电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 任务一:TCS3200拾色传感器及显示色块(ai生成)
2025-12-19 10:28:00     打赏
我参考了这位仁兄的代码
https://forum.eepw.com.cn/thread/397762/1
实现了拾色传感器的功能
因为之前做stm32搞C的,不大会python,所以用ai生成了一个识别颜色,显示色块的功能,但是显示的颜色有点问题。
代码如下
import board
import digitalio
import time
import displayio
import terminalio
from adafruit_display_text import label
# 定义按键变量
Button0_Value = 0
Button1_Value = 0
Button2_Value = 0
# 简单的移动平均平滑
class SimpleSmoother:
    """简单的移动平均平滑器,减少数值跳动"""
    def __init__(self, alpha=0.5):
        self.alpha = alpha  # 平滑系数 (0-1),越小越平滑
        self.r_smooth = 0
        self.g_smooth = 0
        self.b_smooth = 0
        self.initialized = False
    def smooth(self, r, g, b):
        """对RGB值进行平滑处理"""
        if not self.initialized:
            self.r_smooth = r
            self.g_smooth = g
            self.b_smooth = b
            self.initialized = True
        else:
            self.r_smooth = self.r_smooth * (1 - self.alpha) + r * self.alpha
            self.g_smooth = self.g_smooth * (1 - self.alpha) + g * self.alpha
            self.b_smooth = self.b_smooth * (1 - self.alpha) + b * self.alpha
        return int(self.r_smooth), int(self.g_smooth), int(self.b_smooth)
    def reset(self):
        """重置平滑器"""
def rgb888_to_rgb565(r, g, b):
    将24位RGB888格式转换为16位RGB565格式
    用于CircuitPython的displayio颜色显示
    # 限制在0-255范围
    r = max(0, min(255, r))
    g = max(0, min(255, g))
    b = max(0, min(255, b))
    # 转换为RGB565
    r5 = (r >> 3) & 0x1F  # 取高5位
    g6 = (g >> 2) & 0x3F  # 取高6位
    b5 = (b >> 3) & 0x1F  # 取高5位
    return (r5 << 11) | (g6 << 5) | b5
class TCS3200:
    NUM_CYCLES = 10  # 测试多少个周期
    def __init__(self, s0_pin, s1_pin, s2_pin, s3_pin, out_pin):
        # 初始化控制引脚
        self.s0 = digitalio.DigitalInOut(s0_pin)
        self.s1 = digitalio.DigitalInOut(s1_pin)
        self.s2 = digitalio.DigitalInOut(s2_pin)
        self.s3 = digitalio.DigitalInOut(s3_pin)
        self.out = digitalio.DigitalInOut(out_pin)
        # 配置引脚方向
        self.s0.direction = digitalio.Direction.OUTPUT
        self.s1.direction = digitalio.Direction.OUTPUT
        self.s2.direction = digitalio.Direction.OUTPUT
        self.s3.direction = digitalio.Direction.OUTPUT
        self.out.direction = digitalio.Direction.INPUT
        # 设置频率缩放比为100% (最高精度)
        self.set_frequency_scaling(100)
        # 白平衡校准系数 (初始值为1,需要实际校准)
        self.r_scal = 1.0
        self.g_scal = 1.0
        self.b_scal = 1.0
        print("TCS3200传感器初始化完成")
    def set_frequency_scaling(self, scaling):
        设置传感器的频率缩放比例
        # s0  s1
        # L   L   关闭
        # L   H   2%
        # H   L   20%
        # H   H   100%
        if scaling == 2:       # 2%
            self.s0.value = False
            self.s1.value = True
            # print("TCS3200传感器设置频率缩放比为:%2 -> s0,s1[0,1]")
        elif scaling == 20:    # 20%
            self.s0.value = True
            self.s1.value = False
            # print("TCS3200传感器设置频率缩放比为:%20 -> s0,s1[1,0]")
        elif scaling == 100:   # 100%
            # print("TCS3200传感器设置频率缩放比为:%100 -> s0,s1[1,1]")
        else:                  # 关闭
            # print("TCS3200传感器设置频率缩放比为:%0 -> s0,s1[0,0]")
        time.sleep(0.01)       # 短暂延时稳定频率缩放比例
    def set_color_filter(self, filter_type):
        设置传感器的颜色滤波器
        # s2  s3
        # L   L   Red
        # H   H   Green
        # L   H   Blue
        # H   L   Clear(no filter)
        if filter_type == "Red":
            self.s2.value = False
            self.s3.value = False
            # print("TCS3200传感器设置颜色滤波器为:Red -> s2,s3[0,0]")
        elif filter_type == "Green":
            self.s2.value = True
            self.s3.value = True
            # print("TCS3200传感器设置颜色滤波器为:Green -> s2,s3[1,1]")
        elif filter_type == "Blue":
            # print("TCS3200传感器设置颜色滤波器为:Blue -> s2,s3[0,1]")
        else:  # "Clear"
            # print("TCS3200传感器设置颜色滤波器为:Clear -> s2,s3[1,0]")
        time.sleep(0.01)       # 短暂延时稳定滤波器
    def measure_frequency(self):
        # 测量频率,并转换单位为Hz
        timestamps = []
        last_state = self.out.value
        while len(timestamps) < self.NUM_CYCLES:
            current_state = self.out.value
            if current_state != last_state:  # 发生边缘变化
                timestamps.append(time.monotonic_ns())
                last_state = current_state
        # 计数周期
        periods = []
        for i in range(2, len(timestamps), 2):
            period_ns = timestamps[i] - timestamps[i - 2]  # 一个完整周期(两个边缘)
            periods.append(period_ns)
        avg_period_ns = sum(periods) / len(periods)
        frequency = 1000000000 / avg_period_ns  # 转换为 Hz
        # print(f"原始频率值 -> Frequency:{frequency:.3f}")
        return frequency
    def read_rgb_freq(self):
        # 读取RGB三个通道的频率值
        red_freq = 0
        green_freq = 0
        blue_freq = 0
        # 读取红色分量 (S2=0, S3=0)
        self.set_color_filter("Red")
        red_freq = self.measure_frequency()
        # 读取绿色分量 (S2=1, S3=1)
        self.set_color_filter("Green")
        green_freq = self.measure_frequency()
        # 读取蓝色分量 (S2=0, S3=1)
        self.set_color_filter("Blue")
        blue_freq = self.measure_frequency()
        # 清除绿色分量 (S2=1, S3=0)
        # self.set_color_filter("Clear")
        # print(f"原始频率值 -> R:{red_freq:.3f}, G:{green_freq:.3f}, B:{blue_freq:.3f}")
        return red_freq, green_freq, blue_freq
    def calibrate_white_balance(self):
        # 白平衡校准 - 将传感器对准白色参考物后调用此方法
        print("正在进行白平衡校准...")
        print("请将传感器对准白色参考物")
        # 读取白色参考物的原始频率
        red, green, blue = self.read_rgb_freq()
        # 换算为RGB值 (18000/255 = 70)
        red = red / 70 if red > 0 else 1.0
        green = green / 70 if green > 0 else 1.0
        blue = blue / 70 if blue > 0 else 1.0
        # 计算校准系数 (假设我们希望白色时RGB值接近255)
        self.r_scal = 255.0 / red if red > 0 else 1.0
        self.g_scal = 255.0 / green if green > 0 else 1.0
        self.b_scal = 255.0 / blue if blue > 0 else 1.0
        print(f"校准完成 -> R:{self.r_scal:.3f}, G:{self.g_scal:.3f}, B:{self.b_scal:.3f}")
    def read_rgb(self):
        # 读取RGB三个通道的频率值,应用白平衡,并转换为RGB
        r = 0
        g = 0
        b = 0
        # 读取RGB三个通道的频率值
        red_freq, green_freq, blue_freq = self.read_rgb_freq()
        # 应用白平衡校准 (18000/255 = 70)
        r = int(red_freq / 70 * self.r_scal)
        g = int(green_freq / 70 * self.g_scal)
        b = int(blue_freq / 70 * self.b_scal)
        # 限制在0-255范围
        return r, g, b
# 初始化板载按键D0/BOOT0,按下接地
button0 = digitalio.DigitalInOut(board.BUTTON)
button0.switch_to_input(pull=digitalio.Pull.UP)
# 初始化板载按键D1,按下接VCC
button1 = digitalio.DigitalInOut(board.D1)
button1.switch_to_input(pull=digitalio.Pull.DOWN)
# 初始化板载按键D2,按下接VCC
button2 = digitalio.DigitalInOut(board.D2)
button2.switch_to_input(pull=digitalio.Pull.DOWN)
# 初始化板载LED
led0 = digitalio.DigitalInOut(board.LED)
# led0 = digitalio.DigitalInOut(board.D13)
led0.direction = digitalio.Direction.OUTPUT
led0.value = True
# 初始化颜色传感器LED补光灯
led1 = digitalio.DigitalInOut(board.D5)
led1.direction = digitalio.Direction.OUTPUT
led1.value = True
# 初始化显示屏
display = board.DISPLAY
# 创建显示组
splash = displayio.Group()
display.root_group = splash
# 创建DIY活动文本标签
textdo = "Let's do - EEPW DIY"
text_area_do = label.Label(terminalio.FONT, text=textdo, color=0xFFFF00, x=60, y=20)
# 创建文本标签用于显示RGB值
text_area_r = label.Label(terminalio.FONT, text="R: ---", color=0xFF0000, x=10, y=50)
text_area_g = label.Label(terminalio.FONT, text="G: ---", color=0x00FF00, x=10, y=70)
text_area_b = label.Label(terminalio.FONT, text="B: ---", color=0x0000FF, x=10, y=90)
text_area_h = label.Label(terminalio.FONT, text="#------", color=0xFFFFFF, x=10, y=120)
# 创建颜色色块显示区域(矩形)
# 位置在屏幕右侧,大小80x80像素
color_block = displayio.TileGrid(
    displayio.Bitmap(80, 80, 1),
    pixel_shader=displayio.Palette(1),
    x=150,  # 右侧位置
    y=40    # 垂直居中
color_block.pixel_shader[0] = rgb888_to_rgb565(0, 0, 0)  # 初始黑色
splash.append(color_block)
# 显示输出
for text_area in (text_area_do, text_area_r, text_area_g, text_area_b, text_area_h):
    splash.append(text_area)
# 创建颜色平滑器
color_smoother = SimpleSmoother(alpha=0.3)  # 适度的平滑
# 创建TCS3200颜色传感器实体
try:
    # 创建TCS3200对象
    color_sensor = TCS3200(
        s0_pin=board.D12,
        s1_pin=board.D11,
        s2_pin=board.D10,
        s3_pin=board.D9,
        out_pin=board.D6
    print("TCS3200实例创建成功")
except Exception as e:
    print(f"初始化TCS3200失败: {e}")
    # 创建虚拟传感器用于测试
    color_sensor = None
# 主循环
while True:
    led0.value = True
    time.sleep(0.05)
    # 读取按键0
    if not button0.value:
        print("button0按下")
        Button0_Value = 1
        Button1_Value = 0
        Button2_Value = 0
    # 读取按键1
    if button1.value:
        print("button1按下")
        Button0_Value = 0
        Button1_Value = 1
        Button2_Value = 0
    # 读取按键2
    if button2.value:
        print("button2按下")
        Button0_Value = 0
        Button1_Value = 0
        Button2_Value = 1
    if Button0_Value:
        Button0_Value = 0
        # 调用白平衡校准
        color_sensor.calibrate_white_balance()
        # 更新显示
        text_area_r.text = "R: {:.3f}".format(color_sensor.r_scal)
        text_area_g.text = "G: {:.3f}".format(color_sensor.g_scal)
        text_area_b.text = "B: {:.3f}".format(color_sensor.b_scal)
        text_area_h.text = "#------"
        # 将颜色色块重置为白色(使用正确的RGB565格式)
        color_block.pixel_shader[0] = rgb888_to_rgb565(255, 255, 255)
        # 重置平滑器
        color_smoother.reset()
    if Button1_Value:
        # 读取并显示TCS3200颜色传感器的频率值
        if color_sensor is not None:
            try:
                # 调用read_rgb_freq方法读取频率值
                R_Val, G_Val, B_Val = color_sensor.read_rgb_freq()
                # 更新显示
                text_area_r.text = "R: {:.3f}".format(R_Val)
                text_area_g.text = "G: {:.3f}".format(G_Val)
                text_area_b.text = "B: {:.3f}".format(B_Val)
                text_area_h.text = "#: {:.3f},{:.3f},{:.3f}".format(R_Val, G_Val, B_Val)
                # 将频率值转换为0-255范围
                # 频率值通常在0-18000之间,我们将其映射到0-255
                r_color = int(min(255, max(0, R_Val / 70)))
                g_color = int(min(255, max(0, G_Val / 70)))
                b_color = int(min(255, max(0, B_Val / 70)))
                # 应用平滑处理
                r_smooth, g_smooth, b_smooth = color_smoother.smooth(r_color, g_color, b_color)
                # 转换为正确的RGB565格式并更新颜色色块
                color_value = rgb888_to_rgb565(r_smooth, g_smooth, b_smooth)
                color_block.pixel_shader[0] = color_value
                print("RGB: {:.3f},{:.3f},{:.3f}".format(R_Val, G_Val, B_Val))
                print(f"读取颜色传感器错误: {e}")
                R_Val = 128
                G_Val = 128
                B_Val = 128
                # 更新颜色色块为灰色(使用正确的RGB565格式)
                color_block.pixel_shader[0] = rgb888_to_rgb565(128, 128, 128)
        else:
            # 更新显示屏
    if Button2_Value:
        # 读取并显示TCS3200颜色传感器的RGB值
            try:
                # 调用read_rgb方法读取颜色值
                R_Val, G_Val, B_Val = color_sensor.read_rgb()
                # 更新显示
                text_area_r.text = "R: {:3d}".format(R_Val)
                text_area_g.text = "G: {:3d}".format(G_Val)
                text_area_b.text = "B: {:3d}".format(B_Val)
                text_area_h.text = "#: {:02X}{:02X}{:02X}".format(R_Val, G_Val, B_Val)
                # 应用平滑处理
                r_smooth, g_smooth, b_smooth = color_smoother.smooth(R_Val, G_Val, B_Val)
                print("RGB: #{:02X}{:02X}{:02X}".format(R_Val, G_Val, B_Val))
                R_Val = 128
                G_Val = 128
                B_Val = 128
        else:
            # 更新显示屏
    led0.value = False
    time.sleep(0.05)
识别颜色显示色块.zip
