电子产品世界 » 论坛首页 » 行业应用 » 汽车电子 » 【S32K146】S32K146片内RTC使用
2025-06-27 09:15:20     打赏
【简介】
S32K146 芯片内部集成了RTC 定时器,我们可以使用内部的RTC 来实现实时时钟的使用。RTC 模块的特性描述如下:
【S32DS时钟配置】
RTC 模块有多路时钟源可以配置,本地使用LPO128K 的四分频作为RTC 的工作时钟,配置如下
【S32DS RTC 参数配置】
生成如下初始化代码
 * This file was generated by the S32 Configuration Tools. Any manual edits made to this file
 * will be overwritten if the respective S32 Configuration Tools is used to update this file.
/* clang-format off */
/* TEXT BELOW IS USED AS SETTING FOR TOOLS *************************************
!!GlobalInfo
product: Peripherals v14.0
processor: S32K146
package_id: S32K146_LQFP144
mcu_data: s32sdk_s32k1xx_rtm_401
processor_version: 0.0.0
functionalGroups:
- name: BOARD_InitPeripherals
  UUID: 2d0c0af7-dbe7-4f00-821a-837510d6ab4e
  called_from_default_init: true
  selectedCore: core0
 * BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS **********/
/* clang-format on */
 * Included files
#include "peripherals_rtc_1.h"
 * rtc_1 initialization code
instance:
- name: 'rtc_1'
- type: 'rtc_config'
- mode: 'rtcDriver'
- custom_name_enabled: 'false'
- type_id: 'rtc'
- functional_group: 'BOARD_InitPeripherals'
- peripheral: 'RTC'
- config_sets:
  - rtc_driver:
    - rtcInitConfig:
      - 0:
        - init:
          - name: 'rtc_1InitCfg0'
          - readonly: 'true'
          - updateEnable: 'false'
          - nonSupervisorAccessEnable: 'false'
          - compensationEnable: 'false'
          - compensationInterval: '0'
          - compensation: '0'
          - clockSelect: 'RTC_CLK_SRC_LPO_1KHZ'
          - clockOutConfig: 'RTC_CLKOUT_DISABLED'
        - date:
          - 0:
            - year: '1970'
            - month: '1'
            - day: '1'
            - hour: '0'
            - minutes: '0'
            - seconds: '0'
    - rtcLockConfig:
      - 0:
        - enableCfg: 'true'
        - name: 'rtc_1LockCfg0'
        - readonly: 'true'
        - lockRegisterLock: 'false'
        - statusRegisterLock: 'false'
        - controlRegisterLock: 'false'
        - timeCompensationRegisterLock: 'false'
    - rtcAlarmConfig:
      - 0:
        - enableCfg: 'true'
        - name: 'rtc_1AlarmCfg0'
        - alarmTime:
          - 0:
            - year: '1970'
            - month: '1'
            - day: '1'
            - hour: '0'
            - minutes: '0'
            - seconds: '0'
        - repeat: 'false'
        - repeatForever: 'false'
        - repetitionInterval: '0'
        - numberOfRepeats: '0'
        - alarmIntEnable: 'false'
        - alarmCallback: 'NULL'
    - rtcTSIConfig:
      - 0:
        - enableCfg: 'true'
        - name: 'rtc_1SecIntCfg0'
        - secondIntConfig: 'RTC_INT_1HZ'
        - secondIntEnable: 'false'
        - rtcSecondsCallback: 'NULL'
    - rtcFaultConfig:
      - 0:
        - enableCfg: 'true'
        - name: 'rtc_1FaultCfg0'
        - overflowIntEnable: 'false'
        - timeInvalidIntEnable: 'false'
        - rtcCallback: 'NULL'
 * @page misra_violations MISRA-C:2012 violations
 * @section [global]
 * Violates MISRA 2012 Advisory Rule 2.5, Global macro not referenced.
 * The global macro will be used in function call of the module.
 * @section [global]
 * Violates MISRA 2012 Advisory Rule 8.7, External variable could be made static.
 * The external variables will be used in other source files in application code.
 * RTC Initialization configurations
/*! rtc_1InitCfg0 instance initialization configuration */
const rtc_init_config_t rtc_1InitCfg0 = {
  .updateEnable = false,
  .nonSupervisorAccessEnable = false,
  .compensationInterval = 0U,
  .compensation = 0,
  .clockSelect = RTC_CLK_SRC_LPO_1KHZ,
  .clockOutConfig = RTC_CLKOUT_DISABLED
/*! rtc_1InitCfg0_StartTime Initial Time and Date */
const rtc_timedate_t rtc_1InitCfg0_StartTime  = {
  .year = 1970U,
  .month = 1U,
  .day = 1U,
  .hour = 0U,
  .minutes = 0U,
  .seconds = 0U
 * RTC Register Lock configurations
/*! rtc_1LockCfg0 register lock configuration */
const rtc_register_lock_config_t rtc_1LockCfg0 = {
  .lockRegisterLock = false,
  .statusRegisterLock = false,
  .controlRegisterLock = false,
  .timeCompensationRegisterLock = false
 * RTC Alarm configurations
/*! rtc_1AlarmCfg0 alarm configuration */
rtc_alarm_config_t rtc_1AlarmCfg0 = {
  .alarmTime = {
    .year = 1970U,
    .month = 1U,
    .day = 1U,
    .hour = 0U,
    .minutes = 0U,
    .seconds = 0U
  .repeatForever = false,
  .repetitionInterval = 0UL,
  .numberOfRepeats = 0UL,
  .alarmIntEnable = false,
  .callbackParams = NULL,
  .alarmCallback = NULL
 * RTC Time Seconds Interrupt configurations
/*! rtc_1SecIntCfg0 time seconds configuration */
rtc_seconds_int_config_t rtc_1SecIntCfg0 = {
  .secondIntConfig = RTC_INT_1HZ,
  .secondIntEnable = false,
  .secondsCallbackParams = NULL,
  .rtcSecondsCallback = NULL
 * RTC Fault interrupt configurations
/*! rtc_1FaultCfg0 fault configuration */
rtc_interrupt_config_t rtc_1FaultCfg0 = {
  .overflowIntEnable = false,
  .timeInvalidIntEnable = false,
  .rtcCallback = NULL
【代码验证】
添加如下代码初始化RTC
static int rtc_init(void)
    status_t ret;
    /* Call the init function */
    ret = RTC_DRV_Init(RTC_1, &rtc_1InitCfg0);
    if(ret != STATUS_SUCCESS)
        LOG_E("RTC init failed %x.",ret);
    else
        LOG_I("RTC init OK.");
    /* Set the time and date */
    ret = RTC_DRV_SetTimeDate(RTC_1, &rtc_1InitCfg0_StartTime);
        LOG_E("RTC set time failed %x.",ret);
    else
        LOG_I("RTC set time OK.");
    /* Start RTC counter */
    ret = RTC_DRV_StartCounter(RTC_1);
        LOG_E("RTC start failed %x.",ret);
    else
        LOG_I("RTC start OK.");
    return 1;
INIT_BOARD_EXPORT_LEVEL1(rtc_init);
添加如下代码输出RTC时间
unsigned int  date(char argc,char *argv[])
    status_t ret;
    rtc_timedate_t  currentTime;
    ret = RTC_DRV_GetCurrentTimeDate ( RTC_1, &currentTime );
    else
        LOG_I("%d:%d:%d %d:%d:%d",currentTime.year,currentTime.month,currentTime.day,
                                  currentTime.hour,currentTime.minutes,currentTime.seconds);
    return 0;
连续读取RTC 时间发现RTC 计数器已经在持续变化更新。
更新测试代码添加RTC 时间设置,设置时间后读取RTC 时间已经按预期的设置成功
    status_t ret;
    if(argc == 1)
            LOG_E("RTC read failed %x.",ret);
        else
    if(argc == 7)
        ret = RTC_DRV_StopCounter(RTC_1);
            LOG_E("RTC stop failed %x.",ret);
        currentTime.year = atoi(argv[1]);
        currentTime.month = atoi(argv[2]);
        currentTime.day = atoi(argv[3]);
        currentTime.hour = atoi(argv[4]);
        currentTime.minutes = atoi(argv[5]);
        currentTime.seconds = atoi(argv[6]);
        ret = RTC_DRV_SetTimeDate(RTC_1, &currentTime);
    return 0;
