电子产品世界 » 论坛首页 » 行业应用 » 汽车电子 » 【S32K3XX】串口接收不响应问题确认
2025-09-28 08:54:16     打赏
【问题现象】
本地使用S32K328 芯片时使用的UART中断的方式接收数据,偶发的串口无法接收。
【问题调查】
复现问题的时候本地attach 到板子上查UART 的寄存器发现控制寄存器的串口接收中断被关闭了。
知道了问题原因,我们就可以针对该问题进行调查确认,我们可以这对该寄存器下数据断点查看何发生了改写。
本地复现问题发现是触发了串口ERROR异常,从而关闭了串口接收中断
以下是uart 错误异常的处理代码,检测到错误事件后会清除对应的事件,并关闭接收处理同时调用event callback 函数通知应用层。
static void Lpuart_Uart_Ip_ErrIrqHandler(const uint8 Instance)
Lpuart_Uart_Ip_StateStructureType * UartState;
const Lpuart_Uart_Ip_UserConfigType *UartUserCfg;
LPUART_Type * Base;
boolean IsError = FALSE;
boolean IsReturn = FALSE;
Base = Lpuart_Uart_Ip_apBases[Instance];
UartState = (Lpuart_Uart_Ip_StateStructureType *)Lpuart_Uart_Ip_apStateStructuresArray[Instance];
UartUserCfg = Lpuart_Uart_Ip_apUserConfig[Instance];
/* Handle receive overrun interrupt */
if (Lpuart_Uart_Ip_GetStatusFlag(Base, LPUART_UART_IP_RX_OVERRUN))
if (!Lpuart_Uart_Ip_GetIntMode(Base, LPUART_UART_IP_INT_RX_OVERRUN))
IsReturn = TRUE;
else
/* Update the status */
IsError = TRUE;
UartState->ReceiveStatus = LPUART_UART_IP_STATUS_RX_OVERRUN;
/* Clear the flag */
Lpuart_Uart_Ip_ClearStatusFlag(Base, LPUART_UART_IP_RX_OVERRUN);
/* Handle framing error interrupt */
if (Lpuart_Uart_Ip_GetStatusFlag(Base, LPUART_UART_IP_FRAME_ERR) && (FALSE == IsReturn))
if (!Lpuart_Uart_Ip_GetIntMode(Base, LPUART_UART_IP_INT_FRAME_ERR_FLAG))
IsReturn = TRUE;
else
IsError = TRUE;
UartState->ReceiveStatus = LPUART_UART_IP_STATUS_FRAMING_ERROR;
Lpuart_Uart_Ip_ClearStatusFlag(Base, LPUART_UART_IP_FRAME_ERR);
/* Handle parity error interrupt */
if (Lpuart_Uart_Ip_GetStatusFlag(Base, LPUART_UART_IP_PARITY_ERR) && (FALSE == IsReturn))
if (!Lpuart_Uart_Ip_GetIntMode(Base, LPUART_UART_IP_INT_PARITY_ERR_FLAG))
IsReturn = TRUE;
else
IsError = TRUE;
UartState->ReceiveStatus = LPUART_UART_IP_STATUS_PARITY_ERROR;
Lpuart_Uart_Ip_ClearStatusFlag(Base, LPUART_UART_IP_PARITY_ERR);
/* Handle noise error interrupt */
if (Lpuart_Uart_Ip_GetStatusFlag(Base, LPUART_UART_IP_NOISE_DETECT) && (FALSE == IsReturn))
if (!Lpuart_Uart_Ip_GetIntMode(Base, LPUART_UART_IP_INT_NOISE_ERR_FLAG))
IsReturn = TRUE;
else
/* Update the internal status */
IsError = TRUE;
UartState->ReceiveStatus = LPUART_UART_IP_STATUS_NOISE_ERROR;
Lpuart_Uart_Ip_ClearStatusFlag(Base, LPUART_UART_IP_NOISE_DETECT);
#if (LPUART_UART_IP_ENABLE_TIMEOUT_INTERRUPT == STD_ON)
/* Handle the error interrupts if timeout error */
if (Lpuart_Uart_Ip_GetStatusFlag(Base, LPUART_UART_IP_TIMEOUT) && (FALSE == IsReturn))
/* This checking also ensures that the feature is activated for the current instance
         * because the Interrupt can be enabled only in this case.
if (Lpuart_Uart_Ip_GetIntMode(Base, LPUART_UART_IP_INT_TIMEOUT))
IsError = TRUE;
UartState->ReceiveStatus = LPUART_UART_IP_STATUS_RX_IDLE_STATE;
/* Clear Timeout Interrupt Error flag */
Lpuart_Uart_Ip_ClearStatusFlag(Base, LPUART_UART_IP_TIMEOUT);
else
IsReturn = TRUE;
#endif
if (FALSE == IsReturn)
if (TRUE == IsError)
if (LPUART_UART_IP_USING_INTERRUPTS == UartUserCfg->TransferType)
/* Complete the transfer (disable rx logic) */
Lpuart_Uart_Ip_CompleteReceiveDataUsingInt(Instance);
#if (LPUART_UART_IP_HAS_DMA_ENABLED == STD_ON)
else
/* Complete the transfer (stop DMA channel) */
(void)Dma_Ip_SetLogicChannelCommand(UartUserCfg->RxDMAChannel, DMA_IP_CH_CLEAR_HARDWARE_REQUEST);
Lpuart_Uart_Ip_CompleteReceiveUsingDma(Instance);
#endif
/* Invoke callback if there is one */
if (UartUserCfg->Callback != NULL_PTR)
if (LPUART_UART_IP_STATUS_RX_IDLE_STATE == UartState->ReceiveStatus)
UartUserCfg->Callback(Instance, LPUART_UART_IP_EVENT_IDLE_STATE, UartUserCfg->CallbackParam);
else
#endif
UartUserCfg->Callback(Instance, LPUART_UART_IP_EVENT_ERROR, UartUserCfg->CallbackParam);
知道了问题原因后我们就可以在针对该问题添加策略了,串口接收错误事件会通过callback 函数上报给用户,我们可以在里面检测错误事件并开启串口中断。
修改代码后串口异常关闭问题已经被解决。
关键词: S32K3学习整理
