电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » 【米尔-瑞芯微RK3576核心板及开发板】下载和安装Anaconda
共4条 1/1 1 跳转至页
2024-12-16 19:12:31     打赏
选择安装版本:
可以选择安装 Anaconda 或 Miniconda,Anaconda 包含了大量的科学计算库和工具,而 Miniconda 仅包含 Conda 包管理器及其依赖,体积更小.
下载安装脚本:如果选择安装 Anaconda,可使用curl命令下载适合 arm 架构的 Anaconda 安装脚本,如curl -o https://repo.anaconda.com/archive/anaconda3-2023.09-0-linux-aarch64.sh;若选择 Miniconda,则下载对应的 Miniconda 安装脚本,如curl -o https://repo.anaconda.com/miniconda/Miniconda3-latest-Linux-aarch64.sh.
我选择安装Miniconda。在/userdata/下面新建下载目录,并下载好文件:
2、下载好后,执行bash Miniconda3-latest-Linux-aarch64.sh :
按回车键继续,等待阅读完协议后,输入yes同意协议:
3、此时询问是否同意安装到指定目录,输入回车键同意:
/root/miniconda3
  - Press ENTER to confirm the location
  - Press CTRL-C to abort the installation
  - Or specify a different location below
4、最后询问是同意在启动时初始化基础环境,我这里先择同意:
5、检查是否安装成功:
root@myd-lr3576x-debian:/userdata/myenv# /root/miniconda3/bin/conda -V
conda 24.9.2
6、创建虚拟环境:
root@myd-lr3576x-debian:/userdata/myenv# /root/miniconda3/bin/conda create --name myenv python=3.9
Channels:
 - defaults
Platform: linux-aarch64
Collecting package metadata (repodata.json): done
Solving environment: done
7、激活虚拟环境:
Channels:
 - defaults
## Package Plan ##
  environment location: /root/miniconda3/envs/myenv
  added / updated specs:
    - python=3.9
The following packages will be downloaded:
    package                    |            build
    ca-certificates-2024.11.26 |       hd43f75c_0         131 KB
    pip-24.2                   |   py39hd43f75c_0         2.2 MB
    python-3.9.21              |       h4bb2201_1        24.6 MB
    setuptools-75.1.0          |   py39hd43f75c_0         1.6 MB
    wheel-0.44.0               |   py39hd43f75c_0         111 KB
                                           Total:        28.7 MB
The following NEW packages will be INSTALLED:
  _libgcc_mutex      pkgs/main/linux-aarch64::_libgcc_mutex-0.1-main
  _openmp_mutex      pkgs/main/linux-aarch64::_openmp_mutex-5.1-51_gnu
  ca-certificates    pkgs/main/linux-aarch64::ca-certificates-2024.11.26-hd43f75c_0
  ld_impl_linux-aar~ pkgs/main/linux-aarch64::ld_impl_linux-aarch64-2.40-h48e3ba3_0
  libffi             pkgs/main/linux-aarch64::libffi-3.4.4-h419075a_1
  libgcc-ng          pkgs/main/linux-aarch64::libgcc-ng-11.2.0-h1234567_1
  libgomp            pkgs/main/linux-aarch64::libgomp-11.2.0-h1234567_1
  libstdcxx-ng       pkgs/main/linux-aarch64::libstdcxx-ng-11.2.0-h1234567_1
  ncurses            pkgs/main/linux-aarch64::ncurses-6.4-h419075a_0
  openssl            pkgs/main/linux-aarch64::openssl-3.0.15-h998d150_0
  pip                pkgs/main/linux-aarch64::pip-24.2-py39hd43f75c_0
  python             pkgs/main/linux-aarch64::python-3.9.21-h4bb2201_1
  readline           pkgs/main/linux-aarch64::readline-8.2-h998d150_0
  setuptools         pkgs/main/linux-aarch64::setuptools-75.1.0-py39hd43f75c_0
  sqlite             pkgs/main/linux-aarch64::sqlite-3.45.3-h998d150_0
  tk                 pkgs/main/linux-aarch64::tk-8.6.14-h987d8db_0
  tzdata             pkgs/main/noarch::tzdata-2024b-h04d1e81_0
  wheel              pkgs/main/linux-aarch64::wheel-0.44.0-py39hd43f75c_0
  xz                 pkgs/main/linux-aarch64::xz-5.4.6-h998d150_1
  zlib               pkgs/main/linux-aarch64::zlib-1.2.13-h998d150_1
Proceed ([y]/n)? y
Downloading and Extracting Packages:
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
# To activate this environment, use
#     $ conda activate myenv
# To deactivate an active environment, use
#     $ conda deactivate
8、进入虚拟环境:
(base) root@myd-lr3576x-debian:~# conda activate myenv
(myenv) root@myd-lr3576x-debian:~# cd /userdata/myenv/
【总结】
到此基于米尔RK3576的miniconda环境就安装好了。
关键词: 米     米尔     瑞芯     RK3576          Anaconda
2024-12-16 19:24:56     打赏
学习学习!
2024-12-16 21:18:48     打赏
2024-12-16 21:19:23     打赏
共4条 1/1 1 跳转至页
