电子产品世界 » 论坛首页 » DIY与开源设计 » 开源硬件 » 【树莓派5创意赛】树莓派WEB控制设计-过程帖
2026-02-12 22:54:32     打赏
网页后端服务运行在树莓派上,首先设计项目结构
web-control/
├── app.py                 # Flask Web服务器
├── requirements.txt       # Python依赖包
├── static/
│   ├── css/
│   │   └── style.css     # 样式表
│   └── js/
│       └── script.js     # 前端JavaScript
└── templates/
    └── index.html        # 网页模板
后端用python设计,流程如下:
#!/usr/bin/env python3
树莓派5 Flask Web服务器
import socket
import threading
import time
from flask import Flask, render_template, request, jsonify, Response
app = Flask(__name__)
# 配置
ESP32_IP = "192.168.1.100"  # 修改为你的ESP32 IP地址
ESP32_PORT = 5000
ESP32_TIMEOUT = 3
# 全局变量
tcp_socket = None
connection_status = False
status_lock = threading.Lock()
# 默认配置
default_config = {
    "frequency": 1000,
    "waveform": "SINE",
    "output": True,
    "ip": ESP32_IP,
    "port": ESP32_PORT
# 波形名称映射
WAVEFORM_MAP = {
    "SINE": "正弦波",
    "SQUARE1": "方波1",
    "SQUARE2": "方波2",
    "TRIANGLE": "三角波"
class AD9833Controller:
    def __init__(self, ip, port):
        self.ip = ip
        self.port = port
        self.socket = None
        self.connected = False
    def connect(self):
        """连接到ESP32 TCP服务器"""
        try:
            self.socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
            self.socket.settimeout(ESP32_TIMEOUT)
            self.socket.connect((self.ip, self.port))
            # 读取欢迎消息
            welcome = self.receive_response()
            print(f"Connected to ESP32: {welcome}")
            self.connected = True
            with status_lock:
                global connection_status
                connection_status = True
            return True, "连接成功"
        except Exception as e:
            error_msg = f"连接失败: {str(e)}"
            print(error_msg)
            with status_lock:
            return False, error_msg
    def disconnect(self):
        """断开连接"""
        if self.socket:
            try:
                self.send_command("EXIT")
                self.socket.close()
            except:
                pass
            finally:
                self.socket = None
                with status_lock:
    def send_command(self, command):
        """发送命令到ESP32"""
        if not self.socket or not self.connected:
            success, message = self.connect()
            if not success:
                return False, "未连接到设备"
        try:
            # 发送命令(添加换行符)
            self.socket.sendall((command + "\n").encode('utf-8'))
            return True, "命令已发送"
            with status_lock:
            return False, f"发送失败: {str(e)}"
    def receive_response(self, timeout=2):
        """接收ESP32的响应"""
        if not self.socket:
            return ""
        try:
            self.socket.settimeout(timeout)
            response = b""
            while True:
                try:
                    chunk = self.socket.recv(1024)
                    if not chunk:
                        break
                    response += chunk
                    # 如果收到换行符或响应结束
                    if b'\n' in chunk or len(chunk) < 1024:
                        break
                except socket.timeout:
                    break
            return response.decode('utf-8', errors='ignore').strip()
            print(f"接收响应错误: {e}")
            return ""
    def send_and_receive(self, command):
        """发送命令并接收响应"""
        success, msg = self.send_command(command)
        if not success:
            return success, msg
        time.sleep(0.1)  # 等待ESP32处理
        response = self.receive_response()
        return True, response
    def set_frequency(self, frequency):
        """设置频率"""
        try:
            freq = int(frequency)
            if freq < 0 or freq > 12500000:
                return False, "频率超出范围 (0-12,500,000 Hz)"
            success, response = self.send_and_receive(f"FREQ={freq}")
            return success, response
        except ValueError:
            return False, "无效的频率值"
    def set_waveform(self, waveform):
        """设置波形"""
        waveform = waveform.upper()
        if waveform not in ["SINE", "SQUARE1", "SQUARE2", "TRIANGLE"]:
            return False, "无效的波形类型"
        success, response = self.send_and_receive(f"WAVE={waveform}")
    def set_output(self, enable):
        """启用/禁用输出"""
        command = "ON" if enable else "OFF"
        success, response = self.send_and_receive(command)
    def get_status(self):
        """获取设备状态"""
        success, response = self.send_and_receive("STATUS")
        if success and response:
            # 解析状态响应
            status_info = {"connected": True}
            lines = response.split('\n')
            for line in lines:
                line = line.strip()
                if "Frequency:" in line:
                    try:
                        freq_str = line.split(":")[1].strip().split(" ")[0]
                        status_info["frequency"] = int(freq_str)
                    except:
                        status_info["frequency"] = 0
                elif "Waveform:" in line:
                    wave_str = line.split(":")[1].strip()
                    status_info["waveform"] = wave_str
                elif "Output:" in line:
                    output_str = line.split(":")[1].strip()
                    status_info["output"] = (output_str == "ON")
            return True, status_info
    def test_device(self):
        """运行测试序列"""
        success, response = self.send_and_receive("TEST")
    def reset_device(self):
        """重置设备"""
        success, response = self.send_and_receive("RESET")
# 创建控制器实例
controller = AD9833Controller(ESP32_IP, ESP32_PORT)
# Flask路由
@app.route('/')
def index():
    """主页"""
    return render_template('index.html',
                         ip=ESP32_IP,
                         port=ESP32_PORT,
                         default_freq=default_config["frequency"])
@app.route('/api/connect', methods=['POST'])
def api_connect():
    """连接设备API"""
    data = request.json
    ip = data.get('ip', ESP32_IP)
    port = data.get('port', ESP32_PORT)
    # 更新IP和端口
    global ESP32_IP, ESP32_PORT
    ESP32_IP = ip
    ESP32_PORT = int(port)
    # 创建新的控制器实例
    global controller
    success, message = controller.connect()
    if success:
        # 获取初始状态
        controller.get_status()
    return jsonify({
        "success": success,
        "message": message,
        "connected": success
@app.route('/api/disconnect', methods=['POST'])
def api_disconnect():
    """断开连接API"""
    controller.disconnect()
    return jsonify({
        "success": True,
        "message": "已断开连接",
        "connected": False
@app.route('/api/status', methods=['GET'])
def api_status():
    """获取状态API"""
    with status_lock:
        connected = connection_status
    if connected:
        success, response = controller.get_status()
        if success and isinstance(response, dict):
            return jsonify({
                "success": True,
                "connected": True,
                "data": response
        elif success:
            return jsonify({
                "success": True,
                "connected": True,
                "data": {"message": response}
        else:
            return jsonify({
                "success": False,
                "connected": False,
                "message": response
    else:
        return jsonify({
            "success": False,
            "connected": False,
            "message": "未连接到设备"
@app.route('/api/set_frequency', methods=['POST'])
def api_set_frequency():
    """设置频率API"""
    data = request.json
    frequency = data.get('frequency', 1000)
    success, message = controller.set_frequency(frequency)
    return jsonify({
        "success": success,
        "message": message,
        "frequency": frequency if success else None
@app.route('/api/set_waveform', methods=['POST'])
def api_set_waveform():
    """设置波形API"""
    data = request.json
    waveform = data.get('waveform', 'SINE')
    success, message = controller.set_waveform(waveform)
    return jsonify({
        "success": success,
        "message": message,
        "waveform": waveform if success else None,
        "waveform_cn": WAVEFORM_MAP.get(waveform, "未知")
@app.route('/api/set_output', methods=['POST'])
def api_set_output():
    """设置输出API"""
    data = request.json
    enable = data.get('enable', True)
    success, message = controller.set_output(enable)
    return jsonify({
        "success": success,
        "message": message,
        "output": enable if success else None
@app.route('/api/test', methods=['POST'])
def api_test():
    """测试设备API"""
    success, message = controller.test_device()
    return jsonify({
        "success": success,
        "message": message
@app.route('/api/reset', methods=['POST'])
def api_reset():
    """重置设备API"""
    success, message = controller.reset_device()
    return jsonify({
        "success": success,
        "message": message
@app.route('/api/ping', methods=['GET'])
def api_ping():
    """心跳检测API"""
    with status_lock:
        return jsonify({
            "success": True,
            "connected": connection_status,
            "timestamp": time.time()
# 错误处理
@app.errorhandler(404)
def not_found(error):
    return jsonify({"success": False, "message": "资源未找到"}), 404
@app.errorhandler(500)
def server_error(error):
    return jsonify({"success": False, "message": "服务器内部错误"}), 500
def start_status_monitor():
    """状态监控线程"""
    def monitor():
        while True:
            time.sleep(5)  # 每5秒检查一次
            with status_lock:
                if connection_status and controller.connected:
                    try:
                        # 发送PING命令保持连接
                        controller.send_command("PING")
                    except:
    monitor_thread = threading.Thread(target=monitor, daemon=True)
    monitor_thread.start()
if __name__ == '__main__':
    print("=" * 50)
    print("Web控制程序")
    print("=" * 50)
    print(f"目标设备: {ESP32_IP}:{ESP32_PORT}")
    print("Web界面: http://0.0.0.0:8080")
    print("=" * 50)
    # 启动状态监控
    # 启动Flask服务器
    app.run(host='0.0.0.0', port=8080, debug=False, threaded=True)
样式表、html文件
树莓派终端运行方法:
source venv/bin/activate
# 运行Flask应用
python app.py
# 或者以后台方式运行
nohup python app.py > webapp.log 2>&1 &
web_control.zip
效果如下:
2026-02-18 10:22:52     打赏
这网页看上去还是简洁,清晰。
舒服。
