电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 在ubuntu下用crosstool-ng自制交叉工具链时的错误
2012-05-20 23:46:39     打赏
编译了三个小时,已到了最关键的步骤了,没想到出现这个错误:
FO ]  Installing final compiler
[EXTRA]    Configuring final compiler
[EXTRA]    Building final compiler
[ERROR]    gcj: internal compiler error: Killed (program jc1)
[ERROR]    make[4]: *** [ecjx] Error 4
[ERROR]  / ^C
[ERROR]  >>
[ERROR]  >>  Build failed in step 'Installing final compiler'
[ERROR]  >>        called in step '(top-level)'
[ERROR]  >>
[ERROR]  >>  Error happened in: CT_DoExecLog[scripts/functions@172]
[ERROR]  >>        called from: do_cc_backend[scripts/build/cc/gcc.sh@788]
[ERROR]  >>        called from: do_cc_for_host[scripts/build/cc/gcc.sh@546]
[ERROR]  >>        called from: main[scripts/crosstool-NG.sh@598]
[ERROR]  >>
[ERROR]  >>  For more info on this error, look at the file: 'build.log'
[ERROR]  >>  There is a list of known issues, some with workarounds, in:
[ERROR]  >>      '/home/tiny6410/crosstool/crosstool-install/share/doc/crosstool-ng/ct-ng.1.15.2/B - Known issues.txt'
[ERROR]  /
[ERROR]  (elapsed: 285:30.42)
怎么办????
关键词: ubuntu     下用     crosstool-ng     自制
