WINAVR20040404 各位大虾,请教在WINAVR20040404中多文件编译的问题
我在编译多文件工程的时候出现了以下的信息,请问怎样才能够解决它?谢谢!
make.exe: *** No rule to make target `panal.o', needed by `main.elf'. Stop.
我的工程中有八个文件:
main.c configer.h
device.c device.h
panal.c panal.h
work.c work.h
全部的信息是:
-------- begin --------
AVR-gcc (GCC) 3.3.2
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling: main.c
AVR-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst -std=gnu99 -Wp,-M,-MP,-MT,main.o,-MF,.dep/main.o.d main.c -o main.o
> Process Exit Code: 2
答 1: 我想你应该把makefile贴出来,才好看问题在哪 答 2: 好的,谢谢!# Hey Emacs, this is a -*- makefile -*-
# WinAVR Sample makefile written by Eric B. Weddington, J鰎g Wunsch, et al.
# Released to the Public Domain
# Please read the make user manual!
# Additional material for this makefile was submitted by:
# Tim Henigan
# Peter Fleury
# Reiner Patommel
# Sander Pool
# Frederik Rouleau
# Markus Pfaff
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make coff = Convert ELF to AVR COFF (for use with AVR Studio 3.x or VMLAB).
# make extcoff = Convert ELF to AVR Extended COFF (for use with AVR Studio
# 4.07 or greater).
# make program = Download the hex file to the device, using AVRdude. Please
# customize the AVRdude settings below first!
# make filename.s = Just compile filename.c into the assembler code only
# To rebuild project do "make clean" then "make all".
# MCU name
MCU = atmega8
# Output format. (CAN be srec, ihex, binary)
FORMAT = ihex
# Target file name (without extension).
TARGET = main
# List C source files here. (C dependencies are automatically generated.)
SRC += $(TARGET).c main.c panal.c device.c work.c
#SRC += main.c panal.c device.c work.c
# List Assembler source files here.
# Make them always end in a capital .S. Files ending in a lowercase .s
# will not be considered source files but generated files (assembler
# output from the compiler), and will be deleted upon "make clean"!
# Even though the DOS/Win* filesystem matches both .s and .S the same,
# it will preserve the spelling of the filenames, and gcc itself does
# care about how the name is spelled on its command-line.
ASRC =
# Optimization level, CAN be [0, 1, 2, 3, s].
# 0 = turn off optimization. s = optimize for size.
# (Note: 3 is not always the best optimization level. See AVR-libc FAQ.)
OPT = s
# List any extra directories to look for include files here.
# Each directory must be seperated by a space.
EXTRAINCDIRS =
# Compiler flag to set the C Standard level.
# c89 - "ANSI" C
# gnu89 - c89 plus GCC extensions
# c99 - ISO C99 standard (not yet fully implemented)
# gnu99 - c99 plus GCC extensions
CSTANDARD = -std=gnu99
# Place -D or -U options here
CDEFS =
# Place -I options here
CINCS =
# Compiler flags.
# -g: generate debugging information
# -O*: optimization level
# -f...: tuning, see GCC manual and AVR-libc documentation
# -Wall...: warning level
# -Wa,...: tell GCC to pass this to the assembler.
# -adhlns...: create assembler listing
CFLAGS = -g
CFLAGS += $(CDEFS) $(CINCS)
CFLAGS += -O$(OPT)
CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -Wall -Wstrict-prototypes
CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
CFLAGS += $(CSTANDARD)
# Assembler flags.
# -ahlms: create listing
# -gstabs: have the assembler create line number information; note that
# for use in COFF files, additional information about filenames
# and function names needs to be present in the assembler source
# files -- see AVR-libc docs [FIXME: not yet described there]
ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs
#Additional libraries.
# Minimalistic printf version
PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires MATH_LIB = -lm below)
PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
PRINTF_LIB =
# Minimalistic sCANf version
SCANF_LIB_MIN = -Wl,-u,vfsCANf -lsCANf_min
# Floating point + %[ sCANf version (requires MATH_LIB = -lm below)
SCANF_LIB_FLOAT = -Wl,-u,vfsCANf -lsCANf_flt
SCANF_LIB =
MATH_LIB = -lm
# External memory options
# 64 KB of external RAM, starting after internal RAM (ATmega128!),
# used for variables (.data/.bss) and heap (malloc()).
#EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
# only used for heap (malloc()).
#EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
EXTMEMOPTS =
# Linker flags.
# -Wl,...: tell GCC to pass this to linker.
# -Map: create map file
# --cref: add cross reference to map file
LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
LDFLAGS += $(EXTMEMOPTS)
LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
# Programming support using AVRdude. Settings and variables.
# Programming hardware: alf AVR910 AVRisp bascom bsd
# dt006 pAVR PICoweb pony-stk200 sp12 stk200 stk500
# Type: AVRdude -c ?
# to get a full listing.
AVRDUDE_PROGRAMMER = stk500
# com1 = serial port. Use lpt1 to connect to parallel port.
AVRDUDE_PORT = com1 # programmer connected to serial device
AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
#AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
# Uncomment the following if you want AVRdude's erase cycle counter.
# Note that this counter needs to be initialized first using -Yn,
# see AVRdude manual.
#AVRDUDE_ERASE_COUNTER = -y
# Uncomment the following if you do /not/ wish a verification to be
# performed after programming the device.
#AVRDUDE_NO_VERIFY = -V
# Increase verbosity level. Please use this when submitting bug
# reports about AVRdude. See <http://savannah.nongnu.org/projects/AVRdude>
# to submit bug reports.
#AVRDUDE_VERBOSE = -v -v
AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
# Define directories, if needed.
DIRAVR = c:/winAVR
DIRAVRBIN = $(DIRAVR)/bin
DIRAVRUTILS = $(DIRAVR)/utils/bin
DIRINC = .
DIRLIB = $(DIRAVR)/AVR/lib
# Define programs and commands.
SHELL = sh
CC = AVR-gcc
OBJCOPY = AVR-objcopy
OBJDUMP = AVR-objdump
SIZE = AVR-size
NM = AVR-nm
AVRDUDE = AVRdude
REMOVE = rm -f
COPY = cp
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = -------- begin --------
MSG_END = -------- end --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_COFF = Converting to AVR COFF:
MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
MSG_FLASH = Creating load file for Flash:
MSG_EEPROM = Creating load file for EEPROM:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling:
MSG_ASSEMBLING = Assembling:
MSG_CLEANING = Cleaning project:
# Define all object files.
OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(SRC:.c=.lst)
# Compiler flags to generate dependency files.
GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore build sizeafter finished end
build: elf hex eep lss sym
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
# Eye CANdy.
# AVR Studio 3.x does not check make's exit code but relies on
# the following magic strings to be generated by the compile job.
begin:
@echo
@echo $(MSG_BEGIN)
finished:
@echo $(MSG_ERRORS_NONE)
end:
@echo $(MSG_END)
@echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) -A $(TARGET).elf
sizebefore:
@if ][ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); echo; fi
sizeafter:
@if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); echo; fi
# Display compiler version information.
gccversion :
@$(CC) --version
# Program the device.
program: $(TARGET).hex $(TARGET).eep
$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
# Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
COFFCONVERT=$(OBJCOPY) --debugging \
--change-section-address .data-0x800000 \
--change-section-address .bss-0x800000 \
--change-section-address .noinit-0x800000 \
--change-section-address .eeprom-0x810000
coff: $(TARGET).elf
@echo
@echo $(MSG_COFF) $(TARGET).cof
$(COFFCONVERT) -O coff-AVR $< $(TARGET).cof
extcoff: $(TARGET).elf
@echo
@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
$(COFFCONVERT) -O coff-ext-AVR $< $(TARGET).cof
# Create final output files (.hex, .eep) from ELF output file.
%.hex: %.elf
@echo
@echo $(MSG_FLASH) $@
$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
%.eep: %.elf
@echo
@echo $(MSG_EEPROM) $@
-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
%.lss: %.elf
@echo
@echo $(MSG_EXTENDED_LISTING) $@
$(OBJDUMP) -h -S $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
@echo
@echo $(MSG_SYMBOL_TABLE) $@
$(NM) -n $< > $@
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
@echo
@echo $(MSG_LINKING) $@
$(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS)
# Compile: create object files from C source files.
%.o : %.c
@echo
@echo $(MSG_COMPILING) $<
$(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C source files.
%.s : %.c
$(CC) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
%.o : %.S
@echo
@echo $(MSG_ASSEMBLING) $<
$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list finished end
clean_list :
@echo
@echo $(MSG_CLEANING)
$(REMOVE) $(TARGET).hex
$(REMOVE) $(TARGET).eep
$(REMOVE) $(TARGET).obj
$(REMOVE) $(TARGET).cof
$(REMOVE) $(TARGET).elf
$(REMOVE) $(TARGET).map
$(REMOVE) $(TARGET).a90
$(REMOVE) $(TARGET).sym
$(REMOVE) $(TARGET).lnk
$(REMOVE) $(TARGET).lss
$(REMOVE) $(OBJ)
$(REMOVE) $(LST)
$(REMOVE) $(SRC:.c=.s)
$(REMOVE) $(SRC:.c=.d)
$(REMOVE) .dep/*
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion \
build elf hex eep lss sym coff extcoff \
clean clean_list program
答 3: 试一试我的makefile:
#试一试我的makefile:
# WinAVR Sample makefile written by Eric B. Weddington, Jörg Wunsch, et al.
# On command line:
# 4.07 or greater).
#============= MCUÑ¡Ôñ ===========================
# MCU name
MCU = atmega8
#============= Êä³ö¸ñʽѡÔñ ======================
FORMAT = ihex
#============= Ä¿±êÎļþÃû(²»´øÀ©Õ¹Ãû) ============
TARGET = main
#============= ÓÅ»¯¼¶±ðÑ¡Ôñ ======================
# Optimization level, CAN be [0, 1, 2, 3, s]. 0 turns off optimization.
OPT = s
#============= C Ô´ÎļþÁбí("\"Ϊ»»ÐзûºÅ) =======
SRC = $(TARGET).c
# If there is more than one source file, append them above, or adjust and
# uncomment the following:
SRC += panal.c device.c work.c
# You CAN also wrap lines by appending a backslash to the end of the line:
#SRC += baz.c \
#xyzzy.c
#============= ASM Ô´ÎļþÁбí ====================
ASRC =
#============= C±àÒëÑ¡Ïî =========================
# Optional compiler flags.
# -g: generate debugging information (for GDB, or for COFF conversion)
# -f...: tuning, see gcc manual and AVR-libc documentation
# -ahlms: create assembler listing
CFLAGS = -g -O$(OPT) \
-funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums \
-Wall -Wstrict-prototypes \
-Wa,-ahlms=$(<:.c=.lst)
#============= »ã±àÆ÷Ñ¡Ïî ========================
# Optional assembler flags.
ASFLAGS = -Wa,-ahlms=$(<:.S=.lst),-gstabs
#============= Á¬½ÓÆ÷Ñ¡Ïî ========================
# Optional linker flags.
#============= ¸½¼Ó¿âÑ¡Ïî ========================
# Additional libraries
#LDFLAGS += -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires -lm below)
#LDFLAGS += -Wl,-u,vfprintf -lprintf_flt
# -lm = math library
LDFLAGS += -lm
# Programming hardware: AVRisp stk500 AVR910 pAVR stk200 pony-stk200
# dt006 bascom alf
#AVRDUDE_PORT = lpt1 # programmer connected to parallel port
AVRDUDE_ERASE = -e
#AVRDUDE_ERASE += -y
#AVRDUDE_FLAGS += -V
#AVRDUDE_FLAGS += -v -v
#============= Ö¸¶¨Ä¿Â¼£¬Èç¹ûÐèÒª ================
DIRAVR = c:/winAVR
DIRINC = .
#============= ¶¨ÒåÃüÁî(¹¤¾ßÈí¼þÃû³Æ) ============
SHELL = sh
CC = AVR-gcc
SIZE = AVR-size
AVRDUDE = AVRdude
REMOVE = rm -f
COPY = cp
#ELFSIZE = $(SIZE) -A $(TARGET).elf
ELFSIZE = $(SIZE) $(TARGET).elf
FINISH = echo Errors: none
BEGIN = echo -------- begin --------
END = echo -------- end --------
# Default target.
all: begin gccversion sizebefore $(TARGET).elf $(TARGET).hex $(TARGET).eep \
$(TARGET).lss sizeafter finished end
# Eye CANdy.
begin:
@$(BEGIN)
finished:
@$(FINISH)
end:
@$(END)
sizebefore:
@if [ -f $(TARGET).elf ]; then echo Size before:; $(ELFSIZE);fi
sizeafter:
@if [ -f $(TARGET).elf ]; then echo Size after:; $(ELFSIZE);fi
gccversion :
$(CC) --version
# AVR Studio or VMLAB.
coff: $(TARGET).elf
# Program the device. The magic trickery below examines the .eep hex
# file whether the size is > 0, and if so, reprograms the EEPROM as
# well. Just delete these lines if you don't want this feature (like
# on the ATmegas with the EESAVE fuse bit set).
$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_ERASE)
$(AVRDUDE) $(AVRDUDE_FLAGS) -i $(TARGET).hex
@$(SIZE) --target=$(FORMAT) $(TARGET).eep | while read line; \
do \
set -- $$line; \
if [ "x$$1" != "x0" ] ; then continue; fi; \
if [ "$$2" -ne 0 ] ; then \
echo $(AVRDUDE) $(AVRDUDE_FLAGS) -m eeprom -i $(TARGET).eep; \
break; \
fi; \
done
%.hex: %.elf
%.eep: %.elf
%.lss: %.elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
%.o : %.c
%.s : %.c
%.o : %.S
clean_list :
$(REMOVE) $(OBJ)
$(REMOVE) $(LST)
# Automatically generate C source code dependencies.
# (Code originally taken from the GNU make user manual and modified
# (See README.txt Credits).)
# Note that this will work with sh (bash) and sed that is shipped with WinAVR
# (see the SHELL variable defined above).
# This may not work with other shells or other seds.
%.d: %.c
set -e; $(CC) -MM $(ALL_CFLAGS) $< \
| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > $@; \
[ -s $@ ] || rm -f $@
# Remove the '-' if you want to see the dependency files generated.
-include $(SRC:.c=.d)
.PHONY : all begin finish end sizebefore sizeafter gccversion coff extcoff \
答 4: 感谢yfzhang,我试一试 答 5: 是不是不应该加main.c猜的
我的工程中有八个文件:
main.c configer.h
device.c device.h
panal.c panal.h
work.c work.h
全部的信息是:
AVR-gcc (GCC) 3.3.2
Compiling: main.c
# Tim Henigan
# Peter Fleury
# Reiner Patommel
# Sander Pool
# Frederik Rouleau
# Markus Pfaff
# On command line:
# 4.07 or greater).
# MCU name
MCU = atmega8
FORMAT = ihex
TARGET = main
ASRC =
OPT = s
EXTRAINCDIRS =
# c89 - "ANSI" C
CDEFS =
CINCS =
# Compiler flags.
CFLAGS = -g
CFLAGS += -O$(OPT)
# Assembler flags.
PRINTF_LIB =
SCANF_LIB =
MATH_LIB = -lm
EXTMEMOPTS =
# Linker flags.
DIRAVR = c:/winAVR
DIRINC = .
SHELL = sh
CC = AVR-gcc
SIZE = AVR-size
NM = AVR-nm
AVRDUDE = AVRdude
REMOVE = rm -f
COPY = cp
# Define Messages
# English
# Default target.
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
# Eye CANdy.
begin:
@echo
@echo $(MSG_BEGIN)
finished:
end:
@echo $(MSG_END)
@echo
sizebefore:
sizeafter:
gccversion :
@$(CC) --version
coff: $(TARGET).elf
@echo
@echo
%.hex: %.elf
@echo
%.eep: %.elf
@echo
%.lss: %.elf
@echo
%.sym: %.elf
@echo
$(NM) -n $< > $@
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
@echo
%.o : %.c
@echo
%.s : %.c
%.o : %.S
@echo
clean_list :
@echo
$(REMOVE) $(OBJ)
$(REMOVE) $(LST)
$(REMOVE) .dep/*
答 3: 试一试我的makefile:
#试一试我的makefile:
# On command line:
# 4.07 or greater).
# MCU name
MCU = atmega8
FORMAT = ihex
TARGET = main
OPT = s
SRC = $(TARGET).c
#SRC += baz.c \
#xyzzy.c
ASRC =
LDFLAGS += -lm
# dt006 bascom alf
AVRDUDE_ERASE = -e
DIRAVR = c:/winAVR
DIRINC = .
SHELL = sh
CC = AVR-gcc
SIZE = AVR-size
AVRDUDE = AVRdude
REMOVE = rm -f
COPY = cp
# Default target.
# Eye CANdy.
begin:
@$(BEGIN)
finished:
@$(FINISH)
end:
@$(END)
sizebefore:
sizeafter:
gccversion :
$(CC) --version
coff: $(TARGET).elf
do \
set -- $$line; \
break; \
fi; \
done
%.hex: %.elf
%.eep: %.elf
%.lss: %.elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
%.o : %.c
%.s : %.c
%.o : %.S
clean_list :
$(REMOVE) $(OBJ)
$(REMOVE) $(LST)
%.d: %.c
