电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【M5CoreS3测评】网络图传
【M5CoreS3测评】网络图传
2025-10-12 10:51:33     打赏
在Arduino中安装了M5Stack的相关库之后,就有了网络图传的相关工程,其工程路径为ESP32 -> Camera -> CameraWebServer
然而在官方给出的例程中,定义的摄像头是基于OV2640、OV3660以及OV5640的,而M5CoreS3的摄像头是基于GC0308的,因此需要对官方例程进行一定的修改
首先是摄像头引脚定义,根据M5CoreS3的原理图,可以得到摄像头对应引脚
Sch_M5_CoreS3_v1.0.pdf
在camera_pins.h中添加以下代码,填写自己的WiFi名称和WiFi密码。需要注意的是ESP32S3并不支持5G网络,因此选择网络的时候需要选择2.4G的WiFi
#elif defined(CAMERA_MODEL_M5STACK_CORES3)
#define PWDN_GPIO_NUM  -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM  2
#define SIOD_GPIO_NUM  12
#define SIOC_GPIO_NUM  11
#define Y9_GPIO_NUM    47
#define Y8_GPIO_NUM    48
#define Y7_GPIO_NUM    16
#define Y6_GPIO_NUM    15
#define Y5_GPIO_NUM    42
#define Y4_GPIO_NUM    41
#define Y3_GPIO_NUM    40
#define Y2_GPIO_NUM    39
#define VSYNC_GPIO_NUM 46
#define HREF_GPIO_NUM  38
#define PCLK_GPIO_NUM  45
接着在board_config.h中添加宏定义启用M5CoreS3的摄像头
#define CAMERA_MODEL_M5STACK_CORES3
编写CameraWebServer.ino如下,特别需要注意的是,需要引入头文件<M5CoreS3.h>,才能实现开发板相关功能的调用
#include <M5CoreS3.h>
#include "esp_camera.h"
#include <WiFi.h>
// Select camera model in board_config.h
#include "board_config.h"
// Enter your WiFi credentials
const char *ssid = "******";
const char *password = "******";
void startCameraServer();
void setupLedFlash();
void setup() {
  auto cfg = M5.config();
  CoreS3.begin(cfg);
  delay(2000);
  Serial.setDebugOutput(true);
  Serial.println("hello");
  M5.Lcd.println("hello");
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_QVGA;      // FRAMESIZE_VGA is slow
  config.pixel_format = PIXFORMAT_RGB565;  // GC0308 doesn't support JPEG
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.fb_count = 2;
  config.sccb_i2c_port = M5.In_I2C.getPort();
  M5.In_I2C.release();
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x.", err);
    M5.Lcd.printf("Camera init failed with error 0x%x.", err);
    return;
  Serial.println("Camera init ok.");
  M5.Lcd.println("Camera init ok.");
  sensor_t *s = esp_camera_sensor_get();
  if (s == NULL) {
    Serial.println("No camera sensor found!");
    M5.Lcd.println("No camera sensor found!");
    return;
  Serial.println("Camera sensor found.");
  M5.Lcd.println("Camera sensor found.");
  if (s->id.PID != GC0308_PID) {
    Serial.printf("Wrong camera PID: 0x%x. Should be: 0x%x.\n", s->id.PID, GC0308_PID);
    M5.Lcd.printf("Wrong camera PID: 0x%x. Should be: 0x%x.\n", s->id.PID, GC0308_PID);
  Serial.printf("Camera PID: 0x%x GC0308_PID: 0x%x.\n", s->id.PID, GC0308_PID); // GC0308_PID
  M5.Lcd.printf("Camera PID: 0x%x GC0308_PID: 0x%x.\n", s->id.PID, GC0308_PID); // GC0308_PID
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
    M5.Lcd.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  M5.Lcd.println("");
  M5.Lcd.println("WiFi connected");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
  M5.Lcd.print("Camera Ready! Use 'http://");
  M5.Lcd.print(WiFi.localIP());
  M5.Lcd.println("' to connect");
void loop() {
  // Do nothing. Everything is done in another task by the web server
  delay(10000);
完成代码烧录后,开发板显示屏上会显示网址
保证电脑端和开发板处于同一网址,输入网址信息启动视频流显示内容如下
工程代码如下
CameraWebServer.zip
关键词: GC0308     网络图传     M5CoreS3
