请到我的BLOG下载: http://twentyone.blogchina.com
1. Improve the support to ARM9E-S and ARM9EJ-S.
2. Add TAP configuration to support complex TAP/JTAG
3. Add the support for initialization script, which can be used for auto initialization
4. Add the programming of NOR flash and AT91SAM. But only a few chips are supported currently. I will upgrade H-Flasher to support more NOR flash chip step by step. The programming of AT91SAM chips may have some problem. I am looking for some boards for testing. I will correct the problem asap.
