电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » MAX78000使用硬件SPI驱动ST7796
2025-08-12 19:09:12     打赏
MAX78000使用硬件SPI驱动ST7796LCD屏一、max7800与LCD屏的连接
* SCK  P0_7
* MOSI P0_5
* CS   P0_11
* DC   P1_6
* RST  P0-19
其中sck、mosi是使用SPI0这个通道,CS选用SS1即P0_11。
【注意】由于max硬件spi的时钟与MOSI会在正式发送数据之前会有一个方波,因此必须使用硬件CS来配合才能正常。经用逻辑分析仪查看他的时序如下:
DC与RST做为普通GPIO输出即可,BL目前采用直接接VCC3.3V开机即亮。
二、SPI初始化
在max78000的SDK中提供了很多的常用屏的现成驱动,有但是没有st7796的驱动,因此我们可以借用SDK中的屏驱动来学习。
1、宏定义
#define TFT_SPI_FREQ 25000000 // spi 总线线速度25MHz
#define TFT_SPI0_PINS MXC_GPIO_PIN_5 | MXC_GPIO_PIN_6 | MXC_GPIO_PIN_7 | MXC_GPIO_PIN_11
#define DC_SET     MXC_GPIO_OutSet(DC_PORT,DC_PIN)
#define DC_CLR     MXC_GPIO_OutClr(DC_PORT,DC_PIN)
#define RST_SET    MXC_GPIO_OutSet(RST_PORT,RST_PIN)
#define RST_CLR    MXC_GPIO_OutClr(RST_PORT,RST_PIN)
2、spi初始化
static void tft_spi_init(void)
#if SOFT_SPI
mxc_gpio_cfg_t gpio_out;
   gpio_out.port = DC_PORT;
gpio_out.mask = DC_PIN;
gpio_out.pad = MXC_GPIO_PAD_NONE;
gpio_out.func = MXC_GPIO_FUNC_OUT;
gpio_out.vssel = MXC_GPIO_VSSEL_VDDIOH;
gpio_out.drvstr = MXC_GPIO_DRVSTR_0;
MXC_GPIO_Config(&gpio_out);
   gpio_out.port = SCK_PORT;
gpio_out.mask = SCK_PIN;
   gpio_out.port = MOSI_PORT;
gpio_out.mask = MOSI_PIN;
   gpio_out.port = CS_PORT;
gpio_out.mask = CS_PIN;
   gpio_out.port = RST_PORT;
gpio_out.mask = RST_PIN;
DC_CLR;
CS_SET;
SCK_CLR;
RST_SET;
#else
int master = 1;
int quadMode = 0;
int numSlaves = 2;
int ssPol = 0;
unsigned int tft_hz = TFT_SPI_FREQ;
mxc_spi_pins_t tft_pins;
   tft_pins.clock = true;
   tft_pins.ss0 = (ssel == 0); ///< Slave select pin 0
   tft_pins.ss1 = (ssel == 1); ///< Slave select pin 1
   tft_pins.ss2 = (ssel == 2); ///< Slave select pin 2
   tft_pins.miso = true; ///< miso pin
   tft_pins.mosi = true; ///< mosi pin
   tft_pins.sdio2 = false; ///< SDIO2 pin
   tft_pins.sdio3 = false; ///< SDIO3 pin
   spi = MXC_SPI0;
MXC_SPI_Init(spi, master, quadMode, numSlaves, ssPol, tft_hz, tft_pins);
   // Set  SPI0 pins to VDDIOH (3.3V) to be compatible with TFT display
MXC_GPIO_SetVSSEL(MXC_GPIO0, MXC_GPIO_VSSEL_VDDIOH, TFT_SPI0_PINS);
MXC_SPI_SetDataSize(spi, 8);
MXC_SPI_SetWidth(spi, SPI_WIDTH_STANDARD);
CS_SET;
#endif
在这个函数中,我使用条件编译添加要spi的硬件初始化,设置DMA中断发送,8位数据宽度发送。
3、st7796的数据发送
static void spi_transmit(void* datain, unsigned int count)
unsigned int            offset;
unsigned int            fifo;
volatile unsigned short* u16ptrin = (volatile unsigned short*) datain;
unsigned int             start = 0;
   // HW requires disabling/renabling SPI block at end of each transaction (when SS is inactive).
   spi->ctrl0 &= ~(MXC_F_SPI_CTRL0_EN);
   // Setup the slave select
   MXC_SETFIELD(spi->ctrl0, MXC_F_SPI_CTRL0_SS_ACTIVE, ((1 << ssel) << MXC_F_SPI_CTRL0_SS_ACTIVE_POS));
   // number of RX Char is 0xffff
   spi->ctrl1 &= ~(MXC_F_SPI_CTRL1_RX_NUM_CHAR);
   //DMA RX FIFO disabled
   spi->dma &= ~(MXC_F_SPI_DMA_RX_FIFO_EN);
   // set number of char to be transmit
   MXC_SETFIELD(spi->ctrl1, MXC_F_SPI_CTRL1_TX_NUM_CHAR, count << MXC_F_SPI_CTRL1_TX_NUM_CHAR_POS);
   // DMA TX fifo enable
   spi->dma |= MXC_F_SPI_DMA_TX_FIFO_EN;
   /* Clear TX and RX FIFO in DMA
       TX: Set this bit to clear the TX FIFO and all TX FIFO flags in the QSPIn_INT_FL register.
           Note: The TX FIFO should be disabled (QSPIn_DMA.tx_fifo_en = 0) prior to setting this field.
           Note: Setting this field to 0 has no effect.
       RX: Clear the RX FIFO and any pending RX FIFO flags in QSPIn_INTFL.
           This should be done when the RX FIFO is inactive.
   spi->dma   |= (MXC_F_SPI_DMA_TX_FLUSH | MXC_F_SPI_DMA_RX_FLUSH);
   // QSPIn port is enabled
   spi->ctrl0 |= (MXC_F_SPI_CTRL0_EN);
   // Clear master done flag
   spi->intfl = MXC_F_SPI_INTFL_MST_DONE;
   /* Loop until all data is transmitted */
   offset = 0;
do {
       fifo = (count > 8) ? 8 : count;
       count -= fifo;
while (fifo > 0) {
           /* Send data */
           spi->fifo16[0] = u16ptrin[offset];
           offset++;
           fifo--;
           Master Start Data Transmission
               Set this field to 1 to start a SPI master mode transaction.
               0: No master mode transaction active.
               1: Master initiates a data transmission. Ensure that all pending transactions are
               complete before setting this field to 1.
               Note: This field is only used when the QSPIn is configured for Master Mode
               (QSPIn_CTRL0.master = 1).
if (start == 0) {
           spi->ctrl0 |= MXC_F_SPI_CTRL0_START;
           start = 1;
       /* Wait for data transmitting complete and then Deasserts nSS I/O */
       // Deassert slave select at the end of the transaction
       spi->ctrl0 &= ~MXC_F_SPI_CTRL0_SS_CTRL;
while (count);
while (!(spi->intfl & MXC_F_SPI_INTFL_MST_DONE)) {
       // wait until done
return;
4、然后修改相关的命令、数据发送就行了。
## 四、软件与硬件效果对比
使用逻辑分析仪对软件、硬件的sck时序对比,发送速度软件经过优化后最高可以工作到1MHZ
硬件SPI可以达到28MHz
关键词: MAX78000     ST7796     驱动SPI
