG_E("SPI device %s transfer failed", device->parent.parent.name);
            goto __exit;
    else
        return -RT_EIO;
__exit:
    rt_mutex_release(&(device->bus->lock));
    return result;
static rt_ssize_t _spi_bus_device_read(rt_device_t dev,
                                      rt_off_t    pos,
                                      void       *buffer,
                                      rt_size_t   size)
    struct rt_spi_bus *bus;
    bus = (struct rt_spi_bus *)dev;
    RT_ASSERT(bus->owner != RT_NULL);
    return rt_spi_transfer(bus->owner, RT_NULL, buffer, size);
SPI写接口
     在SPI注册代码中,我们可以看到spi写的入口,其名称为_spi_bus_device_write,由于注册符合标准设备注册流程,那应用层肯定可以通过rt_device_write的方式实现读。在这里我们需向上以及向下查看,看该接口具体是如何使用的。
//rt_spi_transfer函数见读接口
static rt_ssize_t _spi_bus_device_write(rt_device_t dev,
                                       rt_off_t    pos,
                                       const void *buffer,
                                       rt_size_t   size)
    return rt_spi_transfer(bus->owner, buffer, RT_NULL, size);
rt_spi_configure 工作模式配置接口
rt_err_t rt_spi_bus_configure(struct rt_spi_device *device)
    rt_err_t result = -RT_ERROR;
    if (device->bus != RT_NULL)
            if (device->bus->owner == device)
                /* current device is using, re-configure SPI bus */
            /* release lock */
    else
        result = RT_EOK;
    return result;
rt_err_t rt_spi_configure(struct rt_spi_device        *device,
                          struct rt_spi_configuration *cfg)
    RT_ASSERT(cfg != RT_NULL);
    /* reset the CS pin */
    if (device->cs_pin != PIN_NONE)
        if (cfg->mode & RT_SPI_CS_HIGH)
            rt_pin_write(device->cs_pin, PIN_LOW);
        else
            rt_pin_write(device->cs_pin, PIN_HIGH);
    /* If the configurations are the same, we don't need to set again. */
    if (device->config.data_width == cfg->data_width &&
        device->config.mode       == (cfg->mode & RT_SPI_MODE_MASK) &&
        device->config.max_hz     == cfg->max_hz)
        return RT_EOK;
    /* set configuration */
    device->config.data_width = cfg->data_width;
    device->config.mode       = cfg->mode & RT_SPI_MODE_MASK;
    device->config.max_hz     = cfg->max_hz;
    return rt_spi_bus_configure(device);
驱动层适配框架
     经过上面的分析,已经驱动,我们需要实现configure和xfer两个入口,而由于入口少,因此入口所需要实现的功能也比较复杂,这里给出一个相对全面的模板:
configure
static rt_err_t spi_configure(struct rt_spi_device* device,
                          struct rt_spi_configuration* configuration)
    /* 设置带宽 */
    /* SPI速率设置 */
    /* SPI工作模式*/
    /*驱动特有设置*/
    /* 初始化SPI */
    return RT_EOK;
xfer
static rt_ssize_t spixfer(struct rt_spi_device *device, struct rt_spi_message *message)
    // 校验输入参数
    RT_ASSERT(message != RT_NULL);
    rt_err_t err = RT_EOK;
    if (message->cs_take && !(device->config.mode & RT_SPI_NO_CS) && (device->cs_pin != PIN_NONE))
        // 使能CS
    if (message->length > 0)
        if (message->send_buf == RT_NULL && message->recv_buf != RT_NULL)
            /**< 读取数据 */
        else if (message->send_buf != RT_NULL && message->recv_buf == RT_NULL)
            /**< 发送数据 */
        else if (message->send_buf != RT_NULL && message->recv_buf != RT_NULL)
            /**< 读写数据 */
    if (message->cs_release && !(device->config.mode & RT_SPI_NO_CS) && (device->cs_pin != PIN_NONE))
        // cs 禁用
    return err;
补充接口
     从这里看,实际上框架层已经较好的实现了SPI的写入口,既考虑到了多线程使用的场景,也考虑到了不同设备对spi接口的要求不一样的场景。但是呢,标准的rt_device_read毕竟不是那么的好理解成spi的操作。因此spi实际上还标准化了一系列的接口,以便上层调用:
rt_spi_transfer  数据单次传输接口
     这个接口在读接口中有解析,实际上就是SPI传递一次数据的实现
rt_spi_transfer_message 数据多次传输接口
struct rt_spi_message *rt_spi_transfer_message(struct rt_spi_device  *device,
    rt_err_t result;
    struct rt_spi_message *index;
    /* get first message */
    index = message;
    if (index == RT_NULL)
        return index;
        return index;
    /* configure SPI bus */
        else
            goto __exit;
    /* transmit each SPI message */
    while (index != RT_NULL)
        /* transmit SPI message */
        result = device->bus->ops->xfer(device, index);
        if (result < 0)
            break;
        index = index->next;
__exit:
    /* release bus lock */
    return index;
    从接口实现上看,其实这就是传递多次版的rt_spi_transfer实现,不过需要注意的是,多次传输,spi的数据不再是在函数内部组包,而是需要组好包后交由函数调用。
其他接口
   老实说,后面的接口,个人不太明白为什么要重复写,因为这些接口实际上都可以使用上面的两个transfer函数实现。我只能猜这些接口都是某些特定场景下的实现吧。
rt_spi_send_then_send
     发送一次数据后再发送一次数据。
rt_err_t rt_spi_send_then_send(struct rt_spi_device *device,
                               const void           *send_buf1,
                               rt_size_t             send_length1,
                               const void           *send_buf2,
                               rt_size_t             send_length2)
    rt_err_t result;
            else
                goto __exit;
        /* send data1 */
        message.send_buf   = send_buf1;
        message.recv_buf   = RT_NULL;
        message.length     = send_length1;
        message.cs_release = 0;
        if (result < 0)
            goto __exit;
        /* send data2 */
        message.send_buf   = send_buf2;
        message.length     = send_length2;
        message.cs_take    = 0;
        if (result < 0)
            goto __exit;
        result = RT_EOK;
    else
        return -RT_EIO;
__exit:
    return result;
rt_spi_send_then_recv
     发送一次数据后读一次数据
rt_err_t rt_spi_send_then_recv(struct rt_spi_device *device,
                               rt_size_t             send_length,
                               void                 *recv_buf,
                               rt_size_t             recv_length)
    rt_err_t result;
            else
                goto __exit;
        /* send data */
        message.length     = send_length;
        if (result < 0)
            goto __exit;
        /* recv data */
        message.send_buf   = RT_NULL;
        message.length     = recv_length;
        if (result < 0)
            goto __exit;
        result = RT_EOK;
    else
        return -RT_EIO;
__exit:
    return result;
rt_spi_sendrecv8
rt_err_t rt_spi_sendrecv8(struct rt_spi_device *device,
                          rt_uint8_t            senddata,
                          rt_uint8_t           *recvdata)
    rt_ssize_t len = rt_spi_transfer(device, &senddata, recvdata, 1);
    if (len < 0)
        return (rt_err_t)len;
    else
        return RT_EOK;
rt_spi_sendrecv16
rt_err_t rt_spi_sendrecv16(struct rt_spi_device *device,
                           rt_uint16_t           senddata,
                           rt_uint16_t          *recvdata)
    rt_ssize_t len;
    rt_uint16_t tmp;
    if (device->config.mode & RT_SPI_MSB)
        tmp = ((senddata & 0xff00) >> 8) | ((senddata & 0x00ff) << 8);
        senddata = tmp;
    len = rt_spi_transfer(device, &senddata, recvdata, 2);
    if(len < 0)
        tmp = ((*recvdata & 0xff00) >> 8) | ((*recvdata & 0x00ff) << 8);
        *recvdata = tmp;
    return RT_EOK;
次级spi
注册入口
      次级spi注册入口,顾名思义,在初级spi的基础上,增加一些必要信息,再次注册的spi设备。其代码如下:
const static struct rt_device_ops spi_device_ops =
    RT_NULL,
    RT_NULL,
    RT_NULL,
    _spidev_device_read,
    _spidev_device_write,
    _spidev_device_control
#endif
rt_err_t rt_spidev_device_init(struct rt_spi_device *dev, const char *name)
    RT_ASSERT(dev != RT_NULL);
    device = &(dev->parent);
    device->type    = RT_Device_Class_SPIDevice;
    device->ops     = &spi_device_ops;
#else
    device->read    = _spidev_device_read;
    device->write   = _spidev_device_write;
    device->control = _spidev_device_control;
#endif
rt_err_t rt_spi_bus_attach_device_cspin(struct rt_spi_device *device,
                                        const char           *name,
                                        const char           *bus_name,
                                        rt_base_t            cs_pin,
                                        void                 *user_data)
    rt_err_t result;
    rt_device_t bus;
    /* get physical spi bus */
    bus = rt_device_find(bus_name);
    if (bus != RT_NULL && bus->type == RT_Device_Class_SPIBUS)
        device->bus = (struct rt_spi_bus *)bus;
        /* initialize spidev device */
        result = rt_spidev_device_init(device, name);
            return result;
        if(cs_pin != PIN_NONE)
            rt_pin_mode(cs_pin, PIN_MODE_OUTPUT);
        rt_memset(&device->config, 0, sizeof(device->config));
        device->parent.user_data = user_data;
        device->cs_pin = cs_pin;
        return RT_EOK;
    /* not found the host bus */
    return -RT_ERROR;
      从实现上看,其实这个接口就是在初级spi无cs脚时,再封装一层,增加一个gpo方式实现的cs脚来保证上层应用不关注SPI的硬件配置信息。
读写入口
      实际上这个入口是通过标准设备接口实现读写的入口,但目前来看,这两个接口属于历史遗留,或者单纯为了满足标准设备框架的实现而留些来的入口。
static rt_ssize_t _spidev_device_read(rt_device_t dev,
                                     rt_off_t    pos,
                                     void       *buffer,
                                     rt_size_t   size)
    struct rt_spi_device *device;
    device = (struct rt_spi_device *)dev;
    return rt_spi_transfer(device, RT_NULL, buffer, size);
static rt_ssize_t _spidev_device_write(rt_device_t dev,
                                      rt_off_t    pos,
                                      const void *buffer,
                                      rt_size_t   size)
    return rt_spi_transfer(device, buffer, RT_NULL, size);
control入口
     其实这个入口可以去掉,因为实际无功能。
static rt_err_t _spidev_device_control(rt_device_t dev,
                                       int         cmd,
                                       void       *args)
    switch (cmd)
    case 0: /* set device */
        break;
    case 1:
        break;
    return RT_EOK;
总结
 分析到这,实际上spi设备的框架已经较为清晰了,其框图如下:
关键词: rtthread     硬件     驱动     框架     spi
2024-10-05 23:25:43     打赏
2024-10-06 21:08:42     打赏
共3条 1/1 1 跳转至页
