这个I/O的电气特性跟其他管脚一样吗?一般为1.8~3.6V ,因为是比较器的管脚是否可以加大一点0~12V
答 1:
引用:
答 2:
CACTL1 = CAON+CAREF_2;
CACTL2 = P2CA1+CAF;
if (CAOUT & CACTL2)
P1OUT &= ~ BIT3; //if CAOUT set, set P1.0
else
P1OUT |= &BIT3;
这CAOUT 怎么老为1呢?调来调去都一样,不灵拉,杨工, 答 3: P1OUT|=&BIT3这句合适吗? 答 4: 你再对照一下这个例子,和内部功能图示比较一下。
// MSP-FET430F1121 Demo - Comp_A Detect theashold, Set P1.0 if P2.3 > 0.25*Vcc
// Description; Use comparator_A to detect a voltage threshold.
// Using an external potentiometer, an unknown voltage is applied to P2.3.
// Comparator_A compares the unknown voltage to an internal reference
// voltage, in this example 0.25*VCC. If the unknown voltage is higher
// than 0.25*VCC, P1.0 is set, if not, P1.0 is reset.
// MSP430F1121
// _________________
// /|\ | XIN|-
// ---|RST XOUT|-
// R<-|P2.3 P1.0|-->LED
// ---|VSS
// M.Buccini
// Texas Instruments, Inc
// January 2002
// Built with IAR Embedded Workbench Version: 1.25A
#include "MSP430x11x1.h"
void main (void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P1DIR |= BIT0; // P1.0 output
CACTL1 = CARSEL + CAREF0 + CAON; // 0.25 Vcc = -comp, on
CACTL2 = P2CA0; // P2.3 = +comp
while (1) // Test comparator_A output
if ((CAOUT & CACTL2) == CAOUT) P1OUT |= BIT0; // if CAOUT set, set P1.0
else P1OUT &= ~BIT0; // else reset
CACTL2 = P2CA1+CAF;
if (CAOUT & CACTL2)
else
P1OUT |= &BIT3;
// MSP430F1121
// /|\ | XIN|-
// ---|RST XOUT|-
// ---|VSS
// M.Buccini
// January 2002
void main (void)
| 电子价签墨水屏开发被打赏¥35元 | |
