【目标】
体验环境监测功能,实现室内二氧化碳监测
【开发环境】
1、wsl2
2、west
【实现步骤】
1、在原有oled显示驱动的工程中添加stcc4驱动库
到github:Sensirion/embedded-i2c-stcc4中下载驱动包,放入工程中:
2、修改设备树,i2c0下添加stcc4节点
&sci0 {
status = "okay";
uart {
status = "disabled";
i2c: i2c {
compatible = "renesas,ra-i2c-sci";
status = "okay";
clock-frequency = <400000>;
ssd1306: ssd1306@3c {
compatible = "solomon,ssd1306fb";
reg = <0x3c>;
width = <128>;
height = <64>;
segment-offset = <0>; // 列偏移(通常为 0)
page-offset = <0>; // ←←← 行(页)偏移(通常为 0)
display-offset = <0>;
multiplex-ratio = <63>;
prechargep = <2>;
status = "okay";
// 添加 STCC4 传感器节点
stcc4: stcc4@62 {
compatible = "sensirion,stcc4";
reg = <0x64>;
status = "okay";
};3、修改hal驱动适配ra6e2的初始化
* @brief 初始化 I2C —— 由你的应用或驱动调用
int sensirion_i2c_hal_init_with_device(const struct device *i2c_dev, uint8_t addr)
if (!device_is_ready(i2c_dev)) {
LOG_ERR("I2C device not ready");
return -ENODEV;
i2c_bus_dev = i2c_dev;
stcc4_i2c_addr = addr;
return 0;
}4、添加read、write代码实现驱动对接:
int8_t sensirion_i2c_hal_read(uint8_t address, uint8_t* data, uint8_t count) {
ARG_UNUSED(address);
if (i2c_read(i2c_bus_dev, data, count, stcc4_i2c_addr) != 0) {
LOG_ERR("I2C read failed");
return -1;
return 0;
int8_t sensirion_i2c_hal_write(uint8_t address, const uint8_t* data,
uint8_t count) {
ARG_UNUSED(address); // 我们已固定地址
if (i2c_write(i2c_bus_dev, data, count, stcc4_i2c_addr) != 0) {
LOG_ERR("I2C write failed");
return -1;
return 0;
}5、添加延时函数的对接,直接使用zephyr的延时来实现:
void sensirion_i2c_hal_sleep_usec(uint32_t useconds) {
if (useconds < 1000) {
k_usleep(useconds);
} else {
k_msleep(useconds / 1000);
}6、编译
lugl@lugl:~/zephyrproject/app/ra6e2/ra6e2_ssd1306_i2c$ west build -b fpb_ra6e2 [1/7] Building C object CMakeFiles/app.dir/src/main.c.obj /home/lugl/zephyrproject/app/ra6e2/ra6e2_ssd1306_i2c/src/main.c:17:6: warning: return type of 'main' is not 'int' [-Wmain] 17 | void main(void) | ^~~~ [7/7] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 31340 B 256 KB 11.96% RAM: 6632 B 40 KB 16.19% OFS_OFS0_MEMORY: 4 B 4 B 100.00% OFS_OSIS_MEMORY: 16 B 16 B 100.00% OFS_OFS1_SEC_MEMORY: 4 B 4 B 100.00% OFS_BPS_SEC_MEMORY: 4 B 4 B 100.00% OFS_PBPS_SEC_MEMORY: 4 B 4 B 100.00% IDT_LIST: 0 GB 32 KB 0.00% Generating files from /home/lugl/zephyrproject/app/ra6e2/ra6e2_ssd1306_i2c/build/zephyr/zephyr.elf for board: fpb_ra6e2
7、下载
使用jlink flash下载
【效果展示】
【总结】
在zephyr生态中,对i2c设备的支持非常友好,只需要少量的代码便可以移植并驱动外设。
附源码代码
