【简介】
从芯片的框图中AES模块中集成TRNG 模块来产生真随机数服务。
以下是文档中对真随机数发生器的描述
我们使用如下代码验证真随机数发生器的功能。
/** * @file main.c * @brief True Random Number Generator (TRNG) example * @details */ /****************************************************************************** * * Copyright (C) 2022-2023 Maxim Integrated Products, Inc. (now owned by * Analog Devices, Inc.), * Copyright (C) 2023-2024 Analog Devices, Inc. * * Licensed under the Apache License, Version 2.0 (the "License"); * you may not use this file except in compliance with the License. * You may obtain a copy of the License at * * http://www.apache.org/licenses/LICENSE-2.0 * * Unless required by applicable law or agreed to in writing, software * distributed under the License is distributed on an "AS IS" BASIS, * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. * See the License for the specific language governing permissions and * limitations under the License. * ******************************************************************************/ #include <stdio.h> #include <stdint.h> #include <string.h> #include "mxc_device.h" #include "nvic_table.h" #include "trng.h" volatile int wait; volatile int callback_result; /***** Globals *****/ uint8_t var_rnd_no[16] = { 0 }; void TRNG_IRQHandler(void) { MXC_TRNG_Handler(); } void Test_Callback(void *req, int result) { wait = 0; callback_result = result; } void print(char *stuff) { int i, j, size = 4; for (i = 0; i < 4; ++i) { for (j = 0; j < 4; ++j) { printf("0x%02x ", stuff[i * size + j]); } printf("\n"); } return; } void Test_TRNG(int asynchronous) { printf(asynchronous ? "\nTest TRNG Async\n" : "\nTest TRNG Sync\n"); int num_bytes = 16; memset(var_rnd_no, 0, sizeof(var_rnd_no)); MXC_TRNG_Init(); if (asynchronous) { wait = 1; NVIC_EnableIRQ(TRNG_IRQn); MXC_TRNG_RandomAsync(var_rnd_no, num_bytes, &Test_Callback); while (wait) {} } else { MXC_TRNG_Random(var_rnd_no, num_bytes); } print((char *)var_rnd_no); MXC_TRNG_Shutdown(); } int main(void) { printf("\n\n********** TRNG Example **********\n"); Test_TRNG(0); Test_TRNG(1); printf("\n********** Test Complete **********\n"); return 0; }
上述代码运行后产同步和中断方式产生四组随机数打印输出如下
