【前言】
Zephyr已经支持STM32H747的官方开发板,可以快速的实现入门。本篇将分享如何快速体验hello wold。
【开发环境】
1、wsl2
2、west
【实现步骤】
1、复制hello world工程
~/zephyrproject/app/stm32h747$ cp -r ~/zephyrproject/zephyr/samples/hello_world/ hello_world
2、加载虚拟环境:
~/zephyrproject/app/stm32h747/hello_world$ source ~/zephyrproject/zephyr/zephyr-env.sh
3、进入hello world工程,执行编译:
west build -b stm32h747i_disco/stm32h747xx/m7
这里注意的是,一定要指定编译哪个内核。
编译的结果如下:
-- west build: building application [1/153] Preparing syscall dependency handling [3/153] Generating include/generated/zephyr/version.h -- Zephyr version: 4.3.0 (/home/lugl/zephyrproject/zephyr), build: v4.3.0 [153/153] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 18900 B 1 MB 1.80% RAM: 4608 B 512 KB 0.88% EXTMEM: 0 GB 64 MB 0.00% SRAM0: 0 GB 512 KB 0.00% SRAM1: 0 GB 128 KB 0.00% SRAM2: 0 GB 128 KB 0.00% SRAM3: 16 KB 32 KB 50.00% SRAM4: 0 GB 64 KB 0.00% SDRAM2: 0 GB 32 MB 0.00% IDT_LIST: 0 GB 32 KB 0.00% Generating files from /home/lugl/zephyrproject/app/stm32h747/hello_world/build/zephyr/zephyr.elf for board: stm32h747i_disco
4、下载,需要在windows下面的powrshell下面执行
usbipd bind --busid 4-3 --force usbipd attach --wsl --busid 4-3
然后在wsl查看:
lugl@lugl:~/zephyrproject/app/stm32h747/hello_world$ lsusb | grep -i "0483:374e" Bus 001 Device 002: ID 0483:374e STMicroelectronics STLINK-V3
5、下载
west flash --runner openocd
【出问题了】
下载后出现
Error: stm32h7x.cpu0 -- clearing lockup after double fault target halted due to debug-request, current mode: Handler Reset xPSR: 0xa05f0001 pc: 0xa05f0001 msp: 0xa05f0001 Polling target stm32h7x.cpu0 failed, trying to reexamine Info : stm32h7x.cpu0: hardware has 0 breakpoints, 10 watchpoints Info : stm32h7x.cpu0: external reset detected shutdown command invoked
估计是M4内核没有初始化,准备下载stm32cubeprograme,将M4内核关闭然后再看看。
