编译了三个小时,已到了最关键的步骤了,没想到出现这个错误:
FO ] Installing final compiler
[EXTRA] Configuring final compiler
[EXTRA] Building final compiler
[ERROR] gcj: internal compiler error: Killed (program jc1)
[ERROR] make[4]: *** [ecjx] Error 4
[ERROR] / ^C
[ERROR] >>
[ERROR] >> Build failed in step 'Installing final compiler'
[ERROR] >> called in step '(top-level)'
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions@172]
[ERROR] >> called from: do_cc_backend[scripts/build/cc/gcc.sh@788]
[ERROR] >> called from: do_cc_for_host[scripts/build/cc/gcc.sh@546]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@598]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: 'build.log'
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> '/home/tiny6410/crosstool/crosstool-install/share/doc/crosstool-ng/ct-ng.1.15.2/B - Known issues.txt'
[ERROR] /
[ERROR] (elapsed: 285:30.42)
怎么办????
| 有奖活动 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| 打赏了!打赏了!打赏了! | |
